电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 29作业本【更新全部作业】
共36条 4/4 |‹ ‹ 1 2 3 4 跳转至页
2014-12-21 10:51:28     打赏
31楼
ADC&RGB
这是在之前PWM的基础上简单更改的,加上了ADC的结构体 初始化 还有一些参数,就可以简单控制RGB的颜色了
视频后面再贴
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
#define VREF 3.3
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
    SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
void PWM_Config()
{uint16_t PrescalerValue = 0;
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
    /* TIM2 clock enable */
  /* GPIOA  enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
        TIM_Cmd(TIM2, ENABLE);
      /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
    /* PWM1 Mode configuration: Channel3 */
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
    /* PWM1 Mode configuration: Channel4 */
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
void ADC_CONFIG(){
    ADC_InitTypeDef ADC_InitStructure;
    #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  /* ADCCLK = PCLK2/2 */
  RCC_ADCCLKConfig(RCC_PCLK2_Div2);   //复位ADC1,同时设置分频因子
#else
  /* ADCCLK = PCLK2/4 */
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
#endif
ADC_DeInit(ADC1);
  /* Enable ADC1 and GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
    /* Configure PB0 (ADC Channel14) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;  //ADC工作模式:独立模式
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;  //AD单通道模式
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;  //AD单次转换模式
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;  //转换由软件而不是外部触发启动
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;  //ADC数据右对齐
  ADC_InitStructure.ADC_NbrOfChannel = 1;  //顺序进行规则转换的ADC通道的数目1
  ADC_Init(ADC1, &ADC_InitStructure);  //根据指定参数初始化外设ADC1
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
 int Get_ADC(){
     /* ADC1 regular channel configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);  //规则序列中的第1个转换,采样周期为55.5
    /* Enable ADC1 reset calibration register */
  ADC_ResetCalibration(ADC1);  //执行复位校准
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
   /* Start ADC1 calibration */
  ADC_StartCalibration(ADC1);  //执行ADC校准,开始指定的ADC1的校准状态
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);  //软件开启ADC转换
    return ADC_GetConversionValue(ADC1);
  void PWM_TEST()
    float Volt=0.00;
    unsigned int temp0,temp1,temp2,ADValue = 0;
    while(1)
      ADValue = Get_ADC();
        Volt = VREF*ADValue/4095;
        printf("PWM-RGB & ADC TEST......\r\n\r\n");
        printf("The ADC value is:%d\r\n",ADValue);
        printf("The Volt is:%f V\r\n",Volt);
      TIM_SetCompare2(TIM2, temp0);
      TIM_SetCompare3(TIM2, temp1);
      TIM_SetCompare4(TIM2, temp2);
        if(ADValue>3000)
         {  temp0=ADValue/2;temp1=ADValue/2;temp2=ADValue/2-1500;
				 if(2000<ADValue<=3000)
        {  temp0=ADValue/2;temp1=ADValue/2-1000;temp2=ADValue/2;
				if(1000<ADValue<=2000)
        {  temp0=ADValue/2+1000;temp1=ADValue/2;temp2=ADValue/2;
				if(ADValue<=1000)
        {  temp0=ADValue+500;temp1=ADValue+1500;temp2=ADValue+1000;
            delay_ms(50);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
    RCC_Configuration();
  USART_int(115200);
    ADC_CONFIG();
    printf(" config done...\r\n");
    Get_ADC();
    PWM_Config();
    delay_ms(200);
    while(1)
        PWM_TEST();
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
  #endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  while (1)
#endif
2014-12-25 09:34:39     打赏
32楼
ADC&RGB视频
2014-12-25 15:02:59     打赏
33楼
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
#include <stm32f10x.h>
#include "delay.h"
#include <stdio.h>
#include "spi_flash.h"
#define VREF 3.3
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define RxBufferSize1   (countof(TxBuffer1) - 1)
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define  FLASH_WriteAddress     0x00000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  sFLASH_ID              0xEF3015     //W25X16
//#define  sFLASH_ID              0xEF4015   //W25Q16
#define buff_size  16;
char rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;  //发送缓冲
uint8_t Rx_Buffer[BufferSize];  //接受缓冲
__IO uint32_t DeviceID = 0;  //装置ID
__IO uint32_t FlashID = 0; //闪存ID
__IO TestStatus TransferStatus1 = FAILED;  //状态测试
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)//整形数据转换为字符型
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;i<n/2;i++)
temp=*(strnum+j+i-n);
*(strnum+j+i-n)=*(strnum+j-i-1);
*(strnum+j-i-1)=temp;
strnum[n]='\0';
return strnum;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);  //使能HSI
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08)
    //SystemInit();
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
        - One Stop Bit
        - No parity
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
  for(; nCount != 0; nCount--);
void ADC_CONFIG(){
#else
#endif
ADC_DeInit(ADC1);
  /* Enable ADC1 */
int Get_ADC(){
void SPI_TEST()
	int i=0;
	int ADValue = 0;
	float Volt=0.00;
     char shuzu[100];
	 for(i=0;i<5;i++)
		printf("===============================\r\n");
			delay_ms(500);
	printf("\r\n这是一个2M SPI总线flash(W25X16)测试 \r\n");
	SPI_FLASH_Init();
	/* Get SPI Flash Device ID */
	DeviceID = SPI_FLASH_ReadDeviceID();
	Delay( 200 );
	/* Get SPI Flash ID */
	FlashID = SPI_FLASH_ReadID();
	printf("\r\n FlashID is 0x%X,  Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
	/* Check the SPI Flash ID */
	if (FlashID == sFLASH_ID)  /* #define  sFLASH_ID  0xEF3015 */
		printf("\r\n 检测到华邦flash W25X16 !\r\n");
		/* Erase SPI FLASH Sector to write on */
		SPI_FLASH_SectorErase(FLASH_SectorToErase);
		/*写缓存并发送*/
		SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
		printf("\r\n写入的数据是:%s \r\t", Tx_Buffer);
		/* 读出刚才写入的数据*/
		SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
		printf("\r\n读出的数据是:%s \r\n", Rx_Buffer);
		TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
		if( PASSED == TransferStatus1 )
			printf("\r\n 2M SPI总线flash(W25X16)测试成功!\n\r");
		else
			printf("\r\n 2M SPI总线flash(W25X16)测试失败!\n\r");
	}// if (FlashID == sFLASH_ID)
	else
		printf("\r\n 未检测到 W25X16 ID!\n\r");
	SPI_Flash_PowerDown();
	printf("\r\n=================================================\n\r");
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  USART_int(115200);
    ADC_CONFIG();
	 Get_ADC();
    delay_ms(1000);
	    while(1)
      SPI_TEST();
        delay_ms(1000);
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-12-25 15:04:54     打赏
34楼
只是简单的改了下老师的代码
  * @version V3.5.0
  * @attention
	© COPYRIGHT 2011 STMicroelectronics
#include "delay.h"
#include
volatile int flag;
#define Set_B20()	 GPIO_SetBits(GPIOC, GPIO_Pin_12) //上拉关闭PC12
#define Reset_B20()	 GPIO_ResetBits(GPIOC, GPIO_Pin_12)//下拉打开PC12
#define Read_B20()	 GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)//读PC12状态
unsigned char Error_Flag=0;
unsigned char zf=0;
void SysTick_Configuration(void)
  /* Setup SysTick Timer for 10 msec interrupts  */
  if (SysTick_Config(48000))                //SysTick配置48000/48ms=1ms
    /* Capture error */
    while (1);
 /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);                       //SysTick中断优先级
  RCC_DeInit(); //将外设RCC重新设为默认值
  RCC_HSICmd(ENABLE);//使能HSI高速内部时钟 8MHZ
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);  //当SHI晶振就绪则重新设定
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//设置系统时钟,时钟源为HSI
  RCC_HSEConfig(RCC_HSE_OFF);//设置外部高速晶振,HSE晶振OFF
  RCC_LSEConfig(RCC_LSE_OFF); //设置外部低速晶振,LSE晶振OFF
	   /******配置PLL时钟频率为48MHZ*******/
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6); //   RCC_PLLMul_ 即设置PLL时钟频率为 6*8 MHz
  RCC_PLLCmd(ENABLE);//使能PLL
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);//PLL就绪
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);//  ADC时钟=PCLK/2
  RCC_PCLK2Config(RCC_HCLK_Div1);//  APB2时钟=HCLK
  RCC_PCLK1Config(RCC_HCLK_Div2);// APB1时钟=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);//  AHB时钟=系统时钟
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // 选择PLL为系统时钟
  while(RCC_GetSYSCLKSource() != 0x08);//当PLL不是系统时钟
//	SystemInit();
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//使能TIM2时钟
        - One Stop Bit
        - No parity
void delay_18b20(u32 nus) //18b20按照严格的时序工作,专属延时
	u16 i;
	while(nus--)
		for(i=12;i>0;i--);
void Init18B20(void)  //18B20初始化
   u8 aa=0;
   u8 count =0;
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//选择PC12
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出
   Set_B20() ; //拉高
   delay_18b20(1);  //复位时需要至少480us的低电平,当18b20接收到此信号后会回发芯片一个存在脉冲
   Reset_B20(); //拉低
   delay_18b20(480);
   Set_B20();//拉高
   delay_18b20(480);
	count=0;  //读取18B20的温度 赋值给aa
	 /*   校验读取值,错误次数大于99才报错 */
	aa=Read_B20();
    while(!aa && count<100)
   	aa=Read_B20();
	count++;
   if(count>=99) //次数大于99次,那么报错,标志位为1
   		Error_Flag=1;
	else
		Error_Flag=0;   //次数未达到99次,正常工作
unsigned char Read18B20(void)//读取18B20的一个字节
unsigned char i=0;
unsigned char date=0;
u8 tempp;
   for(i=8;i>0;i--)//按位读取,读取一个字需要循环8次
   Reset_B20();//拉低电平,读数
   date>>=1;//右移一位
   delay_18b20(1);
   Set_B20();  //拉高电平,关闭
    delay_18b20(1);
   tempp=Read_B20();//读取温度值
   if(tempp)//若读取到的值非0
   		date|=0x80; //将date的最高位置1  1000 0000   然后右移,每次最高位由0变1,使8位全部传递完毕 0xff = 1111 1111
	delay_18b20(60);
	return(date);
void Write18B20(unsigned char date)//写入数据
	unsigned char i=0;
	for (i=8; i>0; i--)
		Reset_B20(); //置低电平
		delay_18b20(1);
		if(date & 0x01)			 //如果date最低位为1
			Set_B20();//置高电平
		else
		{	Reset_B20();}
		delay_18b20(60);
		date>>=1; 	 //date右移一位
		 Set_B20();//置高电平
		 delay_18b20(1);
	delay_18b20(15);
 float Read_T()//读取温度值
		unsigned char TUp,TDown;
	unsigned char fTemp;
	u8 TT=0;
	 float Temp = 0;
	Init18B20();//1820初始化
	Write18B20(0xcc); 	 //不提供64位ROM编码使用存储器
	Write18B20(0x44); 	 //启动一次温度转换
	Write18B20(0xbe); 	 //从字节0开始读取暂存器内容
	  /*两次读取温度*/
	TDown = Read18B20();
	TUp = Read18B20();
	if(TUp>0x7f)      //  如果TUp的值大于最大值(11111111)bin
		TDown=~TDown;   //TDown取反
		TUp=~TUp+1; //TUp取反加一
		TUp/=8;		      //TUp除以8
		zf=1;         //zf标志位置1
	else
		zf=0;
	fTemp=TDown&0x0f;		//TDown保留后四位,赋值给fTemp
	TUp<<=4;//TUp左移四位,舍去高四位
	TDown>>=4;//TDown右移四位,舍去低四位
	TT=TUp|TDown;//TUp与TDown合并 赋值给TT
	Temp=TT+(float)fTemp/16;
	return(Temp);
int main(void)
	 int i;  	unsigned char ID[8];
USART_int(115200);
	Init18B20();//初始化18B20
	SysTick_Configuration();//系统滴答时钟配置
 Write18B20(0x33);//此命令获取18B20的ID
	 for(i=0;i<8;i++)//用一个8位的数组保存id值
        ID[i]=Read18B20();
	delay_ms(1000);
	while(1)
		if(flag == 500){
			printf("The Temperature is:%f\r\n",Read_T());//500us读一次温度
  if(flag == 300){         //300us读一次id
              printf("The id is:");
                for(i=0;i<8;i++)
                printf("%u",ID[i]);
                    if(i==7){printf("\r\n");    }
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
注意一下添加几个头文件
2015-01-06 21:38:15     打赏
35楼
其实这个作业也不错,希望能坚持下去
2015-01-06 22:28:55     打赏
36楼
没毕业之前还是会坚持的
