| 符号及术语 SYMBOLS | |||
| Cj | …… | Junction Capacitance | 结电容 |
| ηv | …… | Rectification Efficiency | 整流效率 |
| I(AV) | …… | Average Forward Rectified Current | 正向平均整流电流 |
| IBO | …… | Breakover Current | 转折电流 |
| ID | …… | Stand-off Reverse Leakage Current | 关态反向漏电流 |
| IF | …… | DC Forward Current | 正向直流电流 |
| IFM | …… | Maximum DC Forward Current | 最大正向直流电流 |
| IFSM | …… | Peak Forward Surge Current | 正向浪涌峰值电流 |
| IFRM | …… | Repetitive Peak Forward Current | 正向重复峰值电流 |
| IH | …… | Holding Current | 维持电流 |
| IO | …… | Mean Forward Current | 正向平均电流 |
| IPPM | …… | Maximum Peak Impulse Current | 最大脉冲峰值电流 |
| Irr | …… | Reverse Recovery Current | 反向恢复电流 |
| IR | …… | Reverse Leakage Current | 反向漏电流 |
| IRM | …… | Maximum Reverse Leakage Current | 最大反向漏电流 |
| IRRM | …… | Repetitive Peak Reverse Current | 重复峰值反向电流 |
| IRSM | …… | Maximum Non-repetitive Reverse Peak Current | 最大反向不重复峰值电流 |
| ITRM | …… | Repetitive Peak On-state Current | 重复峰值开态电流 |
| ITSM | …… | Non Repetitive Surge Peak on-state Current | 不重复浪涌峰值开态电流 |
| IT | …… | Test Current | 测试电流 |
| I2T | …… | Rating for Fusing | 正向浪涌电流的平方对电流 |
| IRRM | …… | Peak Repetitive Reverse Current | 反向重复峰值电流 |
| IZ | …… | Zener Current | 齐纳电流 |
| IZM | …… | Maximum Zener Current | 最大齐纳电流 |
| PM(AV) | …… | Maximum Steady State Power Dissipation | 最大稳态功耗 |
| PPPM | …… | Peak Pulse Power Dissipation | 峰值脉冲功耗 |
| Ptot | …… | Total Power Dissipation | 总功耗 |
| Qrr | …… | Recovered Charge | 恢复电荷 |
| RθJA | …… | Thermal Resistance(Junction to Ambient) | 热阻(结到环境) |
| RθJC | …… | Thermal Resistance(Junction to Case) | 热阻(结到管壳) |
| RθJL | …… | Thermal Resistance(Junction to Lead) | 热阻(结到引线) |
| TA | …… | Ambient Temperature | 环境温度 |
| TC | …… | Case Temperature | 管壳温度 |
| Td | …… | Time Duration | 持续时间 |
| Tf | …… | Fall Time | 下降时间 |
| tfr | …… | Forward Recovery Time | 正向恢复时间 |
| Tj | …… | Junction Temperature | 结温 |
| TL | …… | Lead Temperature | 引线温度 |
| tr | …… | Rise Time | 上升时间 |
| trr | …… | Reverse Recovery Time | 反向恢复时间 |
| TP | …… | Pulse Duration | 脉冲持续时间 |
| TSTG | …… | Storage Temperature | 存储温度 |
| TT | …… | Temperature of the terminals (SMD) | 引线端的温度(SMD) |
| V(BR) | …… | Reverse Breakdown Voltage | 反向击穿电压 |
| VBO | …… | Breakover Voltage | 转折电压 |
| VC | …… | Clamping Voltage | 箝位电压 |
| VDC、 VR | …… | DC Reverse Voltage | 反向直流电压 |
| VF | …… | Forward Voltage | 正向电压 |
| VFM | …… | Maximum Forward Voltage | 最大正向电压 |
| VFR | …… | Forward Recovery Voltage | 正向恢复电压 |
| VISO | …… | Isolation Voltage | 绝缘电压 |
| VO | …… | Output Voltage | 输出电压 |
| VRM | …… | Maximum Recurrent Peak Reverse Voltage | 最大重复峰值反向电压 |
| VRMS | …… | RMS Input Voltage | 均方根输入电压 |
| VRRM | …… | Peak Repetitive Reverse Voltage | 反向重复峰值电压 |
| VRSM | …… | Maximum Non-Repetitive Peak Reverse Voltage | 最大反向不重复峰值电压 |
| VTM | …… | Peak On-state Voltage | 峰值开态电压 |
| VWM | …… | Working Stand-off Voltage | 关态工作电压 |
| VZ | …… | Zener Voltage | 齐纳电压 |
| ZZ | …… | Dynamic Zener Impedance | 动态齐纳阻抗 |
| ︱+VBO︱ - ︱VBO︱ | …… | Breakover Voltage Symmetry | 转折电压的对称性 |
| ︱±△ V ︱ | …… | Dynamic Breakover Voltage | 弹回电压(负阻) |
| αV(BR) | …… | Maximum Reverse Voltage Temperature Coefficient | 最大反向电压温度系数 |
| αVZ | …… | Temperature Coefficient of Zener Voltage | 齐纳电压的温度系数 |
| Duty Cycle (Ratio of pulse duration of full cycle) | 占空因数(由脉冲比率持续 时间制成的完整周期) | ||
共1条
电子技术中常用符号及术语
关键词: 电子
共1条
| 为遥控小车巧添功能被打赏¥26元 | |
