电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 布斯乘法器
布斯乘法器
2014-07-30 22:17:49     打赏
library IEEE;
use IEEE.Std_logic_1164.all;
ENTITY booth_multiplier IS
     GENERIC(k : POSITIVE := 7); --input number word length less one
     PORT(multiplicand, multiplier : IN BIT_VECTOR(k DOWNTO 0);
        clock : IN BIT; product : INOUT BIT_VECTOR((2*k + 1) DOWNTO 0));
END booth_multiplier;
ARCHITECTURE structural OF booth_multiplier IS
SIGNAL mdreg, adderout, carries, augend, tcbuffout : BIT_VECTOR(k DOWNTO 0);
SIGNAL mrreg : BIT_VECTOR((k + 1) DOWNTO 0);
SIGNAL adder_ovfl : BIT;
SIGNAL comp ,clr_mr ,load_mr ,shift_mr ,clr_md ,load_md ,clr_pp ,load_pp ,shift_pp : BIT;
SIGNAL boostate : NATURAL RANGE 0 TO 2*(k + 1);
BEGIN
PROCESS --main clocked process containing all sequential elements
BEGIN
        WAIT UNTIL (clock'EVENT AND clock = '1');
        --register to hold multiplicand during multiplication
        IF clr_md = '1' THEN
                mdreg <= (OTHERS => '0');
        ELSIF load_md = '1' THEN
                mdreg <= multiplicand;
        ELSE
                mdreg <= mdreg;
        END IF;
        --register/shifter to product pair of bits used to control adder
        IF clr_mr = '1' THEN
                mrreg <= (OTHERS => '0');
        ELSIF load_mr = '1' THEN
                mrreg((k + 1) DOWNTO 1) <= multiplier;
                mrreg(0) <= '0';
        ELSIF shift_mr = '1' THEN
                mrreg <= mrreg SRL 1;
        ELSE
                mrreg <= mrreg;
        END IF;
        --register/shifter accumulates partial product values
        IF clr_pp = '1' THEN
                product <= (OTHERS => '0');
        ELSIF load_pp = '1' THEN
                product((2*k + 1) DOWNTO (k + 1)) <= adderout; --add to top half
                product(k DOWNTO 0) <= product(k DOWNTO 0);  --refresh bootm half
        ELSIF shift_pp = '1' THEN
                product <= product SRA 1; --shift right with sign extend
        ELSE
                product <= product;
        END IF;
END PROCESS;
--adder adds/subtracts partial product to multiplicand
augend <= product((2*k+1) DOWNTO (k+1));
addgen : FOR i IN adderout'RANGE
        GENERATE
                lsadder : IF i = 0 GENERATE
                        adderout(i) <= tcbuffout(i) XOR augend(i) XOR comp;
                        carries(i) <= (tcbuffout(i) AND augend(i)) OR
                                      (tcbuffout(i) AND comp) OR
                                      (comp AND augend(i));
                        END GENERATE;
                otheradder : IF i /= 0 GENERATE
                        adderout(i) <= tcbuffout(i) XOR augend(i) XOR carries(i-1);
                                      (tcbuffout(i) AND carries(i-1)) OR
                                      (carries(i-1) AND augend(i));
                        END GENERATE;
        END GENERATE;
        --twos comp overflow bit
        adder_ovfl <= carries(k-1) XOR carries(k);
--true/complement buffer to generate two's comp of mdreg
tcbuffout <= NOT mdreg WHEN (comp = '1') ELSE mdreg;
--booth multiplier state counter
PROCESS BEGIN
        IF boostate < 2*(k + 1) THEN boostate <= boostate + 1;
        ELSE boostate <= 0;
        END IF;
END PROCESS;
--assign control signal values based on state
PROCESS(boostate)
BEGIN
        --assign defaults, all registers refresh
        comp <= '0';
        clr_mr <= '0';
        load_mr <= '0';
        shift_mr <= '0';
        clr_md <= '0';
        load_md <= '0';
        clr_pp <= '0';
        load_pp <= '0';
        shift_pp <= '0';
        IF boostate = 0 THEN
                load_mr <= '1';
                load_md <= '1';
                clr_pp <= '1';
        ELSIF boostate MOD 2 = 0 THEN   --boostate = 2,4,6,8 ....
                shift_mr <= '1';
                shift_pp <= '1';
        ELSE    --boostate = 1,3,5,7......
                IF mrreg(0) = mrreg(1) THEN
                        NULL; --refresh pp
                ELSE
                        load_pp <= '1'; --update product
                END IF;
                comp <= mrreg(1);       --subract if mrreg(1 DOWNTO 0) ="10"
        END IF;
END PROCESS;
END structural;
关键词: 乘法器
2014-08-06 07:14:41     打赏
标题 + 源代码
强悍的帖子~~
