电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 【更】左翼:时钟滴答读取18b20地址
共61条 6/7 |‹ 2 3 4 5 6 7 跳转至
2014-12-01 23:00:35     打赏
51楼
           ADC-PWM-RGB-RGB
为了看到明显变化所以分了四种情况
密码:12
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
#define VREF 3.3
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
	SystemInit();
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
	USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void delay_us(u32 n)
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
void  delay_ms(u32 n)
	while(n--)
	delay_us(1000);
void PWM_Config()
{uint16_t PrescalerValue = 0;
	TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
	/* TIM2 clock enable */
  /* GPIOA  enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);
		GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
		TIM_Cmd(TIM2, ENABLE);
	  /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
	/* PWM1 Mode configuration: Channel3 */
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
	/* PWM1 Mode configuration: Channel4 */
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
void ADC_CONFIG(){
	ADC_InitTypeDef ADC_InitStructure;
	#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  /* ADCCLK = PCLK2/2 */
  RCC_ADCCLKConfig(RCC_PCLK2_Div2);
#else
  /* ADCCLK = PCLK2/4 */
#endif
ADC_DeInit(ADC1);
  /* Enable ADC1 and GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
	/* Configure PB0 (ADC Channel14) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
	 /* ADC1 regular channel configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);
	/* Enable ADC1 reset calibration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
	return ADC_GetConversionValue(ADC1);
void PWM_TEST()
	float Volt=0.00;
	unsigned int temp0,temp1,temp2,ADValue = 0;
	while(1)
	  ADValue = Get_ADC();
		Volt = VREF*ADValue/4095;
		printf("===============================\r\n");
		printf("The ADC value is:%d\r\n",ADValue);
		printf("The Volt is:%f V\r\n",Volt);
	  TIM_SetCompare2(TIM2, temp0);
	  TIM_SetCompare3(TIM2, temp1);
	  TIM_SetCompare4(TIM2, temp2);
		if(ADValue>3000)
		 {  temp0=ADValue/2-1300;temp1=ADValue/2-700;temp2=ADValue/2-150;
		 }if(2000<ADValue<=3000)
		{  temp0=ADValue/2-300;temp1=ADValue/2-900;temp2=ADValue/2-50;
		}if(1000<ADValue<=2000)
		{  temp0=ADValue/2+900;temp1=ADValue/2;temp2=ADValue/2-500;
		}if(ADValue<=1000)
		{  temp0=ADValue+100;temp1=ADValue+600;temp2=ADValue+1000;
			delay_ms(50);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
	RCC_Configuration();
  USART_int(115200);
	ADC_CONFIG();
	printf(" config done...\r\n");
	Get_ADC();
	PWM_Config();
	delay_ms(200);
	while(1)
		PWM_TEST();
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2014-12-02 00:09:17     打赏
52楼
理理效率好高~
2014-12-02 12:52:03     打赏
53楼
闲着也是闲着,早写早轻松
2014-12-08 21:42:22     打赏
54楼
能不能勇用个适点的改锥
突然发现这个帖子也挺不错的。
2014-12-11 00:43:28     打赏
55楼
                   IIc--上电计数
  * @version V3.5.0
  * @attention
#include "delay.h"
#include <stdio.h>
#define VREF 3.3
unsigned char i=0;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
	//SystemInit();
        - One Stop Bit
        - No parity
void GPIO_INIT()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
void Iic1_Init(void)
        I2C_InitTypeDef I2C_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
        //PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
        /* Configure IO connected to IIC*********************/
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStructure.I2C_OwnAddress1 = 0xA0;
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_InitStructure.I2C_ClockSpeed = 400000;
        I2C_Cmd(I2C2, ENABLE);
        I2C_Init(I2C2, &I2C_InitStructure);
        I2C_AcknowledgeConfig(I2C2, ENABLE);
/*IIC?????        */
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));//检查标志位设置与否-总线忙标志位
        I2C_GenerateSTART(I2C2,ENABLE);//产生i2c2传输开始条件
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));//检查最近一次i2c是否是输入事件
        I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);//向指定的从i2c设备传输地址字
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        I2C_SendData(I2C2, write_address);//通过i2c发送一个数据
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        I2C_SendData(I2C2, byte);
        I2C_GenerateSTOP(I2C2, ENABLE);//产生i2c2传输停止条件
        do
                /* Send START condition */
                I2C_GenerateSTART(I2C2, ENABLE);
                /* Read I2C2 SR1 register */
                /* Send EEPROM address for write */
                I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
        }while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));//读取指定的i2c寄存器并返回其值
        /* Clear AF flag */
        I2C_ClearFlag(I2C2, I2C_FLAG_AF);
        /* STOP condition */
unsigned char I2C2_ReadByte(unsigned char  id, unsigned char read_address)
        unsigned char temp;
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
          I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
          I2C_SendData(I2C2, read_address);
          I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
          while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
    I2C_AcknowledgeConfig(I2C2, DISABLE);
    while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
    temp = I2C_ReceiveData(I2C2);
        return temp;
int table[10]=
{GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8 ,GPIO_Pin_9|GPIO_Pin_12 ,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,
GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,
GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,
GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14
 void IIC_TEST()
    i = I2C2_ReadByte(0xA0,0);
    i++;
    printf("从地址读出的数据:%d\r\n",i);
    I2C2_WriteByte(0xA0,0,i);
	  printf("向地址写入的数据:%d\r\n",i);
    printf("上电次数为%d\r\n",i);
	/*for(i=0;i<5;i++)
  I2C2_WriteByte(0xA0,i,buff[i]);
		printf("向地址0x0%x写入数据:%d\r\n",i,buff[i]);
	delay_ms(1000);
  temp=I2C2_ReadByte(0xA0,i);
  printf("从地址0x0%x读出的数据:%d\r\n",i,temp);
	delay_ms(1000);
			if(buff[i] == temp)
			{printf("第%x次IIC读写测试成功!!\r\n",i+1);delay_ms(1000);}
			else {printf("第%x次IIC读写失败!!\r\n",i+1);delay_ms(1000);}
void func()
	char g,s;
	g=i%10;
	s=i/10;
	while(1)
	GPIO_SetBits(GPIOB,GPIO_Pin_15);
  GPIO_ResetBits(GPIOB,table[s]);
	delay_ms(5);
	GPIO_ResetBits(GPIOB,GPIO_Pin_15);
	GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
  //动态扫描
	GPIO_SetBits(GPIOB,GPIO_Pin_1);
  GPIO_ResetBits(GPIOB,table[g]);
  delay_ms(5);
  GPIO_ResetBits(GPIOB,GPIO_Pin_1);
	if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))
	{  delay_ms(200);
		 I2C2_WriteByte(0xA0,0,0);
     printf("上电次数清 0\r\n ");}
int main(void)
	 /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  GPIO_INIT();
  USART_int(115200);
  Iic1_Init();
  IIC_TEST();
  func();
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
2014-12-11 11:42:34     打赏
56楼
                  IIC--上电计数  外部中断清零
  * @version V3.5.0
  * @attention
#include "delay.h"
#include <stdio.h>
#define VREF 3.3
unsigned char i=0;
EXTI_InitTypeDef   EXTI_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
	//SystemInit();
        - One Stop Bit
        - No parity
void GPIO_INIT()
/*IIC?????        */
        do
        /* Clear AF flag */
        unsigned char temp;
        return temp;
int table[10]=
void EXTIkeyS1_Config(void)
  /* Enable GPIOA clock */
  /* Configure PA.00 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void EXTI9_5_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line8) != RESET)
    /* Clear the  EXTI line 8 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line8);
 void IIC_TEST()
    i++;
	/*for(i=0;i<5;i++)
	delay_ms(1000);
	delay_ms(1000);
			if(buff[i] == temp)
void func()
	char g,s;
	g=i%10;
	s=i/10;
	while(1)
	delay_ms(5);
  //动态扫描
  delay_ms(5);
int main(void)
  EXTIkeyS1_Config();
  GPIO_INIT();
  USART_int(115200);
  Iic1_Init();
  IIC_TEST();
  func();
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
2014-12-16 15:59:07     打赏
57楼
COOL,迟来的置顶。
2014-12-24 14:35:09     打赏
58楼
灰常荣幸,谢谢老师哈
2014-12-24 14:46:15     打赏
59楼
                 时钟滴答读出18b20地址
刚开始赋值ID地址的时候没用用for   ID[i] = Read18B20()
 然后灯也不亮,串口只输出了  event 1 oc...... 然后就没有然后了,
之后加了之后输出正常了,但是输出的ID值出错
然后才想起字符不能直接输出的,所以又加了for,之后才完成了
  * @version V3.5.0
  * @attention
	© COPYRIGHT 2011 STMicroelectronics
#include "delay.h"
#include
volatile int flag;
#define Set_B20()	 GPIO_SetBits(GPIOC, GPIO_Pin_12)      //上拉关闭PC12
#define Reset_B20()	 GPIO_ResetBits(GPIOC, GPIO_Pin_12)  //下拉打开PC12
#define Read_B20()	 GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)  //读PC12状态
unsigned char Error_Flag=0;
unsigned char zf=0;
void SysTick_Configuration(void)
  /* Setup SysTick Timer for 10 msec interrupts  */
  if (SysTick_Config(48000))                //SysTick配置
    /* Capture error */
    while (1);
 /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);                       //SysTick中断优先级
  RCC_DeInit();                 //将外设RCC重新设为缺省值
  RCC_HSICmd(ENABLE);            //使能内部高速晶振
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);      //当SHI晶振就绪则重新设定
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);      //设置系统时钟,选择SHI时钟为系统时钟
  RCC_HSEConfig(RCC_HSE_OFF);     //设置外部高速晶振,HSE晶振OFF
  RCC_LSEConfig(RCC_LSE_OFF);      //设置外部低速晶振,LSE晶振OFF
	//******配置PLL时钟频率为48MHZ*******//
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_8);    //RCC_PLLMul_x 即设置PLL时钟频率为 6*x MHz
  RCC_PLLCmd(ENABLE);             ////*******************使能PLL
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);        //PLL就绪
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);                     //  ADC时钟=PCLK/2
  RCC_PCLK2Config(RCC_HCLK_Div1);                       //  APB2时钟=HCLK
  RCC_PCLK1Config(RCC_HCLK_Div2);            /// APB1时钟=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);         //  AHB时钟=系统时钟
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);       // 选择PLL为系统时钟
  while(RCC_GetSYSCLKSource() != 0x08);        //当PLL不是系统时钟
//	SystemInit();
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //使能APB2外设时钟/****GPIOD时钟和功能复用IO时钟***/
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG    SW_DP使能
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;         // //选择设置GPIO管脚
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  ////设置管脚速率
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     ////设置管脚工作状态,此为推挽输出
  GPIO_Init(GPIOD, &GPIO_InitStructure);    //初始化GPIOD
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);     //上拉关闭蜂鸣器
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//LED
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //使能TIM2时钟
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能GPIOA、USART1外设时钟
        - One Stop Bit
        - No parity
  USART_InitStructure.USART_BaudRate = BaudRate;//设置USART传输波特率  BaudRate = 9600 可以直接写9600
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一帧传输或者接收的数据位数为8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//在帧结尾传输一个停止位
  USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶模式失能
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//使能接收发模式
	USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;    //时钟低电平活动
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;      //引脚时钟输出低电平时钟
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;     //第二个时钟边沿开始捕获数据
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据的时钟脉冲不从SCLK输出
  USART_Init(USART1, &USART_InitStructure);//USART1初始化
  USART_Cmd(USART1, ENABLE);//使能USART1时钟外设
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能接受中断
void delay_18b20(u32 nus)    //18b20按照严格的时序工作,这是专属延时
	u16 i;
	while(nus--)
		for(i=12;i>0;i--);
void Init18B20(void)  //18B20初始化
   u8 aa=0;
   u8 count =0;
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出
   Set_B20() ;   // GPIO_SetBits(GPIOC, GPIO_Pin_12)
   delay_18b20(1);
   Reset_B20();
   delay_18b20(480);
   Set_B20();
//	delay_18b20(500);
   delay_18b20(480);
	count=0;
	aa=Read_B20();         //温度读取
	/****个人认为限制温度不超过99度,作为一个保护*/
    while(!aa && count<100)
   	aa=Read_B20();
	count++;          //相当一个for()和while结合
   if(count>=99)
   		Error_Flag=1;
	else
		Error_Flag=0;
unsigned char Read18B20(void)//按位读取数据
unsigned char i=0;
unsigned char date=0;
u8 tempp;
   for(i=8;i>0;i--)
   Reset_B20();   //打开PC12
   date>>=1;    //标志右移一位
   delay_18b20(1);
   Set_B20();    //关闭
    delay_18b20(1);
   tempp=Read_B20();   //读取温度
   if(tempp)
   		date|=0x80;     // 1000 0000   将最高位填1 ,然后右移,每次最高位由0变1,使8位全部传递完毕 0xff = 1111 1111
	delay_18b20(60);
	return(date);
void Write18B20(unsigned char date)//写数据
	unsigned char i=0;
	for (i=8; i>0; i--)
		Reset_B20();
		delay_18b20(1);
		if(date & 0x01)
			Set_B20();
		else
		{	Reset_B20();}
		delay_18b20(60);
		date>>=1;
		 Set_B20();
		 delay_18b20(1);
	delay_18b20(15);
 float Read_T()//读温度
		unsigned char TUp,TDown;
	unsigned char fTemp;
	u8 TT=0;
	 float Temp = 0;
	Init18B20();
	Write18B20(0xcc);
	Write18B20(0x44);
	Init18B20();
	Write18B20(0xcc);
	Write18B20(0xbe);
	TDown = Read18B20();
	TUp = Read18B20();
	if(TUp>0x7f)
		TDown=~TDown;
		TUp=~TUp+1;
		TUp/=8;
		zf=1;
	else
		zf=0;
	fTemp=TDown&0x0f;
	TUp<<=4;
	TDown>>=4;
	TT=TUp|TDown;
	Temp=TT+(float)fTemp/16;
	return(Temp);
int main(void)
	char ID[8];
	int i;
  USART_int(115200);
	SysTick_Configuration();
  delay_ms(1000);
	Init18B20();     //初始化
	Write18B20(0x33);  //写入读取地址的命令
	delay_18b20(20);
	for(i=0;i<8;i++)   //这里必须用for不然 只会输出printf("event 1 oc......\r\n")这句,不会继续运行
		ID[i] = Read18B20();//读取地址
	while(1)
		if(flag == 300)
			printf("At the moment of ID is:")	;
			for(i=0;i<8;i++)     //字符不能直接输出,要按位输出
		  printf("%u",ID[i]);//输出地址
			printf("\r\n")	;
		if(flag == 500)
			printf("The Temperature is:%f\r\n",Read_T());//读取温度并输出
			printf("===================================================\r\n");
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-12-25 22:55:14     打赏
60楼
          SPI--读写ADC值
搞了老久才弄到这程度也是醉了,整型转化都找了好久,自己是不会写的,渣到家了,找个时间再研究下SPI总线这东西。。。。。。
  * @version V3.5.0
  * @attention
#include "delay.h"
#include <stdio.h>
#include <stdlib.h>
#include "spi_flash.h"
#define VREF 3.3
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define RxBufferSize1   (countof(TxBuffer1) - 1)
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define  FLASH_WriteAddress     0x00000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  sFLASH_ID              0xEF3015     //W25X16
//#define  sFLASH_ID              0xEF4015   //W25Q16
#define buff_size  16;
char rx_buff[],rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;
uint8_t Rx_Buffer[BufferSize];
__IO uint32_t DeviceID = 0;
__IO uint32_t FlashID = 0;
__IO TestStatus TransferStatus1 = FAILED;
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9);    //72MHz ,RCC_PLLMul_x 即设置PLL时钟频率为 6*x MHz
//	SystemInit();
        - One Stop Bit
        - No parity
void ADC_CONFIG(){
	ADC_InitTypeDef ADC_InitStructure;//定义结构体
  RCC_ADCCLKConfig(RCC_PCLK2_Div2); //设置ADC时钟 = PCLK/2
#else
  RCC_ADCCLKConfig(RCC_PCLK2_Div4); //设置ADC时钟 = PCLK/4
#endif
ADC_DeInit(ADC1);       //将外设ADC1的全部寄存器重设为缺省值
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);//使能APB2外设时钟
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模拟输入
  GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2工作在独立状态
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;  //规定模数转换在多通道还是单通道
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//转化是连续还是单次模式
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;   //转换是由软件而不是外部触发启动
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;  //ADC数据右对齐
  ADC_InitStructure.ADC_NbrOfChannel = 1;  //通道数目1个
  ADC_DMACmd(ADC1, ENABLE);//使能ADC1的DMA请求
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);//使能ADC1
/***========整型转化为字符型======***/
char *int_to_string(int number,char *strnum)
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
         /*翻转*/
for(i=0;i<n/2;i++)
temp=*(strnum+j+i-n);
*(strnum+j+i-n)=*(strnum+j-i-1);
*(strnum+j-i-1)=temp;
strnum[n]='\0';
return strnum;
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
  for(; nCount != 0; nCount--);
int Get_ADC(){
void SPI_TEST()
	printf("\r\n这是一个2M SPI总线flash(W25X16)测试 \r\n");
	SPI_FLASH_Init();//初始化,在头文件中
	/* Get SPI Flash Device ID */
	DeviceID = SPI_FLASH_ReadDeviceID();
	Delay( 200 );
	/* Get SPI Flash ID */
	FlashID = SPI_FLASH_ReadID();
	printf("\r\n FlashID is 0x%X,  Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
	/* Check the SPI Flash ID */
	if (FlashID == sFLASH_ID)  /* #define  sFLASH_ID  0xEF3015 */
		printf("\r\n 检测到华邦flash W25X16 !\r\n");
		/* Erase SPI FLASH Sector to write on */
		SPI_FLASH_SectorErase(FLASH_SectorToErase);
		/*写缓存并发送*/
		SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
		printf("\r\n写入的数据是:%s \r\t", Tx_Buffer);
		/* 读出刚才写入的数据*/
		SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
		printf("\r\n读出的数据是:%s \r\n", Rx_Buffer);
		TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
		if( PASSED == TransferStatus1 )
			printf("\r\n 2M SPI总线flash(W25X16)测试成功!\n\r");
		else
			printf("\r\n 2M SPI总线flash(W25X16)测试失败!\n\r");
	}// if (FlashID == sFLASH_ID)
	else
		printf("\r\n 未检测到 W25X16 ID!\n\r");
	SPI_Flash_PowerDown();
	printf("\r\n=================================================\n\r");
  * @param  None
  * @retval None
int main(void)
    int ADValue = 0,i=0;
    char num[10];
    USART_int(115200);
    ADC_CONFIG();
    delay_ms(1000);
    while(1)
      for(i=0;i<5;i++)
           int_to_string(ADValue,num);
           Tx_Buffer[i]=num[i];
				printf("\r\n转化成功后的字符数:%s\r\n",num);
        SPI_TEST();
        delay_ms(1000);
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
