电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » VGA800*600显示疑问(已解决)
共8条 1/1 1 跳转至页
VGA800*600显示疑问(已解决)
2014-11-21 21:35:33     打赏
楼上实验室设备更新,抱回来一台显示器。本想着可以把未完成的VGA显示实验做了。640*480显示很正常,可是800*600显示却出现了这样的问题,实在发现不了原因,请大家指点一下。
关键词: FPGA
2014-11-21 21:37:06     打赏
时钟通过PLL倍频,是满足要求的。
*Engineer: superdian
*Create Date:  2014/9/29
*Design Name:
*Module Name:  VGA
*Project Name:
*Target Devices: EP3CE5E144C8
*Tool versions:
*Description:
*Dependencies:
*Revision:
*Revision 0.01 - File Created
*Additional Comments:
module VGA(clock,switch,disp_RGB,hsync,vsync);
input  clock;//系统输入时钟80MHZ
input  [1:0] switch;
output [2:0] disp_RGB;//VGA数据输出
output hsync;  //vga行同步信号
output vsync;  //vga场同步信号
reg [10:0] hcount;//vga行扫描计数器
reg [10:0] vcount;//vga场扫描计数器
reg [2:0] data;
reg [2:0] h_dat;
reg [2:0] v_dat;
reg  flag;
wire hcount_ov;
wire vcount_ov;
wire dat_act;
wire hsync;
wire vsync;
reg  vga_clk;
//vga行场扫描时序参数表
parameter    hsync_end   = 11'd127,
             hdat_begin  = 11'd215,
			    hdat_end    = 11'd1015,
			    hpixel_end  = 11'd1055,
			    vsync_end   = 11'd3,
			    vdat_begin  = 11'd26,
			    vdat_end    = 11'd626,
			    vline_end   = 11'd627;
always @(posedge clock)
begin
  vga_clk = ~vga_clk;
end
VGA驱动部分
//行扫描
always@ (posedge vga_clk)
begin
  if(hcount_ov)
    hcount <= 11'd0;
  else
    hcount <= hcount + 1'd1;
end
assign hcount_ov = (hcount == hpixel_end);
//场扫描
always@(posedge vga_clk)
begin
 if(hcount_ov)
 begin
  if(vcount_ov)
   vcount <= 11'd0;
  else
   vcount <= vcount + 1'd1;
 end
end
assign vcount_ov = (vcount == vline_end);
//数据,信号同步传输
assign dat_act = ((hcount >= hdat_begin)&&(vcount <hdat_end))
   &&((vcount >= vdat_begin) && (vcount < vdat_end));
assign hsync = (hcount > hsync_end);
assign vsync = (vcount > vsync_end);
assign disp_RGB = (dat_act)  ? data:3'h00;
always @(posedge vga_clk)
begin
  case(switch[1:0])
   2'd0: data <= h_dat; //横彩条
   2'd1: data <= v_dat; //选择竖彩条
   2'd2: data <= (v_dat ^ h_dat); //异或产生棋盘格
   2'd3: data <= (v_dat ~^ h_dat); //同或产生棋盘格
  endcase
end
always @(posedge vga_clk)//产生竖彩条
begin
 if(hcount <315)
   v_dat <= 3'h7; //白
 else if(hcount < 415)
   v_dat <= 3'h6; //黄
 else if(hcount < 515)
   v_dat <= 3'h5; //青
 else if(hcount < 615)
   v_dat <= 3'h4; //绿
 else if(hcount < 715)
   v_dat <= 3'h3; //紫
 else if(hcount < 815)
   v_dat <= 3'h2;//红
 else if(hcount < 915)
   v_dat <= 3'h1; //蓝
 else
   v_dat <= 3'h0; //黑
end
always@(posedge vga_clk)//产生横彩条
begin
  if(vcount <101)
     h_dat <= 3'h7; //白
  else if(vcount < 176)
     h_dat <= 3'h6; //黄
  else if(vcount < 251)
     h_dat <= 3'h5; //青
  else if(vcount < 326)
     h_dat <= 3'h4; //绿
  else if(vcount < 401)
     h_dat <= 3'h3; //紫
  else if(vcount < 476)
     h_dat <= 3'h2; //红
  else if(vcount < 551)
     h_dat <= 3'h1; //蓝
  else
     h_dat <= 3'h0; //黑
end
endmodule
2014-11-21 21:40:51     打赏
这是640*480的效果,很正常。FPGAFPGA
2014-11-24 15:10:08     打赏
vga行场扫描时序参数表  你修改过了没??换了不同尺寸的显示器需要修改
2014-11-24 21:29:17     打赏
是修改过了的。再看看,打算换台显示器试试。
2014-11-25 14:04:24     打赏
冒险修改了相关参数,发现这台显示器并不遵循那个VGA时序网站给出的标准,800*600显示最终正常了。FPGA  VGAFPGA  VGA
2014-11-25 14:05:34     打赏
FPGA   VGAFPGA   VGA
2014-11-25 14:07:00     打赏
FPGA  VGA
这是我修改后的参数。
共8条 1/1 1 跳转至页
