用CCS对一个信号进行FFT频谱分析后,怎么DA转换输出到示波器上观察
#include "math.h"
#define sample_1 256
#define signal_1_f 60
#define signal_2_f 200
#define signal_sample_f 512
#define pi 3.1415926
int input[sample_1];
float fwaver[sample_1],fwavei[sample_1],w[sample_1];
float sin_tab[sample_1];
float cos_tab[sample_1];
void init_fft_tab();
void input_data();
void fft(float datar[sample_1],float datai[sample_1]);
void main()
int i;
init_fft_tab();
input_data();
for (i=0;i<sample_1;i++)
fwaver[i]=input[i];
fwavei[i]=0.0f;
w[i]=0.0f;
fft(fwaver,fwavei);
while(1);
void init_fft_tab()
float wt1;
float wt2;
int i;
wt1=2*pi*i*signal_1_f;
wt1=wt1/signal_sample_f;
wt2=2*pi*i*signal_2_f;
wt2=wt2/signal_sample_f;
input[i]=(cos(wt1)+cos(wt2))/2*32768;
void input_data()
int i;
for(i=0;i<sample_1;i++)
sin_tab[i]=sin(2*pi*i/sample_1);
cos_tab[i]=cos(2*pi*i/sample_1);
int x0,x1,x2,x3,x4,x5,x6,x7,xx;
int i,j,k,b,p,L;
float TR,TI,temp;
x0=x1=x2=x3=x4=x5=x6=0;
x0=i&0x01;x1=(i/2)&0x01;x2=(i/4)&0x01;x3=(i/8)&0x01;
x4=(i/16)&0x01;x5=(i/32)&0x01;x6=(i/64)&0x01;x7=(i/128)&0x01;
xx=x0*128+x1*64+x2*32+x3*16+x4*8+x5*4+x6*2+x7;
datai[xx]=datar[i];
datar[i]=datai[i];datai[i]=0;
for(L=1;L<=8;L++)
b=1;i=L-1;
while(i>0)
b=b*2;i--;
for(j=0;j<=b-1;j++)
p=1;i=8-L;
while(i>0)
p=p*2;i--;
p=p*j;
for(k=j;k<256;k=k+2*b)
TR=datar[k];TI=datai[k];temp=datar[k+b];
datar[k]=datar[k]+datar[k+b]*cos_tab[p]+datai[k+b]*sin_tab[p];
datai[k]=datai[k]-datar[k+b]*sin_tab[p]+datai[k+b]*cos_tab[p];
datar[k+b]=TR-datar[k+b]*cos_tab[p]-datai[k+b]*sin_tab[p];
datai[k+b]=TI+temp*sin_tab[p]-datai[k+b]*cos_tab[p];
for(i=0;i<sample_1/2;i++)
w[i]=sqrt(datar[i]*datar[i]+datai[i]*datai[i]);
-f 0
-w
-stack 500
-sysstack 500
-l rts55.lib
MEMORY
DARAM: o=0x100, l=0x7f00
VECT:o=0x8000, l=0x100
DARAM2:o=0x8100,l=0x7f00
SARAM: o=0x10000,l=0x30000
SDRAM:o=0x40000,l=0x3e0000
SECTIONS
.text: {}>DARAM
.vectors: {}>VECT
.trcinit:{}>DARAM
.gblinit:{}>DARAM
.frt:{}>DARAM
.cinit:{}>DARAM
.pinit:{}>DARAM
.sysinit:{}>DARAM2
.far:{}>DARAM2
.const:{}>DARAM2
.switch:{}>DARAM2
.sysmem:{}>DARAM2
.cio:{}>DARAM2
.MEM$obj:{}>DARAM2
.sysheap:{}>DARAM2
.sysstack:{}>DARAM2
.stack:{}>DARAM2
.input:{}>DARAM2
.fftcode:{}>DARAM2
这个是一个fft.c,用的是C5510,CCS仿真已经可以了。请问怎么才能输出到示波器呢?如果您有时间,想请你帮我一下。
