语句是这个意思
我最想知道的是
为什么要判断奇偶?
串口控制led,流水灯顺时针流,逆时针流,z型:
#include "stm32f10x.h" #include "stm32_eval.h" #include "stdio.h" #define buff_size 16; //宏定义一个buff_size=16 GPIO_InitTypeDef GPIO_InitStructure; //结构体的命名 char rx_buff[],rx_buff_count=0; //定义一个字符型数组 rx_buff[] ,并且定义一个字符变量rx_buff_count=0 void RCC_Configuration(void) { RCC_DeInit(); //复位外设RCC的所有寄存器至缺省值(默认值) RCC_HSICmd(ENABLE); //使能外设RCC高速内部时钟 while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); //判断RCC的标志位是否被RESET RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); //配置系统的嘀嗒时钟函数 RCC_HSEConfig(RCC_HSE_OFF); //关闭高速外部时钟 RCC_LSEConfig(RCC_LSE_OFF); //关闭低速外部时钟 RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); //使能外设PLL while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //判断RCC的标志位是否被RESET RCC_ADCCLKConfig(RCC_PCLK2_Div4); ADC速率为RCC_PCLK2/4 ,配置低速ADC时钟等于SYSCLK/4 RCC_PCLK2Config(RCC_HCLK_Div1); // 配置高速APB时钟等于SYSCLK RCC_PCLK1Config(RCC_HCLK_Div2); //配置低速APB时钟等于SYSCLK/2 RCC_HCLKConfig(RCC_SYSCLK_Div1); //配置AHB时钟 AHB时钟等于SYSCLK RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //配置系统时钟SYSCLK=PLL时钟 while(RCC_GetSYSCLKSource() != 0x08); //关闭蜂鸣器 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //使能外设 GPIOD端口时钟 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //端口配置PD.2 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; ;//GPIO速率 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; ;/GPIO输出模式 GPIO_Init(GPIOD, &GPIO_InitStructure); //应用结构体的成员 GPIO_ResetBits(GPIOD,GPIO_Pin_2); //重置GPIOD.2 } void GPIO_INIT() //输入输出的初始化 { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //使能外设GPIOC端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; //端口配置PC.0至PC.7 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; ;//GPIO速率 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //GPIOS输出模式 (推挽输出) GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC.0至GPIOC.7 GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); //根据设定参数初始化GPIOC.0至GPIOC.7输出为 高电平 } void delay_us(u32 n) //延时1us { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) //延时1ms { while(n--) delay_us(1000); } void USART_int(long BaudRate) // USART的初始化 { USART_InitTypeDef USART_InitStructure; //结构体的命名 USART_ClockInitTypeDef USART_ClockInitStructure; // 结构体USART_ClockInit的命名 NVIC_InitTypeDef NVIC_InitStructure; // 结构体 NVIC_Init的命名 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE); //使能外设GPIOC端口时钟和外设APB2下的USART1 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //端口配置PC.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; //GPIO速率为10MHz GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //GPIOS输出模式 GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化,引用结构的的成员 /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //端口配置PC.10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //使能外设GPIOC端口时钟 GPIO_Init(GPIOA, &GPIO_InitStructure); /根据设定参数初始化,引用结构的的成员 /* USARTx configured as follow: - BaudRate = 115200 baud //波特率设置为115200 - Word Length = 8 Bits //字长为8位数据格式 - One Stop Bit //一位停止位 - No parity //无奇偶校验位 - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate; //波特率设置为115200 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1; //一位停止位 USART_InitStructure.USART_Parity = USART_Parity_No; //无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;////收发模式 USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; //失能 USART的端口时钟 USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure); //初始化USART1时钟 USART_Init(USART1, &USART_InitStructure); //初始化USART1 USART_Cmd(USART1, ENABLE); //使能外设RCC USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); //使能USART1 /* Configure four bit for preemption priority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4); //优先级 /* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; // //选择USART1中断通道 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能中断 NVIC_Init(&NVIC_InitStructure); //初始化中断 } void USART_SendStr(char *str) //USART发送数据 { while((*str)!='\0') {USART_SendData(USART1,*str++); while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); } } char strcmp(char *S,char *C,char LEN) //比较字符串是否相等 { char count; for(count=0;count<LEN;count++) { if(S[count]!=C[count]) {return 0;} //不相等 返回0 } return 1; //相等 返回值为1 } void commcmp(char *S,char LEN) //比较字符串的长度 用switch语句 { int i,j; unsigned char flag=0; if((LEN!=7)&(LEN!=8)&(LEN!=9)) {USART_SendStr("\r\n Erro input!!!\r\n");} else{ switch(LEN) { case 7: { flag = strcmp(S,"time=50",7); if(flag==1) { for(i=0;i<=18;i++) //循环19次 { GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6| GPIO_Pin_7); //输出高电平 i=0x01; GPIO_ResetBits(GPIOC,i); delay_ms(50); GPIO_SetBits(GPIOC,i); for(j=1;j<=3;j++) { i<<=1; GPIO_ResetBits(GPIOC,i); delay_ms(50); GPIO_SetBits(GPIOC,i); } i=0x0100; for(j=1;j<=4;j++) { i>>=1; GPIO_ResetBits(GPIOC,i); delay_ms(50); GPIO_SetBits(GPIOC,i); } } break; } } case 8: { flag = strcmp(S,"time=100",8); if(flag==1) { for(i=0;i<=18;i++) { i=0x0010; for(j=1;j<=4;j++) { i>>=1; GPIO_ResetBits(GPIOC,i); delay_ms(100); GPIO_SetBits(GPIOC,i); } i=0x08; for(j=1;j<=4;j++) { i<<=1; GPIO_ResetBits(GPIOC,i); delay_ms(100); GPIO_SetBits(GPIOC,i); } } break; } } case 9: { flag = strcmp(S,"time=1000",9); if(flag==1) { for(i=0;i<=18;i++) { GPIO_SetBits(GPIOC,0x000000ff); i=0x00100; for(j=1;j<=8;j++) { i>>=1; GPIO_ResetBits(GPIOC,i); delay_ms(1000); GPIO_SetBits(GPIOC,i); } } break; } } } } } void input_ASK() { char j; commcmp(rx_buff,rx_buff_count); rx_buff_count=0; for (j=0;j<rx_buff_count;j++) {rx_buff[j]='\0';} USART_SendStr("\n>"); } int main(void) { RCC_Configuration(); GPIO_INIT(); USART_int(9600); USART_SendStr("SyStem booting......\r\n"); while(1){} } void USART1_IRQHandler(void) // USART1中断服务函数 { while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET) { } if(USART_ReceiveData(USART1)==0x0d) {input_ASK();} else { USART_SendData(USART1,USART_ReceiveData(USART1)); rx_buff[rx_buff_count]= USART_ReceiveData(USART1); rx_buff_count++; } USART_ClearFlag(USART1, USART_FLAG_RXNE); }
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
