| 型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 |
| 2SD92 | SI-NPN | 100 V | 3 A | 20 W | - | - |
| 2SD155 | SI-NPN | 80 V | 3 A | 25 W | - | - |
| 2SD198 | SI-NPN | 300 V | 1 A | 25 W | 45 MHz | - |
| 2SD200 | SI-NPN | 1500 V | 2,5 A | 10 W | - | - |
| 2SD213 | SI-NPN | 110 V | 10 A | 100 W | - | - |
| 2SD234 | SI-NPN | 60 V | 3 A | 25 W | - | - |
| 2SD287 | SI-NPN | 200 V | 10 A | 100 W | 8 MHz | - |
| 2SD313 | SI-NPN | 60 V | 3 A | 30 W | 8 MHz | - |
| 2SD325 | SI-NPN | 35 V | 1,5 A | 10 W | 8 MHz | - |
| 2SD350 | SI-NPN | 1500 V | 5 A | 22 W | - | - |
| 2SD350A | SI-NPN | 1500 V | 5 A | 22 W | - | - |
| 2SD359 | SI-NPN | 40 V | 2 A | 10 W | - | - |
| 2SD361 | SI-NPN | 60 V | 1,5 A | 10 W | 70 MHz | - |
| 2SD381 | SI-NPN | 130 V | 1,5 A | 20 W | 60 MHz | - |
| 2SD382 | SI-NPN | 130 V | 1,5 A | 20 W | 60 MHz | - |
| 2SD386 | SI-NPN | 200 V | 3 A | 25 W | 8 MHz | - |
| 2SD400 | SI-NPN | 25 V | 1 A | 0,9 W | - | - |
| 2SD401 | SI-NPN | 200 V | 2 A | 20 W | 10 MHz | - |
| 2SD414 | SI-NPN | 80 V | 0,8 A | 10 W | - | - |
| 2SD415 | SI-NPN | 100 V | 0,8 A | 10 W | - | - |
| 2SD424 | SI-NPN | 160 V | 15 A | 150 W | - | - |
| 2SD438 | SI-NPN | 100 V | 0,7 A | 0,9 W | 100 MHz | - |
| 2SD467 | SI-NPN | 25 V | 0,7 A | 0,5 W | 280 MHz | - |
| 2SD468 | SI-NPN | 25 V | 1 A | 0,9 W | 280 MHz | - |
| 2SD471 | SI-NPN | 30 V | 1 A | 0,8 W | - | - |
| 2SD476 | SI-NPN | 70 V | 4 A | 40 W | 7 MHz | - |
| 2SD478 | SI-NPN | 200 V | 2 A | 30 W | - | - |
| 2SD545 | SI-NPN | 25 V | 1,5 A | 0,5 W | - | - |
| 2SD549 | N-DARL | 30 V | 1,5 A | 15 W | - | - |
| 2SD552 | SI-NPN | 220 V | 15 A | 150 W | 4 MHz | - |
| 2SD553 | SI-NPN | 70 V | 7 A | 40 W | 10 MHz | - |
| 2SD555 | SI-NPN | 400 V | 15 A | 200 W | 7 MHz | - |
| 2SD556 | SI-NPN | 120 V | 15 A | 120 W | 8 MHz | - |
| 2SD560 | N-DARL | 100 V | 5 A | 30 W | - | - |
| 2SD571 | SI-NPN | 60 V | 700 mA | 1 W | 110 MHz | - |
| 2SD592 | SI-NPN | 30 V | 1 A | 0,75 W | 200 MHz | - |
| 2SD596 | SI-NPN | 30 V | 0,7 A | 170 MHz | - | - |
| 2SD600K | SI-NPN | 120 V | 1 A | 8 W | - | - |
| 2SD602A | SI-NPN | 60 V | 0,5 A | 0,2 W | 200 MHz | - |
| 2SD612 | SI-NPN | 25 V | 2 A | 10 W | 100 MHz | - |
| 2SD613 | SI-NPN | 100 V | 6 A | 40 W | 15 MHz | - |
| 2SD617 | N-DARL | 120 V | 8 A | 100 W | - | - |
| 2SD637 | SI-NPN | 60 V | 0,1 A | 0,4 W | 150 MHz | - |
| 2SD661 | SI-NPN | 35 V | 0,1 A | 0,4 W | 200 MHz | - |
| 2SD662 | SI-NPN | 250 V | 0,1 A | 0,6 W | 50 MHz | - |
| 2SD666 | SI-NPN | 120 V | 0,05 A | - | 140 MHz | - |
| 2SD667 | SI-NPN | 120 V | 1 A | - | 140 MHz | - |
| 2SD669A | SI-NPN | 160 V | 1,5 A | 1 W | 140 MHz | - |
| 2SD676 | SI-NPN | 160 V | 12 A | 125 W | 8 MHz | - |
| 2SD712 | SI-NPN | 100 V | 4 A | 30 W | 8 MHz | - |
| 2SD717 | SI-NPN | 70 V | 10 A | 80 W | 0,3 us | - |
| 2SD718 | SI-NPN | 120 V | 8 A | 80 W | 12 MHz | - |
| 2SD725 | SI-NPN | 1500 V | 6 A | 50 W | - | - |
| 2SD726 | SI-NPN | 100 V | 4 A | 40 W | 10 MHz | - |
| 2SD731 | SI-NPN | 170 V | 7 A | 80 W | 7 MHz | - |
| 2SD732 | SI-NPN | 150 V | 8 A | 80 W | 15 MHz | - |
| 2SD734 | SI-NPN | 25 V | 0,7 A | 0,6 W | 250 MHz | - |
| 2SD762 | SI-NPN | 60 V | 3 A | 25 W | 25 kHz | - |
| 2SD763 | SI-NPN | 120 V | 1 A | 0,9 W | - | - |
| 2SD768 | N-DARL+D | 120 V | 6 A | 40 W | - | - |
| 2SD773 | SI-NPN | 20 V | 2 A | 1 W | 110 MHz | - |
| 2SD774 | SI-NPN | 100 V | 1 A | 1 W | 95 MHz | - |
| 2SD781 | SI-NPN | 150 V | 2 A | 1 W | 0,6 us | - |
| 2SD786 | SI-NPN | 40 V | 0,3 A | 0,25 W | - | - |
| 2SD787 | SI-NPN | 20 V | 2 A | 0,9 W | 80 MHz | - |
| 2SD788 | SI-NPN | 20 V | 2 A | 0,9 W | 100 MHz | - |
| 2SD789 | SI-NPN | 50 V | 1 A | 0,9 W | 80 MHz | - |
| 2SD794 | SI-NPN | 70 V | 3 A | 10 W | 60 MHz | - |
| 2SD795 | SI-NPN | 40 V | 3 A | 20 W | 95 MHz | - |
| 2SD798 | N-DARL | 600 V | 6 A | 30 W | - | - |
| 2SD799 | N-DARL+D | 400 V | 6 A | 30 W | - | - |
| 2SD800 | SI-NPN | 750 V | 4 A | 30 W | 8 MHz | - |
| 2SD809 | SI-NPN | 100 V | 1 A | 10 W | 85 MHz | - |
| 2SD819 | SI-NPN | 1500 V | 3,5 A | 50 W | - | - |
| 2SD820 | SI-NPN | 1500 V | 5 A | 50 W | - | - |
| 2SD822 | SI-NPN | 600 V | 7 A | 50 W | - | - |
| 2SD826 | SI-NPN | 60 V | 5 A | 10 W | 120 MHz | - |
| 2SD829 | N-DARL+D | 150 V | 15 A | 100 W | - | - |
| 2SD837 | N-DARL | 60 V | 4 A | 40 W | - | - |
| 2SD844 | SI-NPN | 50 V | 7 A | 60 W | 15 MHz | - |
| 2SD850 | SI-NPN | 1500 V | 3 A | 25 W | - | - |
| 2SD856 | SI-NPN | 60 V | 3 A | 35 W | - | - |
| 2SD863 | SI-NPN | 50 V | 1 A | 0,9 W | - | - |
| 2SD864K | N-DARL+D | 120 V | 3 A | 30 W | - | - |
| 2SD867 | SI-NPN | 130 V | 10 A | 100 W | 3 MHz | - |
| 2SD871 | SI-N+D | 1500 V | 5 A | 50 W | - | - |
| 2SD879 | SI-NPN | 30 V | 3 A | 0,75 W | 200 MHz | - |
| 2SD880 | SI-NPN | 60 V | 3 A | 30 W | 0,8 us | - |
| 2SD882 | SI-NPN | 30 V | 3 A | 10 W | - | - |
| 2SD889 | SI-N+D | 1500 V | 4 A | 50 W | - | - |
| 2SD892A | N-DARL | 60 V | 0,5 A | 0,4 W | - | - |
| 2SD894 | N-DARL | 30 V | 1,5 A | 10 W | 120 MHz | - |
| 2SD895 | SI-NPN | 100 V | 6 A | 60 W | 10 MHz | - |
| 2SD917 | SI-NPN | 330 V | 7 A | 70 W | - | - |
| 2SD921 | N-DARL | 200 V | 5 A | 80 W | - | - |
| 2SD946 | N-DARL | 30 V | 1 A | - | - | - |
| 2SD947 | N-DARL | 40 V | 2 A | 5 W | 150 MHz | - |
| 2SD951 | SI-NPN | 1500 V | 3 A | 65 W | - | - |
| 2SD958 | SI-NPN | 120 V | 0,02 A | 0,4 W | 200 MHz | - |
| 2SD965 | SI-NPN | 40 V | 5 A | 0,75 W | 150 MHz | - |
| 2SD966 | SI-NPN | 40 V | 5 A | 1 W | 150 MHz | - |
| 2SD968A | SI-NPN | 120 V | 0,5 A | 1 W | 120 MHz | - |
| 2SD970 | N-DARL+D | 120 V | 8 A | 40 W | - | - |
| 2SD972 | N-DARL | 50 V | 4 A | 30 W | - | - |
| 2SD982 | N-DARL | 200 V | 5 A | 40 W | - | - |
| 2SD986 | N-DARL | 80 V | 1,5 A | 10 W | - | - |
| 2SD998 | N-DARL | 100 V | 1,5 A | 10 W | - | - |
| 2SD1010 | SI-NPN | 50 V | 50 mA | 0,3 W | 200 MHz | - |
| 2SD1012 | SI-NPN | 20 V | 0,7 A | 0,25 W | 250 MHz | - |
| 2SD1018 | SI-NPN | 250 V | 4 A | 80 W | - | - |
| 2SD1027 | N-DARL+D | 20 V | 15 A | 100 W | - | - |
| 2SD1033 | SI-NPN | 200 V | 2 A | 20 W | 10 MHz | - |
| 2SD1036 | SI-NPN | 120 V | 15 A | 150 W | - | - |
| 2SD1047 | SI-NPN | 160 V | 12 A | 100 W | 15 MHz | - |
| 2SD1048 | SI-NPN | 20 V | 0,7 A | 0,25 W | 250 MHz | - |
| 2SD1049 | SI-NPN | 120 V | 25 A | 100 W | - | - |
| 2SD1051 | SI-NPN | 50 V | 1,5 A | 1 W | 150 MHz | - |
| 2SD1055 | SI-NPN | 40 V | 2 A | 0,75 W | 100 MHz | - |
| 2SD1062 | SI-NPN | 60 V | 12 A | 40 W | 10 MHz | - |
| 2SD1064 | SI-NPN | 60 V | 12 A | 80 W | - | - |
| 2SD1065 | SI-NPN | 60 V | 15 A | 90 W | - | - |
| 2SD1073 | N-DARL | 300 V | 4 A | 40 W | - | - |
| 2SD1088 | N-DARL | 300 V | 6 A | 30 W | - | - |
| 2SD1113K | N-DARL+D | 300 V | 6 A | 40 W | - | - |
| 2SD1128 | N-DARL | 150 V | 5 A | 30 W | - | - |
| 2SD1135 | SI-NPN | 80 V | 4 A | 40 W | - | - |
| 2SD1138 | SI-NPN | 200 V | 2 A | 30 W | - | - |
| 2SD1140 | N-DARL | 30 V | 1,5 A | 0,9 W | - | - |
| 2SD1145 | SI-NPN | 60 V | 5 A | 0,9 W | 120 MHz | - |
| 2SD1148 | SI-NPN | 140 V | 10 A | 100 W | 20 MHz | - |
| 2SD1153 | SI-NPN | 80 V | 1,5 A | 0,9 W | - | - |
| 2SD1163A | SI-NPN | 300 V | 7 A | 40 W | - | - |
| 2SD1164 | SI-NPN | 150 V | 1,5 A | 10 W | - | - |
| 2SD1173 | SI-N+D | 1500 V | 5 A | 70 W | - | - |
| 2SD1187 | SI-NPN | 100 V | 10 A | 80 W | 10 MHz | - |
| 2SD1189 | SI-NPN | 40 V | 2 A | 5 W | 100 MHz | - |
| 2SD1192 | N-DARL+D | 70 V | 10 A | 40 W | - | - |
| 2SD1196 | N-DARL+D | 110 V | 8 A | 40 W | - | - |
| 2SD1198 | N-DARL | 30 V | 1 A | 1 W | 150 MHz | - |
| 2SD1207 | SI-NPN | 60 V | 2 A | 1 W | - | - |
| 2SD1210 | N-DARL+D | 150 V | 10 A | 80 W | - | - |
| 2SD1213 | SI-NPN | 60 V | 20 A | 50 W | - | - |
| 2SD1225 | SI-NPN | 40 V | 1 A | 1 W | 150 MHz | - |
| 2SD1238 | SI-NPN | 120 V | 12 A | 80 W | 20 MHz | - |
| 2SD1244 | SI-N+D | 900 V | 1 A | 50 W | - | - |
| 2SD1246 | SI-NPN | 30 V | 2 A | 0,75 W | - | - |
| 2SD1247 | SI-NPN | 30 V | 2,5 A | 1 W | - | - |
| 2SD1254 | SI-NPN | 130 V | 3 A | 30 W | - | - |
| 2SD1255 | SI-NPN | 130 V | 4 A | 35 W | 30 MHz | - |
| 2SD1263A | SI-NPN | 400 V | 0,75 A | 35 W | 30 MHz | - |
| 2SD1264 | SI-NPN | 200 V | 2 A | 30 W | - | - |
| 2SD1265 | SI-NPN | 60 V | 4 A | 30 W | 25 kHz | - |
| 2SD1266 | SI-NPN | 60 V | 3 A | 35 W | - | - |
| 2SD1267 | SI-NPN | 60 V | 4 A | 40 W | 20 MHz | - |
| 2SD1270 | SI-NPN | 130 V | 5 A | 2 W | 30 MHz | - |
| 2SD1271 | SI-NPN | 130 V | 7 A | 40 W | 30 MHz | - |
| 2SD1272 | SI-NPN | 200 V | 1 A | 40 W | 25 MHz | - |
| 2SD1273 | SI-NPN | 80 V | 3 A | 40 W | 50 MHz | - |
| 2SD1274 | SI-NPN | 150 V | 5 A | 40 W | 40 MHz | - |
| 2SD1276 | N-DARL | 60 V | 4 A | 40 W | - | - |
| 2SD1286 | N-DARL+D | 60 V | 1 A | 8 W | - | - |
| 2SD1288 | SI-NPN | 120 V | 7 A | 70 W | - | - |
| 2SD128
关键词: 日本晶体 参数大全 共1条
回复 |
共1条
