共7条
交一下PCF8563的作业
*Engineer: superdian
*Create Date: 2014/9/7
*Design Name:
*Module Name: pcf8563_topd
*Project Name:
*Target Devices: EP3CE5E144C8
*Tool versions:
*Description:
*Dependencies:
*Revision:
*Revision 0.01 - File Created
*Additional Comments: 开发板晶振为20MHZ,工程中通过倍频50MH。
module pcf8563_top(
input sys_rstn,
input sys_clk,
output scl,
inout wire sda,
output lcd_rs , //lcd的寄存器选择输出信号
output lcd_rw , //lcd的读、写操作选择输出信号
output lcd_en , //lcd使能信号
output [7:0] lcd_data //lcd的数据总线(不进行读操作,故为输出)
wire clk;
wire [7:0] data_trans; //从相应寄存器读取的数据
wire finish_bit; //从单个寄存器读取数据完毕的标志
reg [7:0] data_word; //发送相应寄存器地址
reg [7:0] sec; //储存从秒寄存器读出的数据
reg [7:0] mnt; //储存从分寄存器读出的数据
reg [7:0] hur; //储存从小时寄存器读出的数据
reg [7:0] week; //储存从星期寄存器读出的数据
reg [7:0] day; //储存从日寄存器读出的数据
reg [7:0] month; //储存从月份寄存器读出的数据
reg [7:0] year; //储存从年寄存器读出的数据
reg [7:0] code_ctl; //状态机状态寄存器
parameter sec_time=8'd0;
parameter mnt_time=8'd1;
parameter hour_time=8'd2;
parameter day_time=8'd3;
parameter week_time=8'd4;
parameter month_time=8'd5;
parameter year_time=8'd6;
clk_pll clk_pll (
.inclk0(sys_clk),
.c0(clk)
i2c_test i2c_test(
.clk(clk),
.scl(scl),
.sda(sda),
.data_read_wire(data_trans),
.sda_data_addr(8'ha2),
.sda_data_word(data_word),
.finish_bit(finish_bit)
lcd1602 lcd1602(
.sys_rstn(sys_rstn),
.lcd_rs(lcd_rs),
.lcd_rw(lcd_rw),
.lcd_en(lcd_en),
.lcd_data(lcd_data),
.sys_clk(clk),
.seg_sec(sec),
.seg_mnt(mnt),
.seg_hur(hur),
.seg_week(week),
.seg_day(day),
.seg_month(month),
.seg_year(year)
always@(posedge clk)
begin
case(code_ctl)
sec_time:
begin
if(finish_bit==1'b0)
begin
data_word<=8'h02;//发送秒寄存器地址
sec<=data_trans;
end
else
begin
code_ctl<=mnt_time;
end
end
mnt_time:
begin
begin
data_word<=8'h03;//发送分钟寄存器地址
mnt<=data_trans;
end
else
begin
code_ctl<=hour_time;
end
end
hour_time:
begin
begin
data_word<=8'h04;//发送小时寄存器地址
hur<=data_trans;
end
else
begin
code_ctl<=day_time;
end
end
day_time:
begin
begin
data_word<=8'h05;//发送日寄存器地址
day<=data_trans;
end
else
begin
code_ctl<=week_time;
end
end
week_time:
begin
begin
data_word<=8'h6;//发送星期寄存器地址
week<=data_trans;
end
else
begin
code_ctl<=month_time;
end
end
month_time:
begin
begin
data_word<=8'h07;//发送月寄存器地址
month<=data_trans;
end
else
begin
code_ctl<=year_time;
end
end
year_time:
begin
begin
data_word<=8'h08;//发送年寄存器地址
year<=data_trans;
end
else
begin
code_ctl<=sec_time;
end
end
endcase
end
endmodule
*Design Name:
*Module Name: lcd1602
*Project Name:
*Tool versions:
*Description:
*Dependencies:
*Revision:
module lcd1602(sys_clk ,
sys_rstn ,
lcd_rs ,
lcd_rw ,
lcd_en ,
lcd_data ,
seg_sec ,
seg_mnt ,
seg_hur ,
seg_week ,
seg_day ,
seg_month ,
seg_year
//输入输出信号定义
input [7:0] seg_sec;
input [7:0] seg_mnt;
input [7:0] seg_hur;
input [7:0] seg_week;
input [7:0] seg_day;
input [7:0] seg_month;
input [7:0] seg_year;
input sys_clk ;//系统时钟输入
input sys_rstn ;//系统复位信号,低电平有效
output lcd_rs ;//lcd的寄存器选择输出信号
output lcd_rw ;//lcd的读、写操作选择输出信号
output lcd_en ;//lcd使能信号
output [7:0] lcd_data ;//lcd的数据总线(不进行读操作,故为输出)
//寄存器定义
reg lcd_rs ;
reg clk_div ;
reg [17:0] delay_cnt ;
reg [7:0] lcd_data ;
reg [5:0] char_cnt ;
reg [7:0] data_disp ;
reg [9:0] state ;
reg [3:0] disp_dat;
reg [25:0] g=0;
reg [3:0] shi1;
reg [1:0] shi2;
reg [3:0] fen1;
reg [2:0] fen2;
reg [3:0] miao1;
reg [2:0] miao2;
reg [7:0] shi11;
reg [7:0] shi22;
reg [7:0] fen11;
reg [7:0] fen22;
reg [7:0] miao11;
reg [7:0] miao22;
reg [2:0] week1;
reg [3:0] day1;
reg [2:0] day2;
reg [3:0] month1;
reg [3:0] month2;
reg [3:0] year1;
reg [3:0] year2;
reg [7:0] week11;
reg [7:0] day11;
reg [7:0] day22;
reg [7:0] month11;
reg [7:0] month22;
reg [7:0] year11;
reg [7:0] year22;
reg [7:0] centry1;
reg [7:0] centry2;
reg centry;
parameter idle = 10'b000000000, //初始状态,下一个状态为CLEAR
clear = 10'b000000001, //清屏
set_function = 10'b000000010, //功能设置:8位数据接口/2行显示/5*8点阵字符
switch_mode = 10'b000000100, //显示开关控制:开显示,光标和闪烁关闭
set_mode = 10'b000001000, //输入方式设置:数据读写操作后,地址自动加一/画面不动
shift = 10'b000010000, //光标、画面位移设置:光标向左平移一个字符位(光标显示是关闭的,所以实际上设置是看不出效果的)
set_ddram1 = 10'b000100000, //设置DDRAM的地址:第一行起始为0x00(注意输出时DB7一定要为1)
set_ddram2 = 10'b001000000, //设置DDRAM的地址:第二行为0x40(注意输出时DB7一定要为1)
write_ram1 = 10'b010000000, //数据写入DDRAM相应的地址
write_ram2 = 10'b100000000; //数据写入DDRAM相应的地址
assign lcd_rw = 1'b0; //没有读操作,R/W信号始终为低电平
assign lcd_en = clk_div; //E信号出现高电平以及下降沿的时刻与LCD时钟相同
//时钟分频
always@(posedge sys_clk or negedge sys_rstn)
begin
if(!sys_rstn)
begin
delay_cnt<=18'd0;
clk_div<=1'b0;
end
else if(delay_cnt==18'd249999)//原来50MHZ249999
begin
delay_cnt<=18'd0;
clk_div<=~clk_div;
end
else
begin
delay_cnt<=delay_cnt+1'b1;
clk_div<=clk_div;
end
end
always@(posedge clk_div or negedge sys_rstn) //State Machine
begin
if(!sys_rstn)
begin
state <= idle;
lcd_data <= 8'bzzzzzzzz;
char_cnt <= 5'd0;
end
else
begin
case(state)
idle: begin //初始状态
state <= clear;
end
clear: begin //清屏
state <= set_function;
lcd_rs<=1'b0;
lcd_data <= 8'b00000001;
end
set_function: //功能设置(38H):8位数据接口/2行显示/5*8点阵字符
begin
state <= switch_mode;
lcd_rs<=1'b0;
lcd_data <= 8'b00111000;
end
switch_mode: //显示开关控制(0CH):开显示,光标和闪烁关闭
begin
state <= set_mode;
lcd_rs<=1'b0;
lcd_data <= 8'b00001100;
end
set_mode:begin //输入方式设置(06H):数据读写操作后,地址自动加一/画面不动
state <= shift;
lcd_rs<=1'b0;
lcd_data <= 8'b00000110;
end
shift: begin //光标、画面位移设置(10H):光标向左平移一个字符位(光标显示是关闭的,所以实际上设置是看不出效果的)
state <= set_ddram1;
lcd_rs<=1'b0;
lcd_data <= 8'b0001_0000;
end
set_ddram1: //设置DDRAM的地址:第一行起始为00H(注意输出时DB7一定要为1)
begin
state <= write_ram1;
lcd_rs<=1'b0;
lcd_data <= 8'b1000_0000;//Line1
end
set_ddram2: //设置DDRAM的地址:第二行为40H(注意输出时DB7一定要为1)
begin
state <= write_ram2;
lcd_rs<=1'b0;
lcd_data <= 8'b1100_0000;//Line2
end
write_ram1:
begin
if(char_cnt <=5'd15)
begin
char_cnt <= char_cnt + 1'b1;
lcd_rs<=1'b1;
lcd_data <= data_disp;
end
else
begin
state <= set_ddram2;
end
end
write_ram2:
begin
if(char_cnt <=5'd31)
begin
lcd_rs<=1'b1;
end
else
begin
char_cnt <=5'd0;
state <= shift;
end
end
default: state <= idle;
endcase
end
end
always @(char_cnt) //输出的字符
begin
case (char_cnt)
6'd0: data_disp = "-";
6'd1: data_disp = "-";
6'd2: data_disp = "-";
6'd3: data_disp = "-";
6'd4: data_disp = centry2;
6'd5: data_disp = centry1;
6'd6: data_disp = year22;
6'd7: data_disp = year11;
6'd8: data_disp = "/";
6'd9: data_disp = month22;
6'd10: data_disp = month11;
6'd11: data_disp = "/";
6'd12: data_disp = day22;
6'd13: data_disp = day11;
6'd14: data_disp = "/";
6'd15: data_disp = week11;
6'd16: data_disp = "E";
6'd17: data_disp = "E";
6'd18: data_disp = "P";
6'd19: data_disp = "W";
6'd20: data_disp = "-";
6'd21: data_disp = "-";
6'd22: data_disp = "-";
6'd23: data_disp = "-";
6'd24: data_disp = shi22;
6'd25: data_disp = shi11;
6'd26: data_disp = "/";
6'd27: data_disp = fen22;
6'd28: data_disp = fen11;
6'd29: data_disp = "/";
6'd30: data_disp = miao22;
6'd31: data_disp = miao11;
default : data_disp ="-";
endcase
end
将从pcf8563读出的数据写入相应时,分,秒,年,月,日寄存器
always@(posedge sys_clk)
begin
if(g==26'd2499999)
g<=26'd0;
else
g<=g+1'b1;
end
begin
if(g==26'd2499999)
disp_dat<=disp_dat+1'b1;
else
disp_dat<=disp_dat;
end
always@(disp_dat)
begin
case(disp_dat)
4'd0:
miao1=seg_sec[3:0];
4'd1:
miao2=seg_sec[6:4];
4'd2:
fen1=seg_mnt[3:0];
4'd3:
fen2=seg_mnt[6:4];
4'd4:
shi1=seg_hur[3:0];
4'd5:
shi2=seg_hur[5:4];
4'd6:
week1=seg_week[2:0];
4'd7:
day1=seg_day[3:0];
4'd8:
day2=seg_day[5:4];
4'd9:
month1=seg_month[3:0];
4'd10:
month2=seg_month[5];
4'd11:
year1=seg_year[3:0];
4'd12:
year2=seg_year[7:4];
4'd13:
centry=seg_month[7];
endcase
end
begin
if(centry == 1'b0)
begin
centry1 <= "0";
centry2 <= "2";
end
else
begin
centry1 <= "9";
centry2 <= "1";
end
end
将相应寄存器的BCD码转换为ASCII码
always@(week1)
begin
case(week1)
3'd0: week11 = "0";
3'd1: week11 = "1";
3'd2: week11 = "2";
3'd3: week11 = "3";
3'd4: week11 = "4";
3'd5: week11 = "5";
3'd6: week11 = "6";
3'd7: week11 = "7";
default : week11 = "0";
endcase
end
always@(day1)
begin
case(day1)
4'd0: day11 = "0";
4'd1: day11 = "1";
4'd2: day11 = "2";
4'd3: day11 = "3";
4'd4: day11 = "4";
4'd5: day11 = "5";
4'd6: day11 = "6";
4'd7: day11 = "7";
default: day11 = "0";
endcase
end
always@(day2)
begin
case(day22)
3'd0:day22 = "0";
3'd1:day22 = "1";
3'd2:day22 = "2";
3'd3:day22 = "3";
default: day22 ="0";
endcase
end
always@(month1)
begin
case(month1)
4'd0: month11 = "0";
4'd1: month11 = "1";
4'd2: month11 = "2";
4'd3: month11 = "3";
4'd4: month11 = "4";
4'd5: month11 = "5";
4'd6: month11 = "6";
4'd7: month11 = "7";
4'd8: month11 = "8";
4'd9: month11 = "9";
default : month11 = "0";
endcase
end
always@(month2)
begin
case(month2)
1'b0: month22 = "0";
1'b1: month22 = "1";
default : month22 = "0";
endcase
end
always@(year1)
begin
case(year1)
4'd0: year11 = "0";
4'd1: year11 = "1";
4'd2: year11 = "2";
4'd3: year11 = "3";
4'd4: year11 = "4";
4'd5: year11 = "5";
4'd6: year11 = "6";
4'd7: year11 = "7";
4'd8: year11 = "8";
4'd9: year11 = "9";
default : year11 = "0";
endcase
end
always@(year2)
begin
case(year2)
4'd0: year22 = "0";
4'd1: year22 = "1";
4'd2: year22 = "2";
4'd3: year22 = "3";
4'd4: year22 = "4";
4'd5: year22 = "5";
4'd6: year22 = "6";
4'd7: year22 = "7";
4'd8: year22 = "8";
4'd9: year22 = "9";
default : year22 = "0";
endcase
end
always @(miao1)
begin
case (miao1)
4'd0: miao11 = "0";
4'd1: miao11 = "1";
4'd2: miao11 = "2";
4'd3: miao11 = "3";
4'd4: miao11 = "4";
4'd5: miao11 = "5";
4'd6: miao11 = "6";
4'd7: miao11 = "7";
4'd8: miao11 = "8";
4'd9: miao11 = "9";
default : miao11 ="0";
endcase
end
always @(miao2)
begin
case (miao2)
3'd0: miao22 = "0";
3'd1: miao22 = "1";
3'd2: miao22 = "2";
3'd3: miao22 = "3";
3'd4: miao22 = "4";
3'd5: miao22 = "5";
default : miao22 ="0";
endcase
end
always @(fen1)
begin
case (fen1)
4'd0: fen11 = "0";
4'd1: fen11 = "1";
4'd2: fen11 = "2";
4'd3: fen11 = "3";
4'd4: fen11 = "4";
4'd5: fen11 = "5";
4'd6: fen11 = "6";
4'd7: fen11 = "7";
4'd8: fen11 = "8";
4'd9: fen11 = "9";
default : fen11 ="0";
endcase
end
always @(fen2)
begin
case (fen2)
3'd0: fen22 = "0";
3'd1: fen22 = "1";
3'd2: fen22 = "2";
3'd3: fen22 = "3";
3'd4: fen22 = "4";
3'd5: fen22 = "5";
default : fen22 ="0";
endcase
end
always @(shi1)
begin
case (shi1)
4'd0: shi11 = "0";
4'd1: shi11 = "1";
4'd2: shi11 = "2";
4'd3: shi11 = "3";
4'd4: shi11 = "4";
4'd5: shi11 = "5";
4'd6: shi11 = "6";
4'd7: shi11 = "7";
4'd8: shi11 = "8";
4'd9: shi11 = "9";
default : shi11 ="0";
endcase
end
always @(shi2)
begin
case (shi2)
2'd0: shi22 = "0";
2'd1: shi22 = "1";
2'd2: shi22= "2";
default : shi22 ="0";
endcase
end
endmodule
*Design Name:
*Module Name: i2c_test
*Project Name:
*Tool versions:
*Description:
*Dependencies:
*Revision:
*Additional Comments: 开发板晶振为20MHZ,工程中通过倍频50MHZ。
module i2c_test(input clk,
output scl,
inout wire sda,
output [7:0]data_read_wire,
input [7:0]sda_data_addr,
input [7:0]sda_data_word,
output reg finish_bit
reg sda_io_flag; //sda输入输出状态寄存器
reg read_flag; //主机读写状态
reg sda_r; //数据寄存器
reg scl_r; //时钟脉冲寄存器
reg [7:0] scl_ctr; //scl分频参数寄存器
reg [7:0] scl_sts;
reg [7:0] i2c_sts;
reg [7:0] sda_data_a;
reg [3:0] data_bit;
reg [7:0] data_read;
reg [24:0] timer;
assign scl=scl_r;
assign sda=sda_io_flag?sda_r:1'bz; //sda输入输出状态选择
assign data_read_wire=data_read;
`define scl_pos (scl_sts==3'd0)
`define scl_high (scl_sts==3'd1)
`define scl_neg (scl_sts==3'd2)
`define scl_low (scl_sts==3'd3)
parameter idle =4'd0;
parameter start =4'd1;
parameter send_a =4'd2;
parameter slv_ack1 =4'd3;
parameter send_d =4'd4;
parameter slv_ack2 =4'd5;
parameter send_dd =4'd6;
parameter slv_ack3 =4'd7;
parameter read_byte =4'd8;
parameter master_ack =4'd9;
parameter stop =4'd10;
//SCL分频250KHZ
begin
if(scl_ctr ==8'd199)
scl_ctr<=8'd0;
else
scl_ctr<=scl_ctr+1'b1;
end
begin
case(scl_ctr)
8'd49: scl_sts<=3'd1;//处于高电平中间用于数据采样
8'd99: scl_sts<=3'd2;//下降沿
8'd149: scl_sts<=3'd3;//处于低电平中间用于数据变化
8'd199: scl_sts<=3'd0;//上升沿
default: scl_sts<=3'd5;
endcase
end
begin
if(scl_sts==3'd0)
scl_r<=1'b1;
if(scl_sts==3'd2)
scl_r<=1'b0;
end
begin
if(timer==0)
begin
i2c_sts<=idle;
data_bit<=4'd0;
sda_io_flag<=1'b1;
sda_r<=1'b1;
read_flag<=1'b0;
end
case(i2c_sts)
idle:
begin
i2c_sts<=start;
if(read_flag==1'b1)//判断主机读写状态
sda_data_a<=sda_data_addr+1'b1;//地址+1,即为读状态(A3)
else
sda_data_a<=sda_data_addr;//地址不加一,即为写状态(A2)
end
start:
begin
if(`scl_high)//启动I2C
begin
sda_io_flag<=1'b1;
sda_r<=1'b0;
i2c_sts<=send_a;//发送地址状态
end
else
begin
i2c_sts<=start;
end
end
send_a://发送地址状态
begin
if(`scl_low)
begin
case(data_bit)//8位串行地址数据
4'd0: sda_r<= sda_data_a[7];
4'd1: sda_r<= sda_data_a[6];
4'd2: sda_r<= sda_data_a[5];
4'd3: sda_r<= sda_data_a[4];
4'd4: sda_r<= sda_data_a[3];
4'd5: sda_r<= sda_data_a[2];
4'd6: sda_r<= sda_data_a[1];
4'd7: sda_r<= sda_data_a[0];
endcase
data_bit<=data_bit+1'b1;
if(data_bit==4'd8)//发送地址完毕
begin
sda_io_flag<=1'b0;//SDA做输入口
i2c_sts<=slv_ack1;//读从机应答信号
data_bit<=4'd0;
end
end
else
i2c_sts<=send_a;
end
slv_ack1://从机应答
begin
if(`scl_high)
begin
sda_io_flag<=1'b0;
if(sda==0)
begin
if(read_flag==1'b1)
begin
i2c_sts<=read_byte;
sda_io_flag<=1'b0;
end
else
begin
i2c_sts<=send_d;
sda_io_flag<=1'b1;
sda_r<=1'b0;
sda_data_a<=sda_data_word;
end
end
end
else
begin
i2c_sts<=slv_ack1;
end
end
send_d://发送数据
begin
if(`scl_low)
begin
case(data_bit)
4'd0: sda_r<=sda_data_a[7];
4'd1: sda_r<=sda_data_a[6];
4'd2: sda_r<=sda_data_a[5];
4'd3: sda_r<=sda_data_a[4];
4'd4: sda_r<=sda_data_a[3];
4'd5: sda_r<=sda_data_a[2];
4'd6: sda_r<=sda_data_a[1];
4'd7: sda_r<=sda_data_a[0];
endcase
if(data_bit==4'd8)
begin
sda_io_flag<=1'b0;
i2c_sts<=slv_ack2;//发送数据完毕,进入应答状态
data_bit<=4'd0;
end
end
else
i2c_sts<=send_d;
end
slv_ack2://应答状态
begin
if(`scl_high)
begin
sda_io_flag<=1'b0;
if(sda==0)
begin
i2c_sts<=stop;
sda_io_flag<=1'b1;
sda_r<=1'b0;
end
end
else
begin
i2c_sts<=slv_ack2;
end
end
read_byte://读出数据
begin
if(`scl_high)
begin
sda_io_flag<=1'b0;
data_read<=(data_read<<1)|sda;
if(data_bit==4'd7)
begin
i2c_sts<=master_ack;
data_bit<=4'd0;
end
end
end
master_ack://主机应答
begin
if(`scl_low)
begin
sda_io_flag<=1'b1;
sda_r<=1'b0;
if(data_bit==4'd1)
begin
i2c_sts<=stop;
data_bit<=4'd0;
end
end
end
stop://停止I2C
begin
if(`scl_high)
begin
sda_r<=1'b1;
read_flag<=1'b1;
if(read_flag==1'b0)
i2c_sts<=idle;
else
i2c_sts<=stop;
end
end
endcase
end
begin
if(timer<=25'd12500000)
begin
timer<=timer+1'b1;
if(timer==25'd12499999)
finish_bit<=1'b1;
end
else
begin
timer<=25'd0;
finish_bit<=1'b0;
end
end
endmodule
共7条
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
