电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 【系统滴答&18B20】16号同学的作业本
共94条 5/10 |‹ 3 4 5 6 7 8 ›| 跳转至
2014-10-28 09:00:29     打赏
41楼
STM32开发板学习
 焊接:http://forum.eepw.com.cn/thread/260879/1/#1
 调试:http://forum.eepw.com.cn/thread/260879/2/#16
 Keil的安装与破解:http://forum.eepw.com.cn/thread/260879/3/#22
LED闪烁呈Z字形;RGB闪烁6彩,不含白光:http://forum.eepw.com.cn/thread/260879/3/#26
LED&RGB改进版:http://forum.eepw.com.cn/thread/260879/4/#31
按键,数码管显示计数&按键切换扫描速度 :  http://forum.eepw.com.cn/thread/260879/4/#35
串口发送信息控制LED闪烁速度:http://forum.eepw.com.cn/thread/260879/5/#43
 外部中断 按键点亮 熄灭LED http://forum.eepw.com.cn/thread/260879/7/#68
外部中断 定时器防抖 http://forum.eepw.com.cn/thread/260879/8/#74
 定时器中断闪烁LED(TIM2 TIM3) http://forum.eepw.com.cn/thread/260879/7/#70
 PWM-RGB渐变全彩 http://forum.eepw.com.cn/thread/260879/8/#75
2014-10-28 12:29:49     打赏
42楼
希望能坚持下去
2014-11-04 11:08:44     打赏
43楼
作业六:串口发送信息,控制LED闪烁间隔时间(偶数)
输入格式举例:data=n那么led闪烁的时间间隔就是n毫秒。难点:将字符数组保存的n转换成整型n
 此处n取1到9999之间
视频地址:http://player.youku.com/player.php/sid/XODE5NjI0MTcy/v.swf
源代码:
#include "stm32f10x.h"
#include "stm32_eval.h"
#include	"stdio.h"
#include "math.h"
#define buff_size  16;
char rx_buff[], rx_buff_count=0;
GPIO_InitTypeDef  GPIO_InitStructure;
USART_InitTypeDef  USART_InitStructure;
NVIC_InitTypeDef  NVIC_InitStructure;
USART_ClockInitTypeDef  USART_ClockInitStructure;
void RCC_Configuration(void)
	RCC_DeInit();
	RCC_HSICmd(ENABLE);
	while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
	RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
	RCC_HSEConfig(RCC_HSE_OFF);
	RCC_LSEConfig(RCC_LSE_OFF);
	RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
	RCC_PLLCmd(ENABLE);
	while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
	RCC_ADCCLKConfig(RCC_PCLK2_Div4);
	RCC_PCLK2Config(RCC_HCLK_Div1);
	RCC_PCLK1Config(RCC_HCLK_Div2);
	RCC_HCLKConfig(RCC_SYSCLK_Div1);
	RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
	while(RCC_GetSYSCLKSource() != 0x08);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
	GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
	GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
	GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
void GPIO_INIT()
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PC0-PC7
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
	GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PC
void USART_int(long BaudRate)
	 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
   GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入
   GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
	USART_InitStructure.USART_BaudRate = BaudRate;//传输速率
	USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特
	USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1
	USART_InitStructure.USART_Parity = USART_Parity_No;//
	USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none
	USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式
	USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
	USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
	USART_Init(USART1, &USART_InitStructure);//初始化USART1
	USART_Cmd(USART1, ENABLE);
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Configure four bit for preemption priority */
	NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级
  /* Enable the USART1 Interrupt */
	NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道
	NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
	NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
	NVIC_Init(&NVIC_InitStructure);//初始化中断
/*delay_us*/
void delay_us(u32 n)
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
/*delay_ms*/
void  delay_ms(u32 n)
	while(n--)
	delay_us(1000);
void USART_SendStr(char *str)//发送字符串
   while((*str)!='\0')//到字符串的末尾才停止发送数据
		USART_SendData(USART1,*str++);
		while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned int translate(char *S,char j)//将字符串组成的数字转换成整型数据
	unsigned int a[4],sum=0;
	char i;
	for(i=0;i<j;i++)
		a[i]=S[5+j-1-i]-48;//将字符转成整型数据
		sum+=a[i]*pow(10,i);//按照每一位的权值相乘再相加,还原data=n的本来面貌
	return sum;//sum保存目标整型数据
void func(char *S,char LEN)
	char count;//
	unsigned int sum,i,j,k;
 	if((LEN!=6)&(LEN!=7)&(LEN!=8)&(LEN!=9))//data=1~999
	{USART_SendStr("\r\n Erro input!!!\r\n");}//如果输入格式错误,发送提示
 	else
		count=LEN-5;//从“=”后面开始是目标数据
		sum = translate(S,count);//count记录“=”后有多少位,传递到translate中
		GPIO_SetBits(GPIOC,0x000000ff);//all LED off
		for(k=0;k<3;k++)//循环点亮D8-D1 3次
			i=0x00000100;
			for(j=1;j<=8;j++)//LED D8-D1
				i>>=1;
				GPIO_ResetBits(GPIOC,i); 	// on PC7-PC0 D8-D1
				delay_ms(50);
				GPIO_SetBits(GPIOC,i);
				delay_ms(sum);//每两盏灯发光,间隔时间sum
void input_ASK()
	char j;
	func(rx_buff,rx_buff_count);
	rx_buff_count=0;
	for (j=0;j<rx_buff_count;j++)
	{rx_buff[j]='\0';}//判断读入信息是否结束,如果结束则准备下一次读入
	USART_SendStr("\n>");
int main(void)
	RCC_Configuration();
	GPIO_INIT();
	USART_int(9600);
	GPIO_ResetBits(GPIOC,0x000000ff);//led全亮,提示程序开始
	delay_ms(200);
	GPIO_SetBits(GPIOC,0x000000ff);//led全灭
	USART_SendStr("SyStem booting......\r\n");//
	USART_SendStr("\n>");//
	while(1)
void USART1_IRQHandler(void)
  while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
	if(USART_ReceiveData(USART1)==0x0d)//如果输入完毕,按下了回车
	{input_ASK();}
	else
		USART_SendData(USART1,USART_ReceiveData(USART1));
		rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
		rx_buff_count++;
  	USART_ClearFlag(USART1, USART_FLAG_RXNE);
2014-11-05 21:45:42     打赏
44楼
看视频是ok了
不过这个代码,能用不?
2014-11-05 21:47:36     打赏
45楼
不懂为什么,,发上来老是少括号,少函数,已经4次了!!!
很多人都提醒我说代码好像漏了什么。。
2014-11-05 21:48:54     打赏
46楼
又编辑了一遍 你看看?
2014-11-05 21:52:48     打赏
47楼
可以尝试再流水灯运行的时候,通过串口改变速度
2014-11-05 21:53:13     打赏
48楼
这个帖子再肥点可以加精华了
2014-11-05 22:03:59     打赏
49楼
意思就是LED一直在亮,通过串口改变闪烁的速度吧?  我一开始想让它们一直亮的,然后一下子想不出来。。。我再想想
2014-11-06 00:06:08     打赏
50楼
数码管不就是要这样的吗,头痛着这个问题啊,像这样流水灯循环三次再输入这数码管会黑的
