考完四级再更新~占个楼而已~
滴答18b20
记得添加.H文件~
没添加.H文件 按重置键调试助手只会显示双引号内容~如“config done...”
#include "stm32f10x.h"
#include "stm32_eval.h"
#include
volatile int flag;
#define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12)//上拉关闭pc12
#define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12)//下拉打开pc12
#define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)//读pc状态
unsigned char Error_Flag=0;
unsigned char zf=0;
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
/**************延时函数*******************/
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
void SysTick_Configuration(void)
/* Setup SysTick Timer for 10 msec interrupts */
if (SysTick_Config(48000))
/* Capture error */
while (1);
/* Configure the SysTick handler priority */
NVIC_SetPriority(SysTick_IRQn, 0x0);
void RCC_Configuration(void)
RCC_DeInit();//将RCC寄存器重设为缺省值
RCC_HSICmd(ENABLE);//使能内部高速晶振
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//HSI晶振返回reset
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//选择HSI作为系统时钟
RCC_HSEConfig(RCC_HSE_OFF);//HSE晶振关
RCC_LSEConfig(RCC_LSE_OFF);//LSE晶振关
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);//使能PLL状态
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC时钟=PCLK/4
RCC_PCLK2Config(RCC_HCLK_Div1);//APB2时钟=HCLK
RCC_PCLK1Config(RCC_HCLK_Div2);//APB1时钟=HCLK/2
RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB时钟=系统时钟
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//选择PLL作为系统时钟
while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* PA10 USART1_Rx */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = BaudRate;
USART_InitStructure.USART_BaudRate = BaudRate;//usart传输波比特
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一帧传输或接收8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//在帧结尾传输1个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶失能
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收使能,发送使能
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//时钟低电平活动
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;//始终低电平
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//时钟第二边缘进行数据捕获
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据的时钟不从SCLK输出
USART_ClockInit(USART1, &USART_ClockInitStructure);//使能USART1时钟
USART_Init(USART1, &USART_InitStructure);//初始化USART1
USART_Cmd(USART1, ENABLE);//使能USART1外设
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能中断
void delay_18b20(u32 nus)//18b20专属延时
u16 i;
while(nus--)
for(i=12;i>0;i--);
void Init18B20(void)//初始化
u8 aa=0;
u8 count =0;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
Set_B20() ;
delay_18b20(1);
Reset_B20();
delay_18b20(480);
Set_B20();
// delay_18b20(500);
delay_18b20(480);
count=0;
aa=Read_B20();
while(!aa && count<100)
aa=Read_B20();
count++;
if(count>=99)
Error_Flag=1;
else
Error_Flag=0;
unsigned char Read18B20(void)//按位读取数据
unsigned char i=0;
unsigned char date=0;
u8 tempp;
for(i=8;i>0;i--)
Reset_B20();//打开pc12
date>>=1;//标识右移一位
delay_18b20(1);
Set_B20(); //关闭pc12
delay_18b20(1);
tempp=Read_B20();//温度读取
if(tempp)
date|=0x80;
delay_18b20(60);
return(date);
void Write18B20(unsigned char date)//读数据
unsigned char i=0;
for (i=8; i>0; i--)
Reset_B20();
delay_18b20(1);
if(date & 0x01)
Set_B20();
else
{ Reset_B20();}
delay_18b20(60);
date>>=1;
Set_B20();
delay_18b20(1);
delay_18b20(15);
float Read_T()//读温度
unsigned char TUp,TDown;
unsigned char fTemp;
u8 TT=0;
float Temp = 0;
Init18B20();
Write18B20(0xcc);
Write18B20(0x44);
Init18B20();
Write18B20(0xcc);
Write18B20(0xbe);
TDown = Read18B20();
TUp = Read18B20();
if(TUp>0x7f)
TDown=~TDown;
TUp=~TUp+1;
TUp/=8;
zf=1;
else
zf=0;
fTemp=TDown&0x0f;
TUp<<=4;
TDown>>=4;
TT=TUp|TDown;
Temp=TT+(float)fTemp/16;
return(Temp);
int main(void)
char ID[8];
int i;
RCC_Configuration();
USART_int(115200);
SysTick_Configuration();
printf(" config done...\r\n");
delay_ms(1000);
Init18B20();
Write18B20(0x33);
delay_18b20(20);
for(i=0;i<8;i++) //大神说这里要用for语句,不然只会输出printf("event 1 oc......\r\n")这句,不会继续运行
ID[i] = Read18B20();//读取地址
while(1)
if(flag == 300)
printf("At the moment of ID is:") ;
for(i=0;i<8;i++)
printf("%u",ID[i]);
printf("\r\n") ;
if(flag == 500)
printf("The Temperature is:%f\r\n",Read_T());//读取温度并输出
printf("===================================================\r\n");
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
while (1)
#endif
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(EVAL_COM1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
| 为遥控小车巧添功能被打赏¥26元 | |
