RGB&七彩灯代码作业
#include "stm32f10x.h" #include "stm32_eval.h" #include <stdio.h> #define VREF 3.3 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; void RCC_Configuration(void) { SystemInit(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure); USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); } void PWM_Config() {uint16_t PrescalerValue = 0;//预分频器值 TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* TIM2 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); /* GPIOA enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO , ENABLE);//使能复用功能时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); TIM_Cmd(TIM2, ENABLE);//TIM2使能 /* Compute the prescaler value */ PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1; /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 0x07FF;//设置自动重装载 TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;//设置预分频值 TIM_TimeBaseStructure.TIM_ClockDivision = 0;//设置时钟分割TDTS=Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//向上计数 TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);//根据指定参数初始化TIMx TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//选择PWM模式1 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//输出极性高 /* PWM1 Mode configuration: Channel2 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0xFFFF;//通道占空比时间 TIM_OC2Init(TIM2, &TIM_OCInitStructure);//初始化TIM2 OC2 /* PWM1 Mode configuration: Channel3 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//比较输出使能 TIM_OCInitStructure.TIM_Pulse = 0xFFFF;//通道占空比时间 TIM_OC3Init(TIM2, &TIM_OCInitStructure);//初始化TIM2 OC3 /* PWM1 Mode configuration: Channel4 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0xFFFF;//通道占空比时间 TIM_OC4Init(TIM2, &TIM_OCInitStructure);//初始化TIM2 OC4 TIM_ARRPreloadConfig(TIM2, ENABLE);//使能预装载寄存器 } void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) { while(n--) delay_us(1000); } void PWM_TEST() { unsigned int temp0,temp1,temp2; printf("PWM-RGB TEST......\r\n"); while(1) { if(temp0=2000,temp1=2000,temp2=0) {TIM_SetCompare2(TIM2,temp0);delay_ms(500); TIM_SetCompare3(TIM2,temp1);delay_ms(500); TIM_SetCompare4(TIM2,temp2);delay_ms(500); } if(temp0=1900,temp1=0,temp2=1900) {TIM_SetCompare2(TIM2,temp0);delay_ms(500); TIM_SetCompare3(TIM2,temp1);delay_ms(500); TIM_SetCompare4(TIM2,temp2);delay_ms(500); } if(temp0=0,temp1=2000,temp2=2000) {TIM_SetCompare2(TIM2,temp0);delay_ms(400); TIM_SetCompare3(TIM2,temp1);delay_ms(500); TIM_SetCompare4(TIM2,temp2);delay_ms(500); } if(temp0=250,temp1=1700,temp2=1700) {TIM_SetCompare2(TIM2,temp0);delay_ms(500); TIM_SetCompare3(TIM2,temp1);delay_ms(500); TIM_SetCompare4(TIM2,temp2);delay_ms(500); } if(temp0=500,temp1=300,temp2=1800) {TIM_SetCompare2(TIM2,temp0);delay_ms(500); TIM_SetCompare3(TIM2,temp1);delay_ms(500); TIM_SetCompare4(TIM2,temp2);delay_ms(500); } if(temp0=400,temp1=1500,temp2=1000) {TIM_SetCompare2(TIM2,temp0);delay_ms(500); TIM_SetCompare3(TIM2,temp1);delay_ms(500); TIM_SetCompare4(TIM2,temp2);delay_ms(500); } if(temp0=1300,temp1=800,temp2=1200) {TIM_SetCompare2(TIM2,temp0);delay_ms(500); TIM_SetCompare3(TIM2,temp1);delay_ms(500); TIM_SetCompare4(TIM2,temp2);delay_ms(500); } } } int main(void) { RCC_Configuration(); USART_int(115200); printf(" config done...\r\n"); PWM_Config(); delay_ms(1000); while(1) { PWM_TEST(); } } #ifdef USE_FULL_ASSERT void assert_failed(uint8_t* file, uint32_t line) {while (1) { } } #endif #ifdef __GNUC__ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ PUTCHAR_PROTOTYPE { USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT etval None */ void assert_failed(uint8_t* file, uint32_t line) { while (1) { } } #endif
ADC 控制RGB颜色作业代码与视频
视频地址:http://player.youku.com/player.php/sid/XODU2NDc2Mzc2/v.swf
这是在之前PWM的基础上简单更改的,加上了ADC的结构体 初始化 还有一些参数.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h" #include "stm32_eval.h" #include #define VREF 3.3 /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; void RCC_Configuration(void) { SystemInit(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate;//?????? USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1 USART_InitStructure.USART_Parity = USART_Parity_No;//???? USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//?????????? USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure); USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); } void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) { while(n--) delay_us(1000); } void PWM_Config() {uint16_t PrescalerValue = 0; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* TIM2 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); /* GPIOA enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO , ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); TIM_Cmd(TIM2, ENABLE); /* Compute the prescaler value */ PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1; /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 0x07FF; TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; /* PWM1 Mode configuration: Channel2 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0xFFFF; TIM_OC2Init(TIM2, &TIM_OCInitStructure); /* PWM1 Mode configuration: Channel3 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0xFFFF; TIM_OC3Init(TIM2, &TIM_OCInitStructure); /* PWM1 Mode configuration: Channel4 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0xFFFF; TIM_OC4Init(TIM2, &TIM_OCInitStructure); TIM_ARRPreloadConfig(TIM2, ENABLE); } void ADC_CONFIG(){ ADC_InitTypeDef ADC_InitStructure; #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL) /* ADCCLK = PCLK2/2 */ RCC_ADCCLKConfig(RCC_PCLK2_Div2); //复位ADC1,同时设置分频因子 #else /* ADCCLK = PCLK2/4 */ RCC_ADCCLKConfig(RCC_PCLK2_Div4); #endif ADC_DeInit(ADC1); /* Enable ADC1 and GPIOC clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE); /* Configure PB0 (ADC Channel14) as analog input -------------------------*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOB, &GPIO_InitStructure); /* ADC1 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:独立模式 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //AD单通道模式 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //AD单次转换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //转换由软件而不是外部触发启动 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐 ADC_InitStructure.ADC_NbrOfChannel = 1; //顺序进行规则转换的ADC通道的数目1 ADC_Init(ADC1, &ADC_InitStructure); //根据指定参数初始化外设ADC1 /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); } int Get_ADC(){ /* ADC1 regular channel configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5); //规则序列中的第1个转换,采样周期为55.5 /* Enable ADC1 reset calibration register */ ADC_ResetCalibration(ADC1); //执行复位校准 /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); /* Start ADC1 calibration */ ADC_StartCalibration(ADC1); //执行ADC校准,开始指定的ADC1的校准状态 /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); /* Start ADC1 Software Conversion */ ADC_SoftwareStartConvCmd(ADC1, ENABLE); //软件开启ADC转换 return ADC_GetConversionValue(ADC1); } void PWM_TEST() { float Volt=0.00; unsigned int temp0,temp1,temp2,ADValue = 0; while(1) { ADValue = Get_ADC(); Volt = VREF*ADValue/4095; printf("PWM-RGB & ADC TEST......\r\n\r\n"); printf("The ADC value is:%d\r\n",ADValue); printf("The Volt is:%f V\r\n",Volt); TIM_SetCompare2(TIM2, temp0); TIM_SetCompare3(TIM2, temp1); TIM_SetCompare4(TIM2, temp2); if(ADValue>3000) { temp0=ADValue/2;temp1=ADValue/2;temp2=ADValue/2-1500; } if(2000Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT void assert_failed(uint8_t* file, uint32_t line) { while (1) { } } #endif
IIC-计上电次数作业代码
#include "stm32f10x.h" #include "stm32_eval.h" #include #define VREF 3.3 unsigned char i=0; void EXTIkeyS1_Config(void); /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); //SystemInit(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate;//?????? USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1 USART_InitStructure.USART_Parity = USART_Parity_No;//???? USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//?????????? USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure); USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); /* Configure four bit for preemption priority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4); /* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; // NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } void IIc2_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; I2C_InitTypeDef I2C_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE); //PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA /* Configure IO connected to IIC*********************/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; GPIO_Init(GPIOB, &GPIO_InitStructure); I2C_InitStructure.I2C_Mode = I2C_Mode_I2C; I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2; I2C_InitStructure.I2C_OwnAddress1 = 0xA0; I2C_InitStructure.I2C_Ack = I2C_Ack_Enable; I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; I2C_InitStructure.I2C_ClockSpeed = 400000; I2C_Cmd(I2C2, ENABLE); I2C_Init(I2C2, &I2C_InitStructure); I2C_AcknowledgeConfig(I2C2, ENABLE); } void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte) { while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)); I2C_GenerateSTART(I2C2,ENABLE); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT)); I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); I2C_SendData(I2C2, write_address); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_SendData(I2C2, byte); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_GenerateSTOP(I2C2, ENABLE); do { /* Send START condition */ I2C_GenerateSTART(I2C2, ENABLE); /* Read I2C2 SR1 register */ /* Send EEPROM address for write */ I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter); }while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002)); /* Clear AF flag */ I2C_ClearFlag(I2C2, I2C_FLAG_AF); /* STOP condition */ I2C_GenerateSTOP(I2C2, ENABLE); } unsigned char I2C2_ReadByte(unsigned char id, unsigned char read_address) { unsigned char temp; while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){} I2C_GenerateSTART(I2C2, ENABLE); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT)); I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); I2C_Cmd(I2C2, ENABLE); I2C_SendData(I2C2, read_address); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_GenerateSTART(I2C2, ENABLE); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT)); I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver); while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)); I2C_AcknowledgeConfig(I2C2, DISABLE); I2C_GenerateSTOP(I2C2, ENABLE); while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED))); temp = I2C_ReceiveData(I2C2); I2C_AcknowledgeConfig(I2C2, ENABLE); return temp; } /*delay_us*/ void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } /*delay_ms*/ void delay_ms(u32 n) { while(n--) delay_us(1000); } int main(void) { RCC_Configuration(); EXTIkeyS1_Config(); USART_int(115200); IIc2_Init(); printf(" config done...\r\n"); i = I2C2_ReadByte(0xA0,0);//向0x00读取数据 printf("从地址0x00读出数据 :%d\r\n",i); i++; I2C2_WriteByte(0xA0,0,i);//向0x00写入数据 printf("向地址0x00写入数据 :%d\r\n",i); while(1) { delay_ms(1000); printf(" 上电次数为%d\r\n",i); } } void EXTIkeyS1_Config(void)//S1 PC8 { /* Enable GPIOA clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); /* Configure PA.00 pin as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;//PC8 S1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOC, &GPIO_InitStructure); /* Enable AFIO clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8); EXTI_InitStructure.EXTI_Line = EXTI_Line8; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } void EXTI9_5_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line8) != RESET) { i=0; I2C2_WriteByte(0xA0,0,0); printf(" 上电次数为%d\r\n",i); /* Clear the EXTI line 8 pending bit */ EXTI_ClearITPendingBit(EXTI_Line8); } } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif
打赏帖 | |
【STM32F769】AI之与本地deepseek对接被打赏50分 | |
Buck电路工作在CCM模式下电感电流的计算公式是什么?被打赏5分 | |
buck电路工作原理被打赏5分 | |
基于MSPM0L1306的MODBUS-RTU协议通讯实验被打赏100分 | |
我想要一部加热台+多合一调试工具被打赏18分 | |
每周了解几个硬件知识+485硬件知识分享被打赏10分 | |
【换取手持数字示波器】树莓派PICO调试器官方固件本地化部署实践被打赏24分 | |
【换取手持数字示波器】分享一个KEIL无法识别CMSIS-DAP调试器的解决办法被打赏20分 | |
【换取手持数字示波器】分享一个自制的ArduinoNano扩展板底板被打赏23分 | |
【换取手持示波器】树莓派PICOW网页烟花被打赏18分 |
