view plaincopy to clipboardprint?
#include "stm32f10x.h"
#include "stm32_eval.h"
#include
#define VREF 3.3
unsigned char i=0;
EXTI_InitTypeDef   EXTI_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
    //SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;e
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void GPIO_INIT()
  RCC_Configuration();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
void Iic1_Init(void)
        I2C_InitTypeDef I2C_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
        //PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
        /* Configure IO connected to IIC*********************/
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStructure.I2C_OwnAddress1 = 0xA0;
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_InitStructure.I2C_ClockSpeed = 400000;
        I2C_Cmd(I2C2, ENABLE);
        I2C_Init(I2C2, &I2C_InitStructure);
        I2C_AcknowledgeConfig(I2C2, ENABLE);
/*IIC?????        */
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
        I2C_GenerateSTART(I2C2,ENABLE);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));
        I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        I2C_SendData(I2C2, write_address);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        I2C_SendData(I2C2, byte);
        I2C_GenerateSTOP(I2C2, ENABLE);
        do
                /* Send START condition */
                I2C_GenerateSTART(I2C2, ENABLE);
                /* Read I2C2 SR1 register */
                /* Send EEPROM address for write */
                I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
        }while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));
        /* Clear AF flag */
        I2C_ClearFlag(I2C2, I2C_FLAG_AF);
        /* STOP condition */
unsigned char I2C2_ReadByte(unsigned char  id, unsigned char read_address)
        unsigned char temp;
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
          I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
          I2C_SendData(I2C2, read_address);
          I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
          while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
    I2C_AcknowledgeConfig(I2C2, DISABLE);
    while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
    temp = I2C_ReceiveData(I2C2);
        return temp;
void EXTIkeyS1_Config(void)
  /* Enable GPIOA clock */
  /* Configure PA.00 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void EXTI9_5_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line8) != RESET)
        i=0;
        I2C2_WriteByte(0xA0,0,0);
       printf("上电清0\r\n",i);
    /* Clear the  EXTI line 8 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line8);
 void IIC_TEST()
   printf(" config done...\r\n");
    i = I2C2_ReadByte(0xA0,0);
    i++;
    printf("从地址读出数据:%d\r\n",i);
    I2C2_WriteByte(0xA0,0,i);
      printf("向地址输入数据:%d\r\n",i);
    printf("上电次数%d\r\n",i);
int main(void)
     /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  EXTIkeyS1_Config();
  GPIO_INIT();
  USART_int(115200);
  Iic1_Init();
  IIC_TEST();
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
#ifdef __GNUC__
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
