考完四级再更新~占个楼而已~
滴答18b20
记得添加.H文件~
没添加.H文件 按重置键调试助手只会显示双引号内容~如“config done...”
#include "stm32f10x.h" #include "stm32_eval.h" #include volatile int flag; #define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12)//上拉关闭pc12 #define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12)//下拉打开pc12 #define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)//读pc状态 unsigned char Error_Flag=0; unsigned char zf=0; GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; /**************延时函数*******************/ void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) { while(n--) delay_us(1000); } void SysTick_Configuration(void) { /* Setup SysTick Timer for 10 msec interrupts */ if (SysTick_Config(48000)) { /* Capture error */ while (1); } /* Configure the SysTick handler priority */ NVIC_SetPriority(SysTick_IRQn, 0x0); } void RCC_Configuration(void) { RCC_DeInit();//将RCC寄存器重设为缺省值 RCC_HSICmd(ENABLE);//使能内部高速晶振 while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//HSI晶振返回reset RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//选择HSI作为系统时钟 RCC_HSEConfig(RCC_HSE_OFF);//HSE晶振关 RCC_LSEConfig(RCC_LSE_OFF);//LSE晶振关 RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE);//使能PLL状态 while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC时钟=PCLK/4 RCC_PCLK2Config(RCC_HCLK_Div1);//APB2时钟=HCLK RCC_PCLK1Config(RCC_HCLK_Div2);//APB1时钟=HCLK/2 RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB时钟=系统时钟 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//选择PLL作为系统时钟 while(RCC_GetSYSCLKSource() != 0x08); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate; USART_InitStructure.USART_BaudRate = BaudRate;//usart传输波比特 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一帧传输或接收8bit USART_InitStructure.USART_StopBits = USART_StopBits_1;//在帧结尾传输1个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶失能 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收使能,发送使能 USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//时钟低电平活动 USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;//始终低电平 USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//时钟第二边缘进行数据捕获 USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据的时钟不从SCLK输出 USART_ClockInit(USART1, &USART_ClockInitStructure);//使能USART1时钟 USART_Init(USART1, &USART_InitStructure);//初始化USART1 USART_Cmd(USART1, ENABLE);//使能USART1外设 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能中断 USART_Cmd(USART1, ENABLE); } void delay_18b20(u32 nus)//18b20专属延时 { u16 i; while(nus--) for(i=12;i>0;i--); } void Init18B20(void)//初始化 { u8 aa=0; u8 count =0; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; GPIO_Init(GPIOC, &GPIO_InitStructure); Set_B20() ; delay_18b20(1); Reset_B20(); delay_18b20(480); Set_B20(); // delay_18b20(500); delay_18b20(480); count=0; aa=Read_B20(); while(!aa && count<100) { aa=Read_B20(); count++; } if(count>=99) Error_Flag=1; else Error_Flag=0; } unsigned char Read18B20(void)//按位读取数据 { unsigned char i=0; unsigned char date=0; u8 tempp; for(i=8;i>0;i--) { Reset_B20();//打开pc12 date>>=1;//标识右移一位 delay_18b20(1); Set_B20(); //关闭pc12 delay_18b20(1); tempp=Read_B20();//温度读取 if(tempp) date|=0x80; delay_18b20(60); } return(date); } void Write18B20(unsigned char date)//读数据 { unsigned char i=0; for (i=8; i>0; i--) { Reset_B20(); delay_18b20(1); if(date & 0x01) { Set_B20(); } else { Reset_B20();} delay_18b20(60); date>>=1; Set_B20(); delay_18b20(1); } delay_18b20(15); } float Read_T()//读温度 { unsigned char TUp,TDown; unsigned char fTemp; u8 TT=0; float Temp = 0; Init18B20(); Write18B20(0xcc); Write18B20(0x44); Init18B20(); Write18B20(0xcc); Write18B20(0xbe); TDown = Read18B20(); TUp = Read18B20(); if(TUp>0x7f) { TDown=~TDown; TUp=~TUp+1; TUp/=8; zf=1; } else zf=0; fTemp=TDown&0x0f; TUp<<=4; TDown>>=4; TT=TUp|TDown; Temp=TT+(float)fTemp/16; return(Temp); } int main(void) { char ID[8]; int i; RCC_Configuration(); USART_int(115200); SysTick_Configuration(); printf(" config done...\r\n"); delay_ms(1000); Init18B20(); Write18B20(0x33); delay_18b20(20); for(i=0;i<8;i++) //大神说这里要用for语句,不然只会输出printf("event 1 oc......\r\n")这句,不会继续运行 { ID[i] = Read18B20();//读取地址 } while(1) { if(flag == 300) { printf("At the moment of ID is:") ; for(i=0;i<8;i++) { printf("%u",ID[i]); } printf("\r\n") ; } if(flag == 500) { printf("The Temperature is:%f\r\n",Read_T());//读取温度并输出 printf("===================================================\r\n"); } } } #ifdef USE_FULL_ASSERT void assert_failed(uint8_t* file, uint32_t line) { while (1) { } } #endif #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT void assert_failed(uint8_t* file, uint32_t line) { while (1) { } } #endif /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
汽车+汽车电子电阻解释与分析被打赏5分 | |
分享汽车通信和多媒体总线结构被打赏20分 | |
【我踩过的那些坑】结构堵孔导致的喇叭无声问题被打赏50分 | |
NUCLEO-U083RC学习历程38+串口通过队列的方式输出两个字符串被打赏20分 | |
【我踩过的那些坑】分享一下调试一款AD芯片的遇到的“坑”被打赏50分 | |
电流检测模块MAX4080S被打赏10分 | |
分享电控悬架的结构与工作原理(一)被打赏20分 | |
多组DCTODC电源方案被打赏50分 | |
【我踩过的那些坑】STM32cubeMX软件的使用过程中的“坑”被打赏50分 |
