电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » jobs的进程帖(通讯显示测试源代码发布)
共41条 2/5 ‹ 1 2 3 4 5 › 跳转至页
2014-08-09 18:55:06     打赏
11楼
2014-08-10 08:35:02     打赏
12楼
版主大大给力
2014-08-17 21:48:27     打赏
13楼
为了方便大家焊接完成后检查焊接成果。版主编写了测试程序。
测试程序首先以列为扫描,之后以层为扫描,之后全亮,最后再全灭。循环如此。
附源代码如下:
  * @file    main.c
  * @author  Jobs Zheng
  * @version V1.0
  * @date    2014-08-17
  * @brief   LEDcube 测试程序
  * @note    按列扫描,按层扫描,全亮,全灭
  * @attention
  * <h2><center>&copy; COPYRIGHT 2013 EEPW.com.cn </center></h2>
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "bsp.h"
/** @addtogroup STM32_EEPW
/** @defgroup LEDCUBE
  * @brief
/** @defgroup LEDCUBE_Private_TypesDefinitions
/** @defgroup LEDCUBE_Private_Defines
//#define SIMULATE (1)
#define INTERVAL (500)
/** @defgroup LEDCUBE_Private_Macros
/** @defgroup LEDCUBE_Private_Variables
uint16_t gSecond= 0;
bool gShareMemoryBusy;
uint8_t gDisp = 0;
uint16_t gCount = 0;
uint8_t gGraphBuffer[64] = {0xFF,};
/** @defgroup LEDCUBE_Private_FunctionPrototypes
void AutoReFresh(uint8_t *BufferPtr, bool gShareMemoryBusy);
/** @defgroup LEDCUBE_Private_Functions
  * @brief  main function
  * @param
  * @retval
  * @date   2014-03-24
  * @note
void main(void)
  gShareMemoryBusy = false;
  uint8_t i;
  uint8_t RollLayer[] = {0, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0xFF};
  uint8_t RollRow[] = {0, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0xFF};
  uint8_t RollLayerLongth = sizeof(RollLayer);
  uint8_t RollRowLongth = sizeof(RollRow);
  for(i = 0; i < 64; i++)
    gShareMemoryBusy = true;
    gGraphBuffer[i] = 0xFF;
  i = 0;
#ifndef SIMULATE
  Bsp_Init();  /*!< 底层外设模块初始化 */
#endif
  if (SysTick_Config(72000))  /*!< 1000Hz(1ms)中断间隔 */
    while (1);
  while(true)
    if(gSecond == INTERVAL)
      gSecond = 0;
      if(i < RollRowLongth)
        DispRow(RollRow[i], gGraphBuffer);
      else
        DispLayer(RollLayer[i - RollRowLongth], gGraphBuffer);
      i++;
      if(i == (RollRowLongth + RollLayerLongth))
        i = 0;
      else
        ; //nothing to do
  * @brief  定时刷新光立方显示
  * @param  uint8_t *BufferPtr: 显示图形缓存
            bool MemBusy: 检查显示图形缓存是否可用,
                      true:正在更新缓存,此时不显示;
                      false:已经完成数据更新,不断刷新
  * @retval
  * @date   2014-08-17
  * @note   1000Hz显示每一层
void AutoReFresh(uint8_t *BufferPtr, bool MemBusy)
  if(MemBusy == true)
    // to do something
    return;
  else
    Bsp_LayerOff(gDisp);  //关闭当前层的显示
    H595Disable();
    gDisp++;
    if(gDisp > 7)
      gDisp = 0;
    DispFlush(BufferPtr + gDisp * 8);
    H595Enable();
    Bsp_LayerOn(gDisp); //打开当前层的显示
  * @brief  使用systick中断产生1000Hz, 1ms中断
  * @param
  * @retval
  * @date   2014-08-17
  * @note   500Hz会出现闪烁
void SysTick_Handler(void)
  AutoReFresh((uint8_t *)gGraphBuffer, gShareMemoryBusy);
  if(gSecond < INTERVAL)
    gSecond++;
  else
    gSecond = INTERVAL;
/******************* (C) EEPW.com.cn*****END OF FILE****/
  * @file    display.c
  * @version v1.0
  * @date    2014-08-17   09:59
  * @brief   用来显示函数图形
  * @note
  * @attention
  * <h2><center>&copy; COPYRIGHT 2014 EEPW.com.cn </center></h2>
#include "display.h"
  * @brief
//#define XXXX    ()  /*!<  */
  * @brief  显示某层LED灯
  * @param  uint8_t lay:第0位表示第0层点亮
            uint8_t * bufferPtr:图形显示缓存
  * @retval
  * @date   2014-08-17
  * @note
void DispLayer(uint8_t lay, uint8_t * bufferPtr)
  uint8_t temp[64];
  uint8_t i, j;
  for(i =0; i < 8; i++)
    if(((lay >> i) & 0x01) == 0x01)
      for(j = 0; j < 8; j++)
        temp[i * 8 + j] = 0x00;
    else
        temp[i * 8 + j] = 0xFF;
  * @brief  将临时缓存区的内容拷贝至图形缓存区
    *(bufferPtr + i) = temp[i];
  * @brief  显示某列LED灯
  * @param  uint8_t row:第0位表示第0列点亮
  * @retval
  * @date   2014-08-17
  * @note
void DispRow(uint8_t row, uint8_t * bufferPtr)
  uint8_t temp[64];
  uint8_t i, j;
    if(((row >> i) & 0x01) == 0x01)
        temp[i + j * 8] = 0x00;
    else
        temp[i + j * 8] = 0xFF;
  * @file    bsp.c
  * @version
  * @date    2014-06-15   15:54
  * @brief   光立方项目工程
  * @note    初始化板载硬件外设端口,spi1,spi2,uart1及时钟
  * @attention
#include "bsp.h"
#include <stdio.h>
  * @brief
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
ErrorStatus HSEStartUpStatus;
static void SysClockInit(void);
  * @brief  called from main.c
  * @param
  * @retval
  * @date   2014-03-24
  * @note
void Bsp_Init(void)
  SysClockInit();
  Bsp_LayerInit();
  Uart1Init(115200);
  HC595_Init();
  * @brief  initial the sysclock,
  * @param
  * @retval
  * @date   2014-03-24
  * @note
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------------*/
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 12MHz * 6 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6);    /* 此处需要根据外部晶振的改变而改变 */
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  else
  { /* If HSE fails to start-up, the application will have wrong clock configuration.
       User can add here some code to deal with this error */
    /* Go to infinite loop */
    while (1)
  * @brief  初始化板载8层LED灯
  * @param  none
  * @retval none
  * @date   2014-04-27
  * @note
void Bsp_LayerInit(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(LAYER0_GPIO_CLK, ENABLE);
  GPIO_InitStructure.GPIO_Pin = LAYER0_PIN | LAYER1_PIN | LAYER2_PIN | LAYER3_PIN | LAYER4_PIN | LAYER5_PIN | LAYER6_PIN | LAYER7_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(LAYER0_GPIO_PORT, &GPIO_InitStructure);
  * @brief  给某一层LED灯通电
  * @retval
  * @date   2014-06-30
  * @note
void Bsp_LayerOn(uint8_t lay)
  switch(lay)
    case 0:
      GPIO_SetBits(LAYER0_GPIO_PORT, LAYER0_PIN);
      break;
    case 1:
      GPIO_SetBits(LAYER1_GPIO_PORT, LAYER1_PIN);
      break;
    case 2:
      GPIO_SetBits(LAYER2_GPIO_PORT, LAYER2_PIN);
      break;
    case 3:
      GPIO_SetBits(LAYER3_GPIO_PORT, LAYER3_PIN);
      break;
    case 4:
      GPIO_SetBits(LAYER4_GPIO_PORT, LAYER4_PIN);
      break;
    case 5:
      GPIO_SetBits(LAYER5_GPIO_PORT, LAYER5_PIN);
      break;
    case 6:
      GPIO_SetBits(LAYER6_GPIO_PORT, LAYER6_PIN);
      break;
    case 7:
      GPIO_SetBits(LAYER7_GPIO_PORT, LAYER7_PIN);
      break;
  * @brief  给某一层LED灯断电
  * @retval
  * @date   2014-06-30
  * @note
void Bsp_LayerOff(uint8_t lay)
  switch(lay)
    case 0:
      GPIO_ResetBits(LAYER0_GPIO_PORT, LAYER0_PIN);
      break;
    case 1:
      GPIO_ResetBits(LAYER1_GPIO_PORT, LAYER1_PIN);
      break;
    case 2:
      GPIO_ResetBits(LAYER2_GPIO_PORT, LAYER2_PIN);
      break;
    case 3:
      GPIO_ResetBits(LAYER3_GPIO_PORT, LAYER3_PIN);
      break;
    case 4:
      GPIO_ResetBits(LAYER4_GPIO_PORT, LAYER4_PIN);
      break;
    case 5:
      GPIO_ResetBits(LAYER5_GPIO_PORT, LAYER5_PIN);
      break;
    case 6:
      GPIO_ResetBits(LAYER6_GPIO_PORT, LAYER6_PIN);
      break;
    case 7:
      GPIO_ResetBits(LAYER7_GPIO_PORT, LAYER7_PIN);
      break;
  * @brief  初始化74HC595的驱动方式,使用spi2接口
  * @param  none
  * @retval none
  * @date   2014-06-15
  * @note   使用SPI2的单向,仅发送,低速APB1,最大36MHz
void HC595_Init(void)
  SPI_InitTypeDef  SPI_InitStructure;
  /*!<  PB13 => SPI2_SCK(LED_SCK); PB15 => SPI2_MOSI(LED_TX) Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  /*!< SPI2 Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  /*!< Configure SPI pins: SCK */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /*!< Configure sFLASH_SPI pins: MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  /*!< SPI configuration */
  SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI2, &SPI_InitStructure);
  /*!< Enable the sFLASH_SPI  */
  SPI_Cmd(SPI2, ENABLE);
  /*!< Configure PB14 => ROW  */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
  * @brief  发送一层的数据
  * @param  uint8_t *BufPtr:发送缓冲区,共8字节数据
  * @retval
  * @date   2014-06-17
  * @note
void H595SendData(const uint8_t *BufPtr)
    /*!< Send byte through the SPI2 peripheral */
    SPI_I2S_SendData(SPI2, *BufPtr);
    /*!< Loop while DR register in not emplty */
    while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
  * @brief  使能74HC595,输出数据
  * @param  none
  * @retval none
  * @date   2014-08-17
  * @note
void H595Enable(void)
  GPIO_SetBits(GPIOB, GPIO_Pin_14);   //发送显示开启上升沿
  GPIO_ResetBits(GPIOB, GPIO_Pin_14);
  * @brief  复位74HC595
  * @param  none
  * @retval none
  * @date   2014-08-17
  * @note
void H595Disable(void)
  * @brief  显示一次内容
  * @param
  * @retval
  * @date   2014-07-10
  * @note
void DispFlush(const uint8_t *BufPtr)
  uint8_t i;
  for(i = 0; i < 8; i++)
    H595SendData(BufPtr + i);
  while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) == SET);
  * @brief  配置串口1为printf
  * @param  none
  * @retval none
  * @date   2014-06-15
  * @note
void Uart1Init(uint32_t band)
  USART_InitTypeDef USART_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  /* Configure USART Tx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USART Rx as input floating */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  USART_InitStructure.USART_BaudRate = band;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  /* USART configuration */
  USART_Init(USART1, &USART_InitStructure);
  /* Enable USART */
  USART_Cmd(USART1, ENABLE);
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(USART1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
  return ch;
以上是三个C文件的源代码。
版主的工程文件依然需要回复,并提供积分才能下载。
——回复可见内容——
2014-08-18 21:04:37     打赏
14楼
版主大大给力,就找这个,哈哈,找了好久了
2014-08-18 21:07:27     打赏
15楼
为什么还在审核之中啊
2014-08-18 21:38:42     打赏
16楼
木事 木事!
源代码已经贴出来了,自己 添加一下即可。
2014-08-22 13:15:20     打赏
17楼
瞧瞧版主的~
2014-08-22 18:25:42     打赏
18楼
学习下,谢谢!
2014-08-22 18:33:13     打赏
19楼
Fatal Error[Pe1696]: cannot open source file "main.h" C:\main.c 20
Fatal Error[Pe1696]: cannot open source file "display.h" C:\display.c 20
Fatal Error[Pe1696]: cannot open source file "bsp.h" C:\bsp.c 22
版主这三个文件在哪里呀
2014-08-22 23:12:43     打赏
20楼
这三个头文件都是函数声明,
把函数声明自己添加即可
