| 型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 |
| 2SB206 | GE-PNP | 80 V | 30 A | 80 W | - | - |
| 2SB324 | GE-PNP | 32 V | 1 A | 0,25 W | - | - |
| 2SB337 | GE-PNP | 50 V | 7 A | 30 W | - | - |
| 2SB407 | GE-PNP | 30 V | 7 A | 30 W | - | - |
| 2SB481 | GE-PNP | 32 V | 1 A | 6 W | 15 kHz | - |
| 2SB492 | GE-PNP | 25 V | 2 A | 6 W | - | - |
| 2SB511E | SI-PNP | 35 V | 1,5 A | 10 W | 8 MHz | - |
| 2SB524 | SI-PNP | 60 V | 1,5 A | 10 W | 70 MHz | - |
| 2SB527 | SI-PNP | 110 V | 0,8 A | 10 W | 70 MHz | - |
| 2SB531 | SI-PNP | 90 V | 6 A | 50 W | 8 MHz | - |
| 2SB536 | SI-PNP | 130 V | 1,5 A | 20 W | 40 MHz | - |
| 2SB537 | SI-PNP | 130 V | 1,5 A | 20 W | 60 MHz | - |
| 2SB541 | SI-PNP | 110 V | 8 A | 80 W | 9 MHz | - |
| 2SB544 | SI-PNP | 25 V | 1 A | 0,9 W | 180 MHz | - |
| 2SB546A | SI-PNP | 200 V | 2 A | 25 W | 5 MHz | - |
| 2SB549 | SI-PNP | 120 V | 0,8 A | 10 W | 80 MHz | - |
| 2SB557 | SI-PNP | 120 V | 8 A | 80 W | - | - |
| 2SB560 | SI-PNP | 100 V | 0,7 A | 0,9 W | 100 MHz | - |
| 2SB561 | SI-PNP | 25 V | 0,7 A | 0,5 W | - | - |
| 2SB564 | SI-PNP | 30 V | 1 A | 0,8 W | - | - |
| 2SB598 | SI-PNP | 25 V | 1 A | 0,5 W | 180 MHz | - |
| 2SB600 | SI-PNP | 200 V | 15 A | 200 W | 4 MHz | - |
| 2SB601 | P-DARL | 100 V | 5 A | 30 W | - | - |
| 2SB605 | SI-PNP | 60 V | 0,7 A | 0,8 W | 120 MHz | - |
| 2SB621 | SI-NPN | 25 V | 1,5 A | 0,6 W | 200 MHz | - |
| 2SB621A | SI-NPN | 50 V | 1 A | 0,75 W | 200 MHz | - |
| 2SB631 | SI-PNP | 100 V | 1 A | 8 W | - | - |
| 2SB632 | SI-PNP | 25 V | 2 A | 10 W | 100 MHz | - |
| 2SB633 | SI-PNP | 100 V | 6 A | 40 W | 15 MHz | - |
| 2SB637 | SI-PNP | 50 V | 0,1 A | 0,3 W | 200 MHz | - |
| 2SB641 | SI-PNP | 30 V | 0,1 A | - | 120 MHz | - |
| 2SB647 | SI-PNP | 120 V | 1 A | 0,9 W | 140 MHz | - |
| 2SB649A | SI-PNP | 160 V | 1,5 A | 1 W | 140 MHz | - |
| 2SB656 | SI-PNP | 160 V | 12 A | 125 W | 20 MHz | - |
| 2SB673 | P-DARL+D | 100 V | 7 A | 40 W | 0,8 us | - |
| 2SB676 | P-DARL | 100 V | 4 A | 30 W | 0,15 us | - |
| 2SB681 | SI-NPN | 150 V | 12 A | 100 W | 13 MHz | - |
| 2SB688 | SI-PNP | 120 V | 8 A | 80 W | 10 MHz | - |
| 2SB700 | SI-PNP | 160 V | 12 A | 100 W | - | - |
| 2SB703 | SI-PNP | 100 V | 4 A | 40 W | 18 MHz | - |
| 2SB705 | SI-PNP | 140 V | 10 A | 120 W | 17 MHz | - |
| 2SB707 | SI-PNP | 80 V | 7 A | 40 W | - | - |
| 2SB709 | SI-PNP | 45 V | 0,1 A | 0,2 W | 80 MHz | - |
| 2SB716 | SI-PNP | 120 V | 0,05 A | 0,75 W | - | - |
| 2SB720 | SI-PNP | 200 V | 2 A | 25 W | 100 MHz | - |
| 2SB727 | P-DARL+D | 120 V | 6 A | 50 W | - | - |
| 2SB731 | SI-PNP | 60 V | 1 A | 10 W | 75 MHz | - |
| 2SB733 | SI-PNP | 20 V | 2 A | 1 W | 50 MHz | - |
| 2SB734 | SI-PNP | 60 V | 1 A | 1 W | 80 MHz | - |
| 2SB739 | SI-PNP | 16 V | 2 A | 0,9 W | 80 MHz | - |
| 2SB740 | SI-PNP | 70 V | 1 A | 0,9 W | - | - |
| 2SB744 | SI-PNP | 70 V | 3 A | 10 W | 45 MHz | - |
| 2SB750 | P-DARL+D | 60 V | 2 A | 35 W | - | - |
| 2SB753 | SI-PNP | 100 V | 7 A | 40 W | 0,4 us | - |
| 2SB764 | SI-PNP | 60 V | 1 A | 0,9 A | 150 MHz | - |
| 2SB765 | P-DARL+D | 120 V | 3 A | 30 W | - | - |
| 2SB766 | SI-PNP | 30 V | 1 A | - | 200 MHz | - |
| 2SB772 | SI-PNP | 40 V | 3 A | 10 W | 80 MHz | - |
| 2SB774 | SI-PNP | 30 V | 0,1 A | 0,4 W | 150 MHz | - |
| 2SB775 | SI-PNP | 100 V | 6 A | 60 W | 13 MHz | - |
| 2SB776 | SI-PNP | 120 V | 7 A | 70 W | 15 MHz | - |
| 2SB788 | SI-PNP | 120 V | 0,02 A | 0,4 W | 150 MHz | - |
| 2SB791 | P-DARL+D | 120 V | 8 A | 40 W | - | - |
| 2SB794 | P-DARL+D | 60 V | 1,5 A | 10 W | - | - |
| 2SB795 | P-DARL+D | 80 V | 1,5 A | 10 W | - | - |
| 2SB808 | SI-PNP | 20 V | 0,7 A | 0,25 W | 250 MHz | - |
| 2SB810 | SI-PNP | 30 V | 0,7 A | 0,35 W | 160 MHz | - |
| 2SB815 | SI-PNP | 20 V | 0,7 A | 0,25 W | 250 MHz | - |
| 2SB816 | SI-PNP | 150 V | 8 A | 80 W | 15 MHz | - |
| 2SB817 | SI-PNP | 160 V | 12 A | 100 W | - | - |
| 2SB817F | SI-PNP | 160 V | 12 A | 90 W | 15 MHz | - |
| 2SB819 | SI-PNP | 50 V | 1,5 A | 1 W | 150 MHz | - |
| 2SB822 | SI-PNP | 40 V | 2 A | 0,75 W | 100 MHz | - |
| 2SB824 | SI-PNP | 60 V | 5 A | 30 W | 30 MHz | - |
| 2SB825 | SI-PNP | 60 V | 7 A | 40 W | 10 MHz | - |
| 2SB826 | SI-PNP | 60 V | 12 A | 40 W | 10 MHz | - |
| 2SB827 | SI-PNP | 60 V | 7 A | 80 W | 10 MHz | - |
| 2SB828 | SI-PNP | 60 V | 12 A | 80 W | 10 MHz | - |
| 2SB829 | SI-PNP | 60 V | 15 A | 90 W | 20 MHz | - |
| 2SB857 | SI-PNP | 50 V | 4 A | 40 W | - | - |
| 2SB861 | SI-PNP | 200 V | 2 A | 30 W | - | - |
| 2SB863 | SI-PNP | 140 V | 10 A | 100 W | 15 MHz | - |
| 2SB865 | P-DARL | 80 V | 1,5 A | 0,9 W | - | - |
| 2SB873 | SI-PNP | 30 V | 5 A | 1 W | 120 MHz | - |
| 2SB882 | P-DARL+D | 70 V | 10 A | 40 W | - | - |
| 2SB883 | P-DARL+D | 70 V | 15 A | 70 W | - | - |
| 2SB884 | P-DARL | 110 V | 3 A | 30 W | - | - |
| 2SB885 | P-DARL+D | 110 V | 3 A | 35 W | - | - |
| 2SB891 | SI-PNP | 40 V | 2 A | 5 W | 100 MHz | - |
| 2SB892 | SI-PNP | 60 V | 2 A | 1 W | - | - |
| 2SB895A | P-DARL | 60 V | 1 A | - | - | |
| 2SB897 | P-DARL+D | 100 V | 10 A | 80 W | - | - |
| 2SB908 | P-DARL+D | 80 V | 4 A | 15 W | 0,15 us | - |
| 2SB909 | SI-PNP | 40 V | 1 A | 1 W | 150 MHz | - |
| 2SB922 | SI-PNP | 120 V | 12 A | 80 W | 20 MHz | - |
| 2SB926 | SI-PNP | 30 V | 2 A | 0,75 W | - | - |
| 2SB938A | P-DARL+D | 60 V | 4 A | 40 W | - | - |
| 2SB940 | SI-PNP | 200 V | 2 A | 35 W | 30 MHz | - |
| 2SB941 | SI-PNP | 60 V | 3 A | 35 W | - | - |
| 2SB945 | SI-PNP | 130 V | 5 A | 40 W | 30 MHz | - |
| 2SB946 | SI-PNP | 130 V | 7 A | 40 W | 30 MHz | - |
| 2SB950A | P-DARL+D | 80 V | 4 A | 40 W | - | - |
| 2SB953A | SI-PNP | 50 V | 7 A | 30 W | 150 MHz | - |
| 2SB955 | P-DARL+D | 120 V | 10 A | 50 W | - | - |
| 2SB975 | P-DARL+D | 100 V | 8 A | 40 W | - | - |
| 2SB976 | SI-PNP | 27 V | 5 A | 0,75 W | 120 MHz | - |
| 2SB985 | SI-PNP | 60 V | 3 A | 1 W | 150 MHz | - |
| 2SB986 | SI-PNP | 60 V | 4 A | 10 W | 150 MHz | - |
| 2SB988 | SI-PNP | 60 V | 3 A | 30 W | 400 MHz | - |
| 2SB1009 | SI-PNP | 40 V | 2 A | 10 W | 100 MHz | - |
| 2SB1010 | SI-PNP | 40 V | 2 A | 0,75 W | 100 MHz | - |
| 2SB1012K | P-DARL | 120 V | 1,5 A | 8 W | - | - |
| 2SB1013 | SI-PNP | 20 V | 2 A | 0,7 W | - | - |
| 2SB1015 | SI-PNP | 60 V | 3 A | 25 W | 0,4 us | - |
| 2SB1016 | SI-PNP | 100 V | 5 A | 30 W | 5 MHz | - |
| 2SB1017 | SI-PNP | 80 V | 4 A | 25 W | 9 MHz | - |
| 2SB1018 | SI-PNP | 100 V | 7 A | 30 W | 0,4 us | - |
| 2SB1020 | P-DARL+D | 100 V | 7 A | 30 W | 0,8 us | - |
| 2SB1023 | P-DARL+D | 60 V | 3 A | 20 W | - | - |
| 2SB1035 | SI-PNP | 30 V | 1 A | 0,9 W | 100 MHz | - |
| 2SB1039 | SI-PNP | 100 V | 4 A | 40 W | 20 MHz | - |
| 2SB1050 | SI-PNP | 30 V | 5 A | 1 W | 120 MHz | - |
| 2SB1055 | SI-PNP | 120 V | 6 A | 70 W | 20 MHz | - |
| 2SB1065 | SI-PNP | 60 V | 3 A | 10 W | - | - |
| 2SB1066 | SI-PNP | 50 V | 3 A | 1 W | 70 MHz | - |
| 2SB1068 | SI-PNP | 20 V | 2 A | 0,75 W | 180 MHz | - |
| 2SB1071 | SI-PNP | 40 V | 4 A | 25 W | 150 MHz | - |
| 2SB1077 | P-DARL | 60 V | 4 A | 40 W | - | - |
| 2SB1086 | SI-PNP | 160 V | 1,5 A | 20 W | 50 MHz | - |
| 2SB1098 | P-DARL+D | 100 V | 5 A | 20 W | - | - |
| 2SB1099 | P-DARL+D | 100 V | 8 A | 25 W | - | - |
| 2SB1100 | P-DARL+D | 100 V | 10 A | 30 W | - | - |
| 2SB1109 | SI-PNP | 160 V | 0,1 A | 1,25 W | - | - |
| 2SB1109S | SI-PNP | 160 V | 0,1 A | 1,25 W | - | - |
| 2SB1117 | SI-PNP | 30 V | 3 A | 1 W | 280 MHz | - |
| 2SB1120 | SI-PNP | 20 V | 2,5 A | 0,5 W | 250 MHz | - |
| 2SB1121T | SI-PNP | 30 V | 2 A | - | 150 MHz | - |
| 2SB1123 | SI-PNP | 60 V | 2 A | 0,5 W | 150 MHz | - |
| 2SB1132 | SI-PNP | 40 V | 1 A | 0,5 W | 150 MHz | - |
| 2SB1133 | SI-PNP | 60 V | 3 A | 25 W | 40 MHz | - |
| 2SB1134 | SI-PNP | 60 V | 5 A | 25 W | 30 W | - |
| 2SB1135 | SI-PNP | 60 V | 7 A | 30 W | 10 MHz | - |
| 2SB1136 | SI-PNP | 60 V | 12 A | 30 W | 10 MHz | - |
| 2SB1140 | SI-PNP | 25 V | 5 A | 10 W | 320 MHz | - |
| 2SB1141 | SI-PNP | 20 V | 1,2 A | 10 W | 150 MHz | - |
| 2SB1143 | SI-PNP | 60 V | 4 A | 10 W | 140 MHz | - |
| 2SB1146 | P-DARL | 120 V | 6 A | 25 W | - | - |
| 2SB1149 | P-DARL | 100 V | 3 A | 15 W | - | - |
| 2SB1151 | SI-PNP | 60 V | 5 A | 20 W | - | - |
| 2SB1154 | SI-PNP | 130 V | 10 A | 70 W | 30 MHz | - |
| 2SB1156 | SI-PNP | 130 V | 20 A | 100 W | - | - |
| 2SB1162 | SI-PNP | 160 V | 12 A | 120 W | - | - |
| 2SB1163 | SI-PNP | 170 V | 15 A | 150 W | - | - |
| 2SB1166 | SI-PNP | 60 V | 8 A | 20 W | 130 MHz | - |
| 2SB1168 | SI-PNP | 120 V | 4 A | 20 W | 130 MHz | - |
| 2SB1182 | SI-PNP | 40 V | 2 A | 10 W | 100 MHz | - |
| 2SB1184 | SI-PNP | 60 V | 3 A | 15 W | 70 MHz | - |
| 2SB1185 | SI-PNP | 50 V | 3 A | 25 W | 70 MHz | - |
| 2SB1186 | SI-PNP | 120 V | 1,5 A | 20 W | 50 MHz | - |
| 2SB1187 | SI-PNP | 80 V | 3 A | 35 W | - | - |
| 2SB1188 | SI-PNP | 40 V | 2 A | - | 100 MHz | - |
| 2SB1202 | SI-PNP | 60 V | 3 A | 15 W | 150 MHz | - |
| 2SB1203 | SI-PNP | 60 V | 5 A | 20 W | 130 MHz | - |
| 2SB1204 | SI-PNP | 60 V | 8 A | 20 W | 130 MHz | - |
| 2SB1205 | SI-PNP | 25 V | 5 A | 10 W | 320 MHz | - |
| 2SB1212 | SI-PNP | 160 V | 1,5 A | 0,9 W | 50 MHz | - |
| 2SB1223 | P-DARL+D | 70 V | 4 A | 20 W | 20 MHz | - |
| 2SB1236 | SI-PNP |
关键词: 日本晶体 参数大全 共1条
回复 |
共1条
