电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » EDA第五次作业
EDA第五次作业
2014-10-30 17:46:49     打赏
3-5   1)条件赋值语句:
LIBRARY    IEEE;
USE  IEEE.SID_LOGIC_1164.ALL;
USE  IEEE.SID_LOGIC_UNSIGNED.ALL;
ENTITY(DIN:IN    STD_LOGIC_VECTOR(2  DOWNTO  0);
       DOUT:OUT    BIT_VECTOR(7  DOWNTO  0));
END   DECODER  3  TO  8;
ARCHICTURE  BHV  OF  DECODER  3  TO  8 IS
BEGIN
    WITH  CONV_INTEGER(DIN)SELECT
DOUT<=  “00000001”  WHEN 0,
DOUT<=  “00000010”  WHEN 1,
DOUT<=  “00000100”  WHEN 2,
DOUT<=  “00001000”  WHEN 3,
DOUT<=  “00010000”  WHEN 4,
DOUT<=  “00100000”  WHEN 5,
DOUT<=  “01000000”  WHEN 6,
DOUT<=  “10000000”  WHEN 7;
UNAFFECTER    WHEN   OTHERS;
END  BHV;
2)CASE语句:
LIBRARY    IEEE;
END   DECODER  3  TO  8;
BEGIN
  PROCESS(DIN)
  BEGIN
       CASE  CONV_INTEGER(DIN)  IS
       WHEN  0=> DOUT <= “00000001”;
       WHEN  1=> DOUT <= “00000010”;
       WHEN  2=> DOUT <= “00000100”;
       WHEN  3=> DOUT <= “00001000”;
       WHEN  4=> DOUT <= “00010000”;
       WHEN  5=> DOUT <= “00100000”;
       WHEN  6=> DOUT <= “01000000”;
       WHEN  7=> DOUT <= “10000000”;
       WHEN   OTHERS => NULL;
       END   CASE;
   END  PROCESS;
END   BHV;
3)if   else  语句:
LIBRARY    IEEE;
END   DECODER  3  TO  8;
BEGIN
  PROCESS(DIN)
  BEGIN
IF CONV_INTEGER(DIN)=0  THEN DOUT<= “00000001”;
ELSIF CONV_INTEGER(DIN)=1  THEN DOUT<= “00000010”;
ELSIF CONV_INTEGER(DIN)=2  THEN DOUT<= “00000100”;
ELSIF CONV_INTEGER(DIN)=3  THEN DOUT<= “00001000”;
ELSIF CONV_INTEGER(DIN)=4  THEN DOUT<= “00010000”;
ELSIF CONV_INTEGER(DIN)=5  THEN DOUT<= “00100000”;
ELSIF CONV_INTEGER(DIN)=6  THEN DOUT<= “01000000”;
ELSIF CONV_INTEGER(DIN)=7  THEN DOUT<= “10000000”;
    END   IF;
   END  PROCESS;
END  BHV;
4)移位操作法:
LIBRARY    IEEE;
END   DECODER  3  TO  8;
BEGIN
DOUT<= “00000001”SLLCONV_INTEGER(DIN);
END   BHV;
3-14七人表决器:
LRBRAR   IEEE;
USE  IEEE.STD_LOGIC_1164.ALL;
ENTITY  BJQ7 IS
PORT  (INPUT:  IN  STD_LOGIC_VECTOR(6 DOWNTO 0;
      OUTPUT:OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
       Y: OUT     STD_LOGIC);
END  BJQ7;
ARCHITECTURE  BHV  OF BJQ7  IS
BEGIN
PROCESS(INPUT)
VARIABLE  Q : STD_LOGIC_VECTOR(2DOWNTO 0);
BEGIN
Q :=”000”;
FOR n in  0  TO  6  LOOP
  IF (INPUT(n)=’1’)  THEN Q:=Q+1;
 END IF;
END  LOOP;
OUTPUT<=Q;
IF (OUTPUT>=4)  Y<=’1’  ELSE Y<=’0’;
END  IF;
END PROCESS
END ARCHITECTURE BHV
2014-10-30 20:08:55     打赏
楼主 第一排第六个图标是插入代码功能
