led流水灯的视频呵呵:
牛刀小试6.4 步进电机循环来回转动:
代码如下、如有不足,麻烦指正!
#include<stc89.h>
sbit mota = P1^5;
sbit motb = P1^6;
sbit motc = P1^7;
sbit motd = P3^5;
unsigned int n=1,x=0;
void delay(unsigned int t);
void right();
void left();
void delay(unsigned int t) //延时函数
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<114;j++);
void right() //反转函数
while(x++!=500)
mota=0;
motb=1;
motc=1;
motd=1;
delay(n);
mota=0;
motb=0;
motc=1;
motd=1;
delay(n);
mota=1;
motb=0;
motc=1;
motd=1;
delay(n);
mota=1;
motb=0;
motc=0;
motd=1;
delay(n);
mota=1;
motb=1;
motc=0;
motd=1;
delay(n);
mota=1;
motb=1;
motc=0;
motd=0;
delay(n);
mota=1;
motb=1;
motc=1;
motd=0;
delay(n);
mota=0;
motb=1;
motc=1;
motd=0;
delay(n);
void left() //正转函数
while(x++!=500)
motd=0;
motc=1;
motb=1;
mota=1;
delay(n);
motd=0;
motc=0;
motb=1;
mota=1;
delay(n);
motd=1;
motc=0;
motb=1;
mota=1;
delay(n);
motd=1;
motc=0;
motb=0;
mota=1;
delay(n);
motd=1;
motc=1;
motb=0;
mota=1;
delay(n);
motd=1;
motc=1;
motb=0;
mota=0;
delay(n);
motd=1;
motc=1;
motb=1;
mota=0;
delay(n);
motd=0;
motc=1;
motb=1;
mota=0;
delay(n);
void main()
while(1)
x=0;
left();
delay(10);
x=0;
right();
delay(10);
牛刀小试7.3数码管最低位显示'E'
做的时候参考了教程、然后把0-f都给定义了。
代码如下、请指教哈哈
#include<stc89.h>
code unsigned char segment[] = {0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0x08,0x03,0x46,0x21,0x06,0x0e};
//0到f花样,其中a为10、b为11、类推
code unsigned char select[] = {0xff,0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
unsigned char p=0;
sbit hc595st=P0^4;
sbit hc595out=P2^3;
sbit hc595dat=P0^2;
void hc595write(unsigned char dat);
void led(unsigned int x,unsigned char n,unsigned char dp);
void delay(unsigned int time);
void error();
void error() //错误显示函数
led(14,5,0);
led(10,4,0);
led(10,3,0);
led(0,2,0);
led(10,1,0);
void delay(unsigned int time) //延时函数
unsigned int i,j;
for(i=0;i<time;i++)
for(j=0;j<2;j++);
void hc595write(unsigned char dat) // 写入数据
unsigned char m;
hc595out=0;
for(m=0;m<8;m++)
hc595st=0;
if(0x80&dat)
hc595dat=1;
else
hc595dat=0;
hc595st=1;
delay(3);
dat<<=1;
void led(unsigned int x,unsigned char n,unsigned char dp) //显示(数码,位数,是否小数点)
if((x<16)&&(x>=0)&&(n<9)&&(n>=0)) //判断出错
if(dp!=0)
dp=segment[x];
else
dp=segment[x]|0x80;
hc595write(dp);
hc595write(select[n]);
hc595out=1;
delay(1);
hc595out=0;
delay(1);
else
p=1;
void main()
while(1)
if(p)
error();
else
led(14,1,0); //最低位显示”E“
牛刀小试13.3:在 LCD1602 的第一行显示“Hello!”,第二行显示“The world!”
调试了一晚、参考了一些资料、然后自己改改、弄了个头文件、以后要用到1602就比较方便了,共享给大家哈哈,不足指出、麻烦指出!多谢!
以下是主程序:
#include<stc89.h>
#include<1602.h>
void main(void)
code uchar *dat="Hello!";
code uchar *dats="The World!";
lcdinit();
DisplayListChar(0,0,dat);
DisplayListChar(0,1,dats);
while(1);
头文件要不要来个回复可见呢
——回复可见内容——
| PCF8574功能模块及其使用被打赏¥20元 | |
