#include "stm32f10x.h"
#include "stm32_eval.h"
#include
#define VREF 3.3
unsigned char i=0;
EXTI_InitTypeDef EXTI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
//SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* PA10 USART1_Rx */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = BaudRate;//??????
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
USART_InitStructure.USART_Parity = USART_Parity_No;//????
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void GPIO_INIT()
RCC_Configuration();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
void Iic1_Init(void)
I2C_InitTypeDef I2C_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
//PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
/* Configure IO connected to IIC*********************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0xA0;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = 400000;
I2C_Cmd(I2C2, ENABLE);
I2C_Init(I2C2, &I2C_InitStructure);
I2C_AcknowledgeConfig(I2C2, ENABLE);
/*IIC????? */
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));//?????????-??????
I2C_GenerateSTART(I2C2,ENABLE);//??i2c2??????
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));//??????i2c???????
I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);//?????i2c???????
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_SendData(I2C2, write_address);//??i2c??????
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_SendData(I2C2, byte);
I2C_GenerateSTOP(I2C2, ENABLE);//??i2c2??????
do
/* Send START condition */
I2C_GenerateSTART(I2C2, ENABLE);
/* Read I2C2 SR1 register */
/* Send EEPROM address for write */
I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
}while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));//?????i2c????????
/* Clear AF flag */
I2C_ClearFlag(I2C2, I2C_FLAG_AF);
/* STOP condition */
unsigned char I2C2_ReadByte(unsigned char id, unsigned char read_address)
unsigned char temp;
while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
I2C_SendData(I2C2, read_address);
I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
I2C_AcknowledgeConfig(I2C2, DISABLE);
while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
temp = I2C_ReceiveData(I2C2);
return temp;
void anjian3_Config(void)
/* Enable GPIOA clock */
/* Configure PA.00 pin as input floating */
/* Enable AFIO clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
/* Connect EXTI0 Line to PA.00 pin */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource10);
/* Configure EXTI0 line */
EXTI_InitStructure.EXTI_Line = EXTI_Line10;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable and set EXTI0 Interrupt to the lowest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void IIC_TEST()
printf(" config done...\r\n");
i = I2C2_ReadByte(0xA0,0);
i++;
printf("向地址第%d次写入数据
\n",i);
I2C2_WriteByte(0xA0,0,i);
printf("向地址第%d次读出数据
\n",i);
printf("第%d次上电....\r\n",i);
int main(void)
anjian3_Config();
GPIO_INIT();
USART_int(115200);
Iic1_Init();
IIC_TEST();
void EXTI15_10_IRQHandler(void)
if(EXTI_GetITStatus(EXTI_Line10) != RESET)
i=0;
I2C2_WriteByte(0xA0,0,0);
delay_ms(200);
printf("上电立即清0\r\n",i);
/* Clear the EXTI line 8 pending bit */
EXTI_ClearITPendingBit(EXTI_Line10);
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
while (1)
#endif
#ifdef __GNUC__
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
USART_SendData(EVAL_COM1, (uint8_t) ch);
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
* @file EXTI/EXTI_Config/main.c
* @author MCD Application Team
* @version V3.5.0
* @date 08-April-2011
* @brief Main program body
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
? COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
long flag,temp,num;
RCC_DeInit();
RCC_HSICmd(ENABLE);
RCC_PLLCmd(ENABLE);
SystemInit();
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
- One Stop Bit
- No parity
void NVIC_Configuration(void)
/* Enable the TIM2 global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 24000;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
/*NVIC_InitStructure.NVIC_IRQChannel =TIM8_CC_IRQn;
NVIC_Init(&NVIC_InitStructure);*/
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f10x_xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f10x.c file
/* System Clocks Configuration */
NVIC_Configuration();
USART_int(115200);
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE );
TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure);
TIM_ITConfig(TIM7,TIM_IT_Update,ENABLE );
/* TIM2 enable counter */
TIM_Cmd(TIM2, ENABLE);
TIM_Cmd(TIM3, ENABLE);
TIM_Cmd(TIM7, ENABLE);
while (1){
if(flag == 2000)
{printf("TIM2 interrupt......\r\n");
flag = 0;
GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3);
//delay_ms(80)
if(temp == 3000)
{printf("TIM3 interrupt......\r\n");
temp = 0;
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
if(num == 1000)
{printf("TIM7 interrupt......\r\n");
num = 0;
/*GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
delay_ms(150);*/
GPIO_ResetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
void TIM2_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //?? TIM3 ??????
flag++;
void TIM3_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //?? TIM3 ??????
temp++;
void TIM7_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM7, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM7, TIM_IT_Update ); //?? TIM3 ??????
num++;
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#else
* @brief Retargets the C library printf function to the USART.
* @param None
* @retval None
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
/* Loop until the end of transmission */
return ch;
* @retval None
/* Infinite loop */
while (1)
#endif
<P>
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
</P>
<P>
</P>
<P>
</P>
| 为遥控小车巧添功能被打赏¥26元 | |
