#include
#include
#define uint unsigned int
#define uchar unsigned char
uchar code digit[10]={"0123456789"}; //定义字符数组显示数字
unsigned char code Temp[]={"Temp:"}; //说明显示的是温度
unsigned char code Cent[]={"Cent"}; //温度单位
sbit DS=P1^1;
sbit rs=P1^0;
sbit rw=P1^1;
sbit en=P1^2;
uchar TH,TL,TN,TD;
//uint temp;
//uchar code table[]={"temp"};
void delay(uint sum) //延时函数
uint i;
for(i=sum;i>0;i--)
_nop_();
void begin(void) //初始化
uint i=4;
DS=0;
delay(720);
DS=1;
while(i>0) i--;
void write(uchar dat) //写数据
uint i=0;
uchar j;
bit testb;
for(j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if(testb)
DS=0;
i++;i++;
DS=1;
delay(50);
else
DS=0;
delay(60);
DS=1;
i++;i++;
bit readbit(void) //读取一位
uint i;
bit dat;
DS=0;
i++;
DS=1;
i++;i++;
dat=DS;
delay(50);
return(dat);
uchar read(void) //读取一个字节
uint i;
uchar j,dat;
for(i=1;i<=8;i++)
j=readbit();
dat=(j<<7)|(dat>>1);
return(dat);
void wenduchange() //温度转换
begin();
delay(1);
write(0xcc);
write(0x44);
delay(100);
wendu() //读取温度数值
// float tempp;
begin();
delay(1);
write(0xcc);
write(0xbe);
// TL=read();
// TH=read();
// temp=TH;
// temp<<=8;
// temp=temp|TL;
// tempp=temp*0.0625;
// temp=tempp*10+0.5;
// return temp;
void write_date(uchar date)
rs=1;
rw=0;
P0=date;
delay(1000);
en=1;
delay(1000);
en=0;
void write_com(uint com)
rs=0;
rw=0;
P0=com;
delay(1000);
en=1;
delay(1000);
en=0;
void init()
en=0;
write_com(0x38);
write_com(0x0e);
write_com(0x06);
write_com(0x01);
// write_com(0x80+0x10);
void display_symbol(void) //显示温度字符
uint num;
write_com(0x80);
for(num=0;num<4;num++)
write_date(Temp[num]);
void display_cent(void) //显示温度单位
uint num;
write_com(0x80+0x0b);
write_date(Cent[num]);
void display_dot() //显示温度小数点
write_com(0x80+0x08);
write_date('.');
void display_temp1(uchar x) //显示温度整数部分
uchar j,k,l;
j=x/100;
k=(x%100)/10;
l=x%10;
write_com(0x80+0x05);
write_date(digit[j]);
write_date(digit[k]);
write_date(digit[l]);
delay(50000);
void display_temp2(uchar x) //显示温度小数部分
write_com(0x80+0x09);
write_date(digit[x]);
delay(1000);
void main()
// uchar TH,TL,TN,TD;
init();
delay(5000);
display_symbol();
display_dot();
display_cent();
while(1)
wenduchange();
wendu();
TL=read();
TH=read();
TN=TH*16+TL/16;
TD=(TL%16)*10/16;
display_temp1(TN); //显示温度的整数部分
display_temp2(TD); //显示温度的小数部分
delay(1000);
运行结果
刚刚学习温度检测并用1602液晶显示,调试时有警告“missing return value”,不知怎么改,求大神指导··········
