电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » STC51单片机实例之39SD卡实验
STC51单片机实例之39SD卡实验
2014-09-13 21:53:43     打赏
这里需要用到2G的SD卡,SD卡插上后,会在串口中对数据进行读写。显示0-9
#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
#include<9325TP.h>
//定义SD卡需要的4根信号线
sbit SD_CLK = P1^1;
sbit SD_DI  = P1^2;
sbit SD_DO  = P1^0;
sbit SD_CS  = P1^3;
//定义按键端口
sbit KEY = P3^2;
//定义512字节缓冲区,注意需要使用 xdata关键字
unsigned char xdata DATA[75]={0};
unsigned char xdata DATA1[75]={0};
//写一字节到SD卡,模拟SPI总线方式
void SdWrite(unsigned char n)
unsigned char i;
for(i=8;i;i--)
SD_CLK=0;
SD_DI=(n&0x80);
n<<=1;
SD_CLK=1;
SD_DI=1;
//从SD卡读一字节,模拟SPI总线方式
unsigned char SdRead()
unsigned char n,i;
for(i=8;i;i--)
SD_CLK=0;
SD_CLK=1;
n<<=1;
if(SD_DO) n|=1;
return n;
//检测SD卡的响应
unsigned char SdResponse()
unsigned char i=0,response;
while(i<=8)
response = SdRead();
if(response==0x00)
break;
if(response==0x01)
break;
i++;
return response;
//发命令到SD卡
void SdCommand(unsigned char command, unsigned long argument, unsigned char CRC)
SdWrite(command|0x40);
SdWrite(((unsigned char *)&argument)[0]);
SdWrite(((unsigned char *)&argument)[1]);
SdWrite(((unsigned char *)&argument)[2]);
SdWrite(((unsigned char *)&argument)[3]);
SdWrite(CRC);
//初始化SD卡
unsigned char SdInit(void)
int delay=0, trials=0;
unsigned char i;
unsigned char response=0x01;
SD_CS=1;
for(i=0;i<=9;i++)
SdWrite(0xff);
SD_CS=0;
//Send Command 0 to put MMC in SPI mode
SdCommand(0x00,0,0x95);
response=SdResponse();
if(response!=0x01)
return 0;
while(response==0x01)
SD_CS=1;
SdWrite(0xff);
SD_CS=0;
SdCommand(0x01,0x00ffc000,0xff);
SD_CS=1;
SdWrite(0xff);
return 1;
//往SD卡指定地址写数据,一次最多512字节
unsigned char SdWriteBlock(unsigned char *Block, unsigned long address,int len)
unsigned int count;
unsigned char dataResp;
//Block size is 512 bytes exactly
//First Lower SS
SD_CS=0;
//Then send write command
SdCommand(0x18,address,0xff);
if(SdResponse()==00)
SdWrite(0xff);
SdWrite(0xff);
SdWrite(0xff);
//command was a success - now send data
//start with DATA TOKEN = 0xFE
SdWrite(0xfe);
//now send data
for(count=0;count<len;count++) SdWrite(*Block++);
for(;count<512;count++) SdWrite(0);
//data block sent - now send checksum
SdWrite(0xff); //两字节CRC校验, 为0XFFFF 表示不考虑CRC
SdWrite(0xff);
//Now read in the DATA RESPONSE token
dataResp=SdRead();
//Following the DATA RESPONSE token
//are a number of BUSY bytes
//a zero byte indicates the MMC is busy
while(SdRead()==0);
dataResp=dataResp&0x0f; //mask the high byte of the DATA RESPONSE token
SD_CS=1;
SdWrite(0xff);
if(dataResp==0x0b)
//printf("DATA WAS NOT ACCEPTED BY CARD -- CRC ERROR\n");
return 0;
if(dataResp==0x05)
return 1;
//printf("Invalid data Response token.\n");
return 0;
//printf("Command 0x18 (Write) was not received by the MMC.\n");
return 0;
//从SD卡指定地址读取数据,一次最多512字节
unsigned char SdReadBlock(unsigned char *Block, unsigned long address,int len)
unsigned int count;
//First Lower SS
 //printf("MMC_read_block\n");
SD_CS=0;
SdCommand(0x11,address,0xff);
while(SdRead()!=0xfe);
for(count=0;count<len;count++) *Block++=SdRead();
for(;count<512;count++) SdRead();
SdRead();
SdRead();
SD_CS=1;
SdRead();
return 1;
 //printf("Command 0x11 (Read) was not received by the MMC.\n");
return 0;
* 名称 : Com_Init()
* 功能 : 初始化串口程序,晶振11.0592, 波特率9600
* 输入 : 无
* 输出 : 无
void Com_Init(void)
     TMOD = 0x20;
     PCON = 0x00;
     SCON = 0x50;
     TH1 = 0xFd;
     TL1 = 0xFd;
     TR1 = 1;
//主程序
main()
  unsigned long AddTemp=262144;//SD卡地址第一个数据物理地址初始值,可以用winhex查看,这里是512扇区,512x512=262144,根据实际SD卡内容更改
unsigned char i;
unsigned char *p;
  	CS=1;
	delayms(5);
	RES=0;
	delayms(5);
	RES=1;
	delayms(5);
	SdInit();         //SD卡初始化
	Com_Init();
	for(i=0;i<75;i++)
		DATA1[i]=i;
		SdWriteBlock(DATA1, AddTemp, 75);
    	SdReadBlock(DATA, AddTemp, 75);
		p= DATA;
while(1)
for(i=0;i<75;i++)
		SBUF = *p+48;
		while(!TI)                   //如果发送完毕,硬件会置位TI
			_nop_();
		p++;
		TI = 0;		                //TI清零
		delayms(500);
  名称:写彩屏
  公司:上海浩豚电子科技有限公司
  网站:www.doflye.net
  编写:师访
  日期:2009.12
  修改:无
  内容:320x240像素、16位BMP图片的HEX数据,依次写到屏上,还原图片
  注意事项:
#include"reg52.h"
//根据芯片资料定义
#define WINDOW_XADDR_START	0x0050 // Horizontal Start Address Set
#define WINDOW_XADDR_END	0x0051 // Horizontal End Address Set
#define WINDOW_YADDR_START	0x0052 // Vertical Start Address Set
#define WINDOW_YADDR_END	0x0053 // Vertical End Address Set
#define GRAM_XADDR		    0x0020 // GRAM Horizontal Address Set
#define GRAM_YADDR		    0x0021 // GRAM Vertical Address Set
#define GRAMWR 			    0x0022 // memory write
//定义液晶屏接口
sbit CS=P2^2;		//片选
sbit RES=P2^1;		//复位
sbit RS=P2^4;		//数据/命令选择
sbit RW=P2^5;
                    //数据口使用P0
//函数声明
void ILI9325_Initial(void);
void Write_Cmd_Data(unsigned char x, unsigned int y);
void Write_Cmd(unsigned char DH,unsigned char DL);
void Write_Data(unsigned char DH,unsigned char DL);
void delayms(unsigned int tt);
void  Write_Data_U16(unsigned int y);
static void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1);
void ClearScreen(unsigned int bColor);
//清屏
 unsigned int i,j;
 LCD_SetPos(0,240,0,320);//320x240
 for (i=0;i<320;i++)
	   for (j=0;j<240;j++)
	       Write_Data_U16(bColor);
//写命令数据
void  Write_Cmd_Data (unsigned char x,unsigned int y)
	unsigned char m,n;
	m=y>>8;
	n=y;
	Write_Cmd(0x00,x);
	Write_Data(m,n);
//写16位数据
	unsigned char m,n;
	m=y>>8;
	n=y;
	Write_Data(m,n);
//写命令
	CS=0;
	RS=0;
	P0=DH;
	RW=0;
	RW=1;
	P0=DL;
	RW=0;
	RW=1;
	CS=1;
//写数据
	CS=0;
	RS=1;
	P0=DH;
	RW=0;
    RW=1;
	P0=DL;
	RW=0;
	RW=1;
	CS=1;
//延时程序
void delayms(unsigned int count)
    int i,j;
    for(i=0;i<count;i++)
	     for(j=0;j<260;j++);
//液晶初始化
 delayms(50);                     //根据不同晶振速度可以调整延时,保障稳定显示
 Write_Cmd_Data(0x0001,0x0100);
 Write_Cmd_Data(0x0002,0x0700);
 Write_Cmd_Data(0x0003,0x1030);
 Write_Cmd_Data(0x0004,0x0000);
 Write_Cmd_Data(0x0008,0x0207);
 Write_Cmd_Data(0x0009,0x0000);
 Write_Cmd_Data(0x000A,0x0000);
 Write_Cmd_Data(0x000C,0x0000);
 Write_Cmd_Data(0x000D,0x0000);
 Write_Cmd_Data(0x000F,0x0000);
//power on sequence VGHVGL
 Write_Cmd_Data(0x0010,0x0000);
 Write_Cmd_Data(0x0011,0x0007);
 Write_Cmd_Data(0x0012,0x0000);
 Write_Cmd_Data(0x0013,0x0000);
//vgh
 Write_Cmd_Data(0x0010,0x1290);
 Write_Cmd_Data(0x0011,0x0227);
 //delayms(100);
 //vregiout
 Write_Cmd_Data(0x0012,0x001d); //0x001b
 //delayms(100);
 //vom amplitude
 Write_Cmd_Data(0x0013,0x1500);
 //delayms(100);
 //vom H
 Write_Cmd_Data(0x0029,0x0018);
 Write_Cmd_Data(0x002B,0x000D);
//gamma
 Write_Cmd_Data(0x0030,0x0004);
 Write_Cmd_Data(0x0031,0x0307);
 Write_Cmd_Data(0x0032,0x0002);// 0006
 Write_Cmd_Data(0x0035,0x0206);
 Write_Cmd_Data(0x0036,0x0408);
 Write_Cmd_Data(0x0037,0x0507);
 Write_Cmd_Data(0x0038,0x0204);//0200
 Write_Cmd_Data(0x0039,0x0707);
 Write_Cmd_Data(0x003C,0x0405);// 0504
 Write_Cmd_Data(0x003D,0x0F02);
 //ram
 Write_Cmd_Data(0x0050,0x0000);
 Write_Cmd_Data(0x0051,0x00EF);
 Write_Cmd_Data(0x0052,0x0000);
 Write_Cmd_Data(0x0053,0x013F);
 Write_Cmd_Data(0x0060,0xA700);
 Write_Cmd_Data(0x0061,0x0001);
 Write_Cmd_Data(0x006A,0x0000);
 Write_Cmd_Data(0x0080,0x0000);
 Write_Cmd_Data(0x0081,0x0000);
 Write_Cmd_Data(0x0082,0x0000);
 Write_Cmd_Data(0x0083,0x0000);
 Write_Cmd_Data(0x0084,0x0000);
 Write_Cmd_Data(0x0085,0x0000);
 Write_Cmd_Data(0x0090,0x0010);
 Write_Cmd_Data(0x0092,0x0600);
 Write_Cmd_Data(0x0093,0x0003);
 Write_Cmd_Data(0x0095,0x0110);
 Write_Cmd_Data(0x0097,0x0000);
 Write_Cmd_Data(0x0098,0x0000);
 Write_Cmd_Data(0x0007,0x0133);
//	Write_Cmd_Data(0x0022);//
//定义坐标
  Write_Cmd_Data(WINDOW_XADDR_START,x0);
  Write_Cmd_Data(WINDOW_XADDR_END,x1);
  Write_Cmd_Data(WINDOW_YADDR_START,y0);
  Write_Cmd_Data(WINDOW_YADDR_END,y1);
  Write_Cmd_Data(GRAM_XADDR,x0);
  Write_Cmd_Data(GRAM_YADDR,y0);
  Write_Cmd (0x00,0x22);//LCD_WriteCMD(GRAMWR);
2019-03-14 14:45:56     打赏
楼主的无私分享,是我们加强学习,积极进步的动力。
