电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » What is Soldermask? 什么是绿油
2014-06-12 10:32:31     打赏
The normally green coating used to protect the board and circuitry during the assembly and packaging operations. Among other things, the solder mask helps prevents solder bridges between adjacent pads and traces during the wave soldering process and oxidization of the copper traces. Liquid Photo-imageable (LPI) is our default process.
关键词: Solde
