其实有试过的,把S2键的中断放进来,i置零,void EXTIkeyS2_Config(void);也有
可是这样不知道为什么记数就记不了,按下S1键就显示1,然后怎么按都没反应了
/** ****************************************************************************** * @file EXTI/EXTI_Config/main.c * @author MCD Application Team * @version V3.5.0 * @date 08-April-2011 * @brief Main program body ****************************************************************************** * @attention * * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. * * <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2> ****************************************************************************** */
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h" #include "stm32_eval.h" #include volatile int flag; #define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12) #define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12) #define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12) unsigned char Error_Flag=0; unsigned char zf=0; unsigned char ID[8]; void SysTick_Configuration(void) { /* Setup SysTick Timer for 1 msec interrupts */ if (SysTick_Config(48000)) //SysTick配置 48000/48MHZ=1ms 滴答一次 { /* Capture error */ while (1); } /* Configure the SysTick handler priority */ NVIC_SetPriority(SysTick_IRQn, 0x0); //SysTick中断优先级 } GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; #define RCC_PLLSource_HSE_Div1 ((uint32_t)0x00010000) void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6); // 6*8Mhz= 48MHz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); // SystemInit(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate;//?????? USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1 USART_InitStructure.USART_Parity = USART_Parity_No;//???? USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//?????????? USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure); USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); } void delay_18b20(u32 nus) { u16 i; while(nus--) for(i=12;i>0;i--); } /*delay_us*/ void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } /*delay_ms*/ void delay_ms(u32 n) { while(n--) delay_us(1000); } void Init18B20(void)//18B20初始化 { u8 aa=0; u8 count =0; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //GPIOC的复用时钟使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//选择PC12 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出 GPIO_Init(GPIOC, &GPIO_InitStructure);//GPIOC初始化 Set_B20() ; /*复位时需要至少480us的低电平*/ delay_18b20(1); Reset_B20(); delay_18b20(480); /* 探测到上升沿后等待15~60us后18B20发出存在脉冲 */ Set_B20(); delay_18b20(480); count=0; aa=Read_B20();//读取18B20的一个字节 赋值给aa /* 校验读取值,错误次数大于99才报错 */ while(!aa && count<100) { aa=Read_B20(); count++; } if(count>=99) Error_Flag=1; else Error_Flag=0; } unsigned char Read18B20(void)//读取18B20的一个字节 { unsigned char i=0; unsigned char date=0; u8 tempp; for(i=8;i>0;i--)//按位读取,读取一个字需要循环8次 { Reset_B20();//拉低电平 date>>=1;//date右移一位 delay_18b20(1); Set_B20(); //置高电平 delay_18b20(1); tempp=Read_B20();//读取温度值 if(tempp)//若读取到的值非0 {date|=0x80;} //将date的最高位置1 delay_18b20(60); } return(date); } void Write18B20(unsigned char date)//写入 { unsigned char i=0; for (i=8; i>0; i--) { Reset_B20(); //置低电平 delay_18b20(1); if(date & 0x01) //如果date最低位为1 { Set_B20();//置高电平 } else//如果date最低位为0 { Reset_B20();}//置低电平 delay_18b20(60); date>>=1; //date右移一位 Set_B20();//置高电平 delay_18b20(1); } delay_18b20(15); } float Read_T()//读取温度值 { unsigned char TUp,TDown; unsigned char fTemp; u8 TT=0; float Temp = 0; Init18B20();//1820初始化 Write18B20(0xcc); //不提供64位ROM编码使用存储器 Write18B20(0x44); //启动一次温度转换 Init18B20();//1820初始化 Write18B20(0xcc); //不提供64位ROM编码使用存储器 Write18B20(0xbe); //从字节0开始读取暂存器内容 /*两次读取温度*/ TDown = Read18B20(); TUp = Read18B20(); if(TUp>0x7f) // 如果TUp的值大于最大值(11111111)bin { TDown=~TDown; //TDown取反 TUp=~TUp+1; //TUp取反加一 TUp/=8; //TUp除以8 zf=1; //zf标志位置1 } else zf=0; fTemp=TDown&0x0f;//TDown保留后四位,赋值给fTemp TUp<<=4;//TUp左移四位,舍去高四位 TDown>>=4;//TDown右移四位,舍去低四位 TT=TUp|TDown;//TUp与TDown合并 赋值给TT Temp=TT+(float)fTemp/16; return(Temp); } int main(void) { int i; RCC_Configuration(); USART_int(115200); Init18B20();//初始化18B20 SysTick_Configuration();//系统滴答时钟配置 printf(" config done...\r\n"); Write18B20(0x33);//此命令获取18B20的ID for(i=0;i<8;i++)//用一个8位的数组保存id值 { ID[i]=Read18B20(); } delay_ms(1000); while(1) { if(flag==300)//300ms输出一次id { printf("\r\nevent 1 oc......\r\n"); printf("The id is :\r\n"); for(i=0;i<8;i++) { printf("%x",ID[i]); } } else if(flag==500)//500ms输出一次温度 { printf("\r\nevent 2 oc......\r\n"); printf("The Temperature is:%f\r\n",Read_T()); } } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif /** * @} */ /** * @} */ #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
怎么感觉又是keil5的问题才会这样啊- -
