电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 为什么指针无法读取返回值
共8条 1/1 1 跳转至页
为什么指针无法读取返回值
2013-12-17 00:48:24     打赏
#include<reg52.h>
#include "1602.h"
#include<intrins.h>
#define uint unsigned int
#define uchar unsigned char
#define  delay()  _nop_();_nop_();_nop_();_nop_();_nop_()
  sbit scl=P2^6;
  sbit sda=P2^7;
uchar  l[]={0x63,3,4,5,6,7,8,9};
uint k[8];
void start()
  sda=1;
  scl=1;
  delay();
  sda=0;
  delay();
  scl=0;
void stop()
sda=0;
scl=1;
delay();
sda=1;
delay();
void ack()
scl=1;
sda=1;
while(sda);
scl=0;
delay();
void PC_ack()
scl=1;
sda=1;
sda=0;
delay();
scl=0;
delay();
void write_byte(uchar d)
{ uchar i;
for(i=0;i<8;i++)
            sda=(bit)((d<<i)&0x80);
          scl=1;
          scl=0;
void write_one(uchar e,uchar f)
   start();
   write_byte(0xa0);
   ack();
   write_byte(e);
   ack();
   write_byte(f);
   ack();
   stop();
uint read_byte()
{ uchar i;
  uint b;
  for(i=0;i<8;i++)
              b<<=1;
                scl=0;
                b|=(sda)?0x01:0x00;
        scl=1;
    return b;
uchar read_one(uchar m)
  uchar b;
  start();
  write_byte(0xa0);
  ack();
  write_byte(m);
  ack();
  start();
  write_byte(0xa1);
  ack();
  b=read_byte();
  delay();
   stop();
   return b;
void write_page(uchar e,uchar *q)
   start();
   write_byte(0xa0);
   ack();
   write_byte(e);
   ack();
   while(*q)
            write_byte(*(q++));
     ack();
   stop();
uint read_page(uchar h,uchar m)
  uint *v;
  uchar i;
  start();
  write_byte(0xa0);
  ack();
  write_byte(h);
  ack();
  start();
  write_byte(0xa1);
  ack();
        for(i=0;i<m;i++)
          k=read_byte();
          PC_ack();
  stop();
  v=&k[0];
  return *v;
void main()
   uint **w;
   uchar i;
   write_page(0x00,l);
   LCD_init();
   while(1)
            for(i=0;i<8;i++)
          w=read_page(0x00,8);
           zl(0x80+i*2);
           sj((**w>>4)%10+0x30);
           sj((**w&0x0f)%10+0x30);
为什么在主函数中的
  会出现   illegal pointer conversion 的语句?哪位大神能告诉我,谢谢
2013-12-17 08:41:29     打赏
0x去掉
2013-12-17 09:04:42     打赏
好长啊
2013-12-17 09:35:36     打赏
楼主这是模拟的I2C通信吧,
  uint *v;
  uchar i;
  start();
  write_byte(0xa0);
  ack();
  write_byte(h);
  ack();
  start();
  write_byte(0xa1);
  ack();
        for(i=0;i<m;i++)
          k=read_byte();  ......此处也有问题吧,K【i】?
          PC_ack();
  stop();
  v=&k[0];.................返回数组的首地址,最终的目的
  return *v;
返回的是一个值,去给指向指针的指针赋值肯定行不通,
其实没必要这么复杂,指针传递是“传址”的,可以在外部声明一个指针数组,在内部用其来接收返回值,在外部会同步更新的,说多了也不好说,建议楼主看看C指针方面的资料。
2013-12-17 10:33:10     打赏
2013-12-17 20:32:14     打赏
指针跑偏了哟
注意*V和**W是不一样的
2013-12-18 23:24:18     打赏
我今天这样写没有语病,但还是乱码
uint   *k[8];
  uchar i;
  start();
  write_byte(0xa0);
  ack();
  write_byte(h);
  ack();
  start();
  write_byte(0xa1);
  ack();
  for(i=0;i<m;i++)
 *k[i]=read_byte();
 PC_ack();
  stop();
  return k[0];
void main()
//   uint *w;
   uchar i;
   write_page(0x00,l);
   LCD_init();
   while(1)
  read_page(0x00,8);
    for(i=0;i<8;i++)
  zl(0x80+i*2);
  sj((*k[i]>>4)%10+0x30);
  sj((*k[i]&0x0f)%10+0x30);
你能帮帮忙,把你想的写出来吗,谢谢
2013-12-19 22:34:40     打赏
不明白楼主为什么要用指针,I2C读页数据保存在数组k[i]里不就好啦,你定义*k[i],然后 *k[i]=read_byte(); 这是什么意思呢?难道你I2C读出的不是数据,全是另一些数据的地址????总之感觉你指针用的多此一举
共8条 1/1 1 跳转至页
