电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » LCD1602 作业
共5条 1/1 1 跳转至页
LCD1602 作业
2014-06-30 22:32:26     打赏
交一下LCD1602的作业。
这次学到了不少,刚开始自己听完课之后,看着数据手册,写完了代码,慢慢编译过来,成功了一大部分,最后的两个状态转换搞错了,后来跟51FPGA 大神的源代码进行比较,根据他的正确代码一点点纠正状态机的源代码,结果,跟51FPGA 大大的几乎一样了。不过还是学到了很多。
以下是源代码:
`timescale 1ns / 1ps
// Company:
// Engineer: Charles Wang
// Create Date:    06/23/2014
// Design Name: 	lcd1602_clock
// Module Name:   lcd1602_clock
// Project Name: 	lcd1602_clock
// Target Devices: EP4CE6E22C8
// Tool versions: Quartus II 13.1
// Description: 用LCD1602显示数字时钟
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module lcd1602_clock(clk,rst_n,lcd_en,lcd_rs,lcd_rw,lcd_data);
input clk;
input rst_n;
output lcd_en;
output lcd_rs;
output lcd_rw;
output [7:0]lcd_data;
reg lcd_rs;
reg [7:0]lcd_data;
reg clk_div;
reg [4:0]char_cnt;
reg [9:0]state;
reg [17:0]delay_cnt;
reg [7:0]lcd_data_r;
parameter	idle 				=10'b00_0000_0001,
				clear				=10'b00_0000_0010,
				set_function	=10'b00_0000_0100,
				switch_mode		=10'b00_0000_1000,
				set_mode			=10'b00_0001_0000,
				shift				=10'b00_0010_0000,
				set_ddram1		=10'b00_0100_0000,
				set_ddram2		=10'b00_1000_0000,
				write_ddram1	=10'b01_0000_0000,
				write_ddram2	=10'b10_0000_0000;
assign lcd_en = clk_div;
assign lcd_rw = 1'b0;
always@(posedge clk or negedge rst_n)
	begin
		if(!rst_n)
			begin
				delay_cnt <= 18'h0;
				clk_div	 <= 1'b0;
			end
		else if(delay_cnt == 18'd249999)
			begin
				delay_cnt <= 18'h0;
				clk_div	 <= ~ clk_div;
			end
		else
			begin
				delay_cnt <= delay_cnt + 1'b1;
				clk_div	 <= clk_div;
			end
	end
always@(posedge clk_div or negedge rst_n)//状态机模块
	begin
		if(!rst_n)
			begin
				state <= idle;
				char_cnt<= 5'd0;
			end
		else
			case(state)
				idle: 									//起始状态
					begin
						lcd_data	<=	8'bzzzz_zzzz;
						state		<=	clear;
					end
				clear:									//清屏
					begin
						lcd_rs	<=	1'b0;
						lcd_data	<=	8'b0000_0001;
						state 	<=	set_function;
					end
				set_function:							//功能设置:8位数据接口/2行显示/5*8点阵字符
					begin
						lcd_rs	<=	1'b0;
						lcd_data	<=	8'b0011_1000;
						state		<=	switch_mode;
					end
				switch_mode:							//开关模式:开显示,关闭光标和闪烁
					begin
						lcd_rs	<=	1'b0;
						lcd_data	<=	8'b0000_1100;
						state		<=	set_mode;
					end
				set_mode:								//输入方式:数据读写操作后,地址自动加一/画面不动
					begin
						lcd_rs	<= 1'b0;
						state 	<= shift;
						lcd_data <= 8'b0000_0110;
					end
				shift:
					begin
						lcd_rs	<=	1'b0;
						lcd_data	<=	8'b0001_0000;
						state		<=	set_ddram1;
					end
				set_ddram1:
					begin
						lcd_rs	<=	1'b0;
						lcd_data	<=	8'b1000_0000;
						state		<=	write_ddram1;
					end
				set_ddram2:
					begin
						lcd_rs	<=	1'b0;
						lcd_data	<=	8'b1100_0000;
						state		<=	write_ddram2;
					end
				write_ddram1:
					begin
						if(char_cnt	<=	5'd15)
							begin
								lcd_rs	<=	1'b1;
								char_cnt	<=	char_cnt +	1'b1;
								lcd_data	<=	lcd_data_r;
							end
						else
							state	<=	set_ddram2;
					end
				write_ddram2:
					begin
						if(char_cnt	<=	5'd30)
							begin
								lcd_rs	<=	1'b1;
							end
						else
							begin
								char_cnt <= 5'd0;
								state	<=	shift;
							end
					end
				default:
					state	<=	idle;
			endcase
	end
always@(char_cnt)										//显示相关字符
	begin
		case(char_cnt)
			5'd0:			lcd_data_r	<=	"D";
			5'd1:			lcd_data_r	<=	"e";
			5'd2:			lcd_data_r	<=	"s";
			5'd3:			lcd_data_r	<=	"i";
			5'd4:			lcd_data_r	<=	"g";
			5'd5:			lcd_data_r	<=	"n";
			5'd6:			lcd_data_r	<=	" ";
			5'd7:			lcd_data_r	<=	"b";
			5'd8:			lcd_data_r	<=	"y";
			5'd9:			lcd_data_r	<=	" ";
			5'd10:		lcd_data_r	<=	"C";
			5'd11:		lcd_data_r	<=	"h";
			5'd12:		lcd_data_r	<=	"a";
			5'd13:		lcd_data_r	<=	"r";
			5'd14:		lcd_data_r	<=	"l";
			5'd15:		lcd_data_r	<=	"e";
			5'd16:		lcd_data_r	<=	" ";
			5'd17:		lcd_data_r	<=	"T";
			5'd18:		lcd_data_r	<=	"i";
			5'd19:		lcd_data_r	<=	"m";
			5'd20:		lcd_data_r	<=	"e";
			5'd21:		lcd_data_r	<=	":";
			5'd22:		lcd_data_r	<=	" ";
			5'd23:		lcd_data_r	<=	hour_reg_dec_char;
			5'd24:		lcd_data_r	<=	hour_reg_bit_char;
			5'd25:		lcd_data_r	<=	"-";
			5'd26:		lcd_data_r	<=	minu_reg_dec_char;
			5'd27:		lcd_data_r	<=	minu_reg_bit_char;
			5'd28:		lcd_data_r	<=	"-";
			5'd29:		lcd_data_r	<=	sec_reg_dec_char;
			5'd30:		lcd_data_r	<=	sec_reg_bit_char;
			default:		lcd_data_r	<= "";
		endcase
	end
reg 	[2:0]sec_reg_dec;//秒的十位
reg	[3:0]sec_reg_bit;//秒的个位
reg 	[2:0]minu_reg_dec;//分的十位
reg	[3:0]minu_reg_bit;//分的个位
reg	[3:0]hour_reg_dec;//小时的十位
reg	[1:0]hour_reg_bit;//小时的个位
reg 	[27:0]delay_cnt_clock;//数字时钟计数器分频寄存器
always@(posedge clk or negedge rst_n)//数字时钟计数器分频模块,50MHz → 1Hz
	begin
		if(!rst_n)
			delay_cnt_clock <= 28'h0000000;
		else if(delay_cnt_clock == 28'd49999999)
			delay_cnt_clock <= 28'd0;
		else
			delay_cnt_clock <= delay_cnt_clock + 1'b1;
	end
always@(posedge clk or negedge rst_n)//数字时钟模块
	begin
		if(!rst_n)
			begin
				sec_reg_bit	<=	4'd0;
				sec_reg_dec	<=	3'd0;
				minu_reg_bit<=	4'd0;
				minu_reg_dec<=	3'd0;
				hour_reg_bit<=	4'd0;
				hour_reg_dec<=	2'd0;
			end
			begin
				if(sec_reg_bit == 4'd9 && sec_reg_dec == 3'd5)
					begin
						if(hour_reg_bit == 4'd3 && hour_reg_dec == 2'd2 && minu_reg_bit == 4'd9
						&& minu_reg_dec == 3'd5)
							begin
							end
						else if(hour_reg_bit == 4'd9 && hour_reg_dec < 2'd2 && minu_reg_bit == 4'd9
							begin
								hour_reg_dec <= hour_reg_dec + 1'b1;
							end
						else if(hour_reg_bit <4'd9 && minu_reg_bit == 4'd9 && minu_reg_dec == 3'd5)
							begin
								hour_reg_bit <= hour_reg_bit + 1'b1;
								hour_reg_dec <= hour_reg_dec;
							end
						else if(minu_reg_bit == 4'd9 && minu_reg_dec < 3'd5)
							begin
								minu_reg_dec<=	minu_reg_dec + 1'b1;
								hour_reg_bit<= hour_reg_bit;
								hour_reg_dec<= hour_reg_dec;
							end
						else if(minu_reg_bit < 4'd9)
							begin
								minu_reg_bit<=	minu_reg_bit + 1'b1;
								minu_reg_dec<=	minu_reg_dec;
							end
					end
				else if(sec_reg_bit == 4'd9 && sec_reg_dec < 3'd5)
					begin
						sec_reg_dec	<=	sec_reg_dec + 1'b1;
						minu_reg_bit<=	minu_reg_bit;
					end
				else
					begin
						sec_reg_bit	<=	sec_reg_bit + 1'b1;
						sec_reg_dec	<=	sec_reg_dec;
					end
			end
		else
			begin
				sec_reg_bit	<=	sec_reg_bit;
			end
	end
//将数字时钟的秒、分、时以字符的形式显示在LCD屏幕上
reg[7:0] sec_reg_bit_char;
reg[7:0] sec_reg_dec_char;
reg[7:0] minu_reg_bit_char;
reg[7:0] minu_reg_dec_char;
reg[7:0] hour_reg_bit_char;
reg[7:0] hour_reg_dec_char;
always@(sec_reg_bit)
	begin
		case(sec_reg_bit)
			4'd0: sec_reg_bit_char <= "0";
			4'd1: sec_reg_bit_char <= "1";
			4'd2: sec_reg_bit_char <= "2";
			4'd3: sec_reg_bit_char <= "3";
			4'd4: sec_reg_bit_char <= "4";
			4'd5: sec_reg_bit_char <= "5";
			4'd6: sec_reg_bit_char <= "6";
			4'd7: sec_reg_bit_char <= "7";
			4'd8: sec_reg_bit_char <= "8";
			4'd9: sec_reg_bit_char <= "9";
			default:sec_reg_bit_char <= sec_reg_bit_char;
		endcase
	end
always@(sec_reg_dec)
	begin
		case(sec_reg_dec)
			3'd0: sec_reg_dec_char <= "0";
			3'd1: sec_reg_dec_char <= "1";
			3'd2: sec_reg_dec_char <= "2";
			3'd3: sec_reg_dec_char <= "3";
			3'd4: sec_reg_dec_char <= "4";
			3'd5: sec_reg_dec_char <= "5";
			default:sec_reg_dec_char <= "0";
		endcase
	end
always@(minu_reg_bit)
	begin
		case(minu_reg_bit)
			4'd0:	minu_reg_bit_char <= "0";
			4'd1:	minu_reg_bit_char <= "1";
			4'd2:	minu_reg_bit_char <= "2";
			4'd3:	minu_reg_bit_char <= "3";
			4'd4:	minu_reg_bit_char <= "4";
			4'd5:	minu_reg_bit_char <= "5";
			4'd6:	minu_reg_bit_char <= "6";
			4'd7:	minu_reg_bit_char <= "7";
			4'd8:	minu_reg_bit_char <= "8";
			4'd9:	minu_reg_bit_char <= "9";
			default:	minu_reg_bit_char <= "0";
		endcase
	end
always@(minu_reg_dec)
	begin
		case(minu_reg_dec)
			3'd0: minu_reg_dec_char <= "0";
			3'd1: minu_reg_dec_char <= "1";
			3'd2: minu_reg_dec_char <= "2";
			3'd3: minu_reg_dec_char <= "3";
			3'd4: minu_reg_dec_char <= "4";
			3'd5: minu_reg_dec_char <= "5";
			default:minu_reg_dec_char <= "0";
		endcase
	end
always@(hour_reg_bit)
	begin
		case(hour_reg_bit)
			4'd0:	hour_reg_bit_char <= "0";
			4'd1:	hour_reg_bit_char <= "1";
			4'd2:	hour_reg_bit_char <= "2";
			4'd3:	hour_reg_bit_char <= "3";
			4'd4:	hour_reg_bit_char <= "4";
			4'd5:	hour_reg_bit_char <= "5";
			4'd6:	hour_reg_bit_char <= "6";
			4'd7:	hour_reg_bit_char <= "7";
			4'd8:	hour_reg_bit_char <= "8";
			4'd9:	hour_reg_bit_char <= "9";
			default:	hour_reg_bit_char <= "0";
		endcase
	end
always@(hour_reg_dec)
	begin
		case(hour_reg_dec)
			2'd0:	hour_reg_dec_char	<= "0";
			2'd1:	hour_reg_dec_char	<=	"1";
			2'd2:	hour_reg_dec_char	<= "2";
			default:hour_reg_dec_char	<= "0";
		endcase
	end
endmodule
关键词: LCD1602     作业
2014-06-30 22:40:41     打赏
2014-06-30 22:46:03     打赏
不过,还是遇到一个问题,就是,如各位所看到的实验现象里面,数字时钟的秒的个位右边的那个字符老是跟着个位一直显示,而且跟它显示的一模一样。不觉名利。其他的均显示正常。
希望个位大神看出原因了,指出来我的错误,谢谢了
从中午十二点到现在,敲了一下午代码,眼睛酸痛,目前来看,自己是看不出来了,明天再看看哪里出错了。
2014-12-23 16:16:37     打赏
参考了楼主的程序,小弟也写了一个程序贴出来,在此献丑!
// Company:        芯创电子工作室
// Engineer:       51FPGA
// Create Date:    16:12:14 12/23/2014
// Design Name:
// Module Name:    timer1602
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
module timer1602(sys_clk    ,
			   sys_rstn   ,
			   lcd_rs     ,
			   lcd_rw     ,
			   lcd_en     ,
			   lcd_data
//输入输出信号定义
input          sys_clk    ;//系统时钟输入
input          sys_rstn   ;//系统复位信号,低电平有效
output         lcd_rs     ;//lcd的寄存器选择输出信号
output         lcd_rw     ;//lcd的读、写操作选择输出信号
output         lcd_en     ;//lcd使能信号
output  [7:0]  lcd_data   ;//lcd的数据总线(不进行读操作,故为输出)
//寄存器定义
reg            lcd_rs     ;
reg            clk_div    ;
reg     [17:0] delay_cnt  ;
reg     [7:0]  lcd_data   ;
reg     [4:0]  char_cnt   ;
reg     [7:0]  data_disp  ;
reg     [9:0]  state      ;
parameter	idle 		= 10'b000000000,	//初始状态,下一个状态为CLEAR
			   clear		= 10'b000000001, 	//清屏
			   set_function	= 10'b000000010, 	//功能设置:8位数据接口/2行显示/5*8点阵字符
			   switch_mode	= 10'b000000100, 	//显示开关控制:开显示,光标和闪烁关闭
			   set_mode     = 10'b000001000, 	//输入方式设置:数据读写操作后,地址自动加一/画面不动
			   shift  		= 10'b000010000, 	//光标、画面位移设置:光标向左平移一个字符位(光标显示是关闭的,所以实际上设置是看不出效果的)
			   set_ddram1   = 10'b000100000, 	//设置DDRAM的地址:第一行起始为0x00(注意输出时DB7一定要为1)
			   set_ddram2   = 10'b001000000, 	//设置DDRAM的地址:第二行为0x40(注意输出时DB7一定要为1)
			   write_ram1   = 10'b010000000, 	//数据写入DDRAM相应的地址
			   write_ram2   = 10'b100000000; 	//数据写入DDRAM相应的地址
assign lcd_rw = 1'b0;						//没有读操作,R/W信号始终为低电平
assign lcd_en = clk_div;	//E信号出现高电平以及下降沿的时刻与LCD时钟相同
//时钟分频
always@(posedge sys_clk or negedge sys_rstn)
begin
	if(!sys_rstn)
		begin
			delay_cnt<=18'd0;
			clk_div<=1'b0;
			clk_div<=1'b0;
		end
	else if(delay_cnt==18'd24999)
		begin
			delay_cnt<=18'd0;
			clk_div<=~clk_div;
		end
	else
		begin
			delay_cnt<=delay_cnt+1'b1;
			clk_div<=clk_div;
		end
end
always@(posedge clk_div or negedge sys_rstn)	//State Machine
begin
	if(!sys_rstn)
		begin
			state 	 <= idle;
			lcd_data <= 8'bzzzzzzzz;
			char_cnt <= 5'd0;
		end
	else
		begin
		case(state)
		idle:	begin						//初始状态
					state <= clear;
				end
		clear:	begin						//清屏
					lcd_rs<=1'b0;
					lcd_data <= 8'b00000001;
				end
		set_function:						//功能设置(38H):8位数据接口/2行显示/5*8点阵字符
				begin
					lcd_rs<=1'b0;
					lcd_data <= 8'b00111000;
				end
		switch_mode:							//显示开关控制(0CH):开显示,光标和闪烁关闭
				begin
					state <= set_mode;
					lcd_rs<=1'b0;
					lcd_data <= 8'b00001100;
				end
		set_mode:begin						//输入方式设置(06H):数据读写操作后,地址自动加一/画面不动
					state <= shift;
					lcd_rs<=1'b0;
					lcd_data <= 8'b00000110;
				end
		shift:	begin						//光标、画面位移设置(10H):光标向左平移一个字符位(光标显示是关闭的,所以实际上设置是看不出效果的)
					lcd_rs<=1'b0;
				end
		set_ddram1:						    //设置DDRAM的地址:第一行起始为00H(注意输出时DB7一定要为1)
				begin
					state <= write_ram1;
					lcd_rs<=1'b0;
					lcd_data <= 8'b1000_0000;//Line1
				end
		set_ddram2:							//设置DDRAM的地址:第二行为40H(注意输出时DB7一定要为1)
				begin
					state <= write_ram2;
					lcd_rs<=1'b0;
					lcd_data <= 8'b1100_0000;//Line2
				end
		write_ram1:
				begin
					if(char_cnt <=5'd12)
						begin
							lcd_rs<=1'b1;
							lcd_data <= data_disp;
						end
					else
						begin
						end
				end
		write_ram2:
				begin
					if(char_cnt <=5'd27)
						begin
							lcd_rs<=1'b1;
						end
					else
						begin
							char_cnt <=5'd0;
							state <= shift;
						end
				end
		default: 	state <= idle;
		endcase
		end
end
always @(char_cnt)			//输出的字符
begin
	case (char_cnt)
	5'd0: data_disp  = "d";
	5'd1: data_disp  = "e";
	5'd2: data_disp  = "s";
	5'd3: data_disp  = "i";
	5'd4: data_disp  = "g";
	5'd5: data_disp  = "n";
	5'd6: data_disp  = "e";
	5'd7: data_disp  = "r";
	5'd8: data_disp  = ":";
	5'd9: data_disp  = "l";
	5'd10: data_disp = "l";
	5'd11: data_disp = "w";
	5'd12: data_disp = " ";
	5'd13: data_disp = "t";
	5'd14: data_disp = "i";
	5'd15: data_disp = "m";
	5'd16: data_disp = "e";
	5'd17: data_disp = " ";
	5'd18: data_disp = ":";
	5'd19: data_disp = hour_reg_dec_char;
	5'd20: data_disp = hour_reg_bit_char;
	5'd21: data_disp = ":";
	5'd22: data_disp = minu_reg_dec_char;
	5'd23: data_disp = minu_reg_bit_char;
	5'd24: data_disp = ":";
	5'd25: data_disp = sec_reg_dec_char;
	5'd26: data_disp = sec_reg_bit_char;
	5'd27: data_disp = " ";
    default :   data_disp ="";
	endcase
end
reg [2:0] sec_reg_dec;
reg [3:0] sec_reg_bit;
reg [2:0] minu_reg_dec;
reg [3:0] minu_reg_bit;
reg [2:0] hour_reg_dec;
reg [3:0] hour_reg_bit;
reg [25:0] delay_cnt_clock;
begin
	if(!sys_rstn)
			delay_cnt_clock<=26'd0;
	 else if(delay_cnt_clock==26'd49999999)
		else
			delay_cnt_clock<=delay_cnt_clock+1'b1;
end
begin
	if(!sys_rstn)
		begin
			sec_reg_dec<=4;
			sec_reg_bit<=3;
			minu_reg_dec<=5;
			minu_reg_bit<=9;
			hour_reg_dec<=2;
			hour_reg_bit<=3;
		end
	else if(hour_reg_dec==3'b010&&hour_reg_bit==4'b0011&&minu_reg_dec==3'b101&&minu_reg_bit==4'b1001&&sec_reg_dec==3'b101&&sec_reg_bit==4'b1001&&delay_cnt_clock==26'd49999999)
		begin
			sec_reg_dec<=0;
			sec_reg_bit<=0;
			minu_reg_dec<=0;
			minu_reg_bit<=0;
			hour_reg_dec<=0;
			hour_reg_bit<=0;
		end
		else if(hour_reg_bit==4'b1001&&minu_reg_dec==3'b101&&minu_reg_bit==4'b1001&&sec_reg_dec==3'b101&&sec_reg_bit==4'b1001&&delay_cnt_clock==26'd49999999)
			begin
				sec_reg_dec<=0;
				sec_reg_bit<=0;
				minu_reg_dec<=0;
				minu_reg_bit<=0;
				hour_reg_dec<=hour_reg_dec+1'b1;
				hour_reg_bit<=0;
			end
			else if(minu_reg_dec==3'b101&&minu_reg_bit==4'b1001&&sec_reg_dec==3'b101&&sec_reg_bit==4'b1001&&delay_cnt_clock==26'd49999999)
				begin
					hour_reg_bit<=hour_reg_bit+1'b1;
					sec_reg_dec<=0;
					sec_reg_bit<=0;
					minu_reg_dec<=0;
					minu_reg_bit<=0;
				end
				else if(minu_reg_bit==4'b1001&&sec_reg_dec==3'b101&&sec_reg_bit==4'b1001&&delay_cnt_clock==26'd49999999)
					begin
						minu_reg_dec<=minu_reg_dec+1'b1;
						minu_reg_bit<=0;
						sec_reg_dec<=0;
						sec_reg_bit<=0;
					end
					else if(sec_reg_dec==3'b101&&sec_reg_bit==4'b1001&&delay_cnt_clock==26'd49999999)
						begin
							minu_reg_bit<=minu_reg_bit+1'b1;
							sec_reg_dec<=0;
							sec_reg_bit<=0;
						end
						else if(sec_reg_bit==4'b1001&&delay_cnt_clock==26'd49999999)
							begin
								sec_reg_dec<=sec_reg_dec+1'b1;
								sec_reg_bit<=0;
							end
								begin
									sec_reg_bit<=sec_reg_bit+1'b1;
								end
								else
									begin
										sec_reg_dec<=sec_reg_dec;
										sec_reg_bit<=sec_reg_bit;
										minu_reg_dec<=minu_reg_dec;
										minu_reg_bit<=minu_reg_bit;
										hour_reg_dec<=hour_reg_dec;
										hour_reg_bit<=hour_reg_bit;
									end
end
    begin
        case(sec_reg_bit)
        endcase
    end
    begin
        case(sec_reg_dec)
        endcase
    end
    begin
        case(minu_reg_bit)
        endcase
    end
    begin
        case(minu_reg_dec)
        endcase
    end
    begin
        case(hour_reg_bit)
        endcase
    end
    begin
        case(hour_reg_dec)
        endcase
    end
endmodule
2014-12-24 16:47:37     打赏
赞一个!!
共5条 1/1 1 跳转至页
