电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 删删作业【~渣渣作业停止更新~】
共67条 4/7 |‹ ‹ 2 3 4 5 6 7 › 跳转至页
2014-10-23 13:07:15     打赏
31楼
收到~改了~
2014-10-23 22:01:26     打赏
32楼
这还真是考验智商啊!!
2014-10-25 23:10:10     打赏
33楼
你的智商~
2014-10-27 17:48:58     打赏
34楼
数码管显示:0~30
key1;key3切换到key2(动态扫描)
2014-10-27 19:27:49     打赏
35楼
(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//0
(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//1
 (GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//2
(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);//3
(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);//4
(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);//5
(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//6
(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);//7
(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//8
(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);//9
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)//始终配置
  RCC_DeInit();//将RCC寄存器重设为缺省值
  RCC_HSICmd(ENABLE);//使能内部高速晶振
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//HSI晶振返回reset
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//选择HSI作为系统时钟
  RCC_HSEConfig(RCC_HSE_OFF);//HSE晶振关
  RCC_LSEConfig(RCC_LSE_OFF);//LSE晶振关
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);//使能PLL状态
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC时钟=PCLK/4
  RCC_PCLK2Config(RCC_HCLK_Div1);//APB2时钟=HCLK
  RCC_PCLK1Config(RCC_HCLK_Div2);//APB1时钟=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB时钟=系统时钟
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//选择PLL作为系统时钟
  while(RCC_GetSYSCLKSource() != 0x08);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
void delay_us(u32 n)
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
void  delay_ms(u32 n)
	while(n--)
	delay_us(1000);
int main (void)
	char i=0;
	RCC_Configuration();
	/*初始化PC*/
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
	GPIO_Init(GPIOC, &GPIO_InitStructure);
	/*初始化PB*/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
	GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
	  while(1){
		if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_8)==0)
		if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))
       delay_ms(100);if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}
    if(i>30){i=0;}
		GPIO_ResetBits(GPIOB,GPIO_Pin_1);
		GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
		switch(i)
		 case 0 :
			 GPIO_SetBits(GPIOB,GPIO_Pin_1);
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//0
		 break;
		 case 1 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//1
		 break;
			case 2 :
			break;
			case 3 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);//3
			break;
			case 4 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);//4
			break;
			case 5 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);//5
			break;
			case 6 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//6
			break;
			case 7 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);//7
			break;
			case 8 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//8
			break;
			case 9 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);//9
			break;
			case 10 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
                  GPIO_SetBits(GPIOB,GPIO_Pin_15);
                  delay_ms(200);
                  GPIO_ResetBits(GPIOB,GPIO_Pin_15);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//10
			break;
			case 11 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//11
			break;
			case 12 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//12
			break;
			case 13 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//13
			case 14 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//14
			break;
			case 15 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//15
			break;
			case 16 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//16
			break;
			case 17 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//17
			break;
			case 18 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//18
			break;
			case 19 :
			 delay_ms(100);
       GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//19
			break;
			case 20 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//20
			break;
			case 21 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//21
			break;
			case 22 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//22
			break;
			case 23 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//23
			case 24 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//24
			break;
			case 25 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//25
			break;
			case 26 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//26
			break;
			case 27 :
			 GPIO_ResetBits	(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
			 delay_ms(100);
       GPIO_SetBits	(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//27
			break;
			case 28 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//28
			break;
			case 29 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);//29
			break;
			case 30 :
			 delay_ms(100);
                  delay_ms(200);
                  GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);//30
			break;
2014-10-27 20:42:54     打赏
36楼
这代码看的我都晕了。
楼主,您这当时写的时候得多辛苦啊~~
P.S. 楼主是不是使用的外置16MHz的晶振啊~~
2014-10-27 22:06:51     打赏
37楼
去看我的就不幸苦了嘿嘿。。
2014-10-27 22:13:35     打赏
38楼
看你的就更不懂了!C重修的人不是开玩笑的渣~if else的 我都看了老半天了  渣都学渣阵营都容不下我了
2014-10-27 22:17:25     打赏
39楼
腿都盘麻了
PS:要是我说我不知道外置晶振的参数会不会太诚实了~
2014-10-28 00:34:56     打赏
40楼
8M
