版主好,我在DIY区下载安装的 Quartus II 12.0 (64-bit),编译EPM240T100C5N(以前的CPLD板)时,说12.0的license不支持 EPM240T100C5,注解如下,该怎么解决?是用老版本,还是有插件可安装?多谢了.
Error (119013): Current license file does not support the EPM240T100C5 deviceError: Quartus II 64-Bit Fitter was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 363 megabytes
Error: Processing ended: Thu Nov 20 12:40:05 2014
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:00
Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 1 warning
