共8条
VGA800*600显示疑问(已解决)
时钟通过PLL倍频,是满足要求的。
*Engineer: superdian
*Create Date: 2014/9/29
*Design Name:
*Module Name: VGA
*Project Name:
*Target Devices: EP3CE5E144C8
*Tool versions:
*Description:
*Dependencies:
*Revision:
*Revision 0.01 - File Created
*Additional Comments:
module VGA(clock,switch,disp_RGB,hsync,vsync);
input clock;//系统输入时钟80MHZ
input [1:0] switch;
output [2:0] disp_RGB;//VGA数据输出
output hsync; //vga行同步信号
output vsync; //vga场同步信号
reg [10:0] hcount;//vga行扫描计数器
reg [10:0] vcount;//vga场扫描计数器
reg [2:0] data;
reg [2:0] h_dat;
reg [2:0] v_dat;
reg flag;
wire hcount_ov;
wire vcount_ov;
wire dat_act;
wire hsync;
wire vsync;
reg vga_clk;
//vga行场扫描时序参数表
parameter hsync_end = 11'd127,
hdat_begin = 11'd215,
hdat_end = 11'd1015,
hpixel_end = 11'd1055,
vsync_end = 11'd3,
vdat_begin = 11'd26,
vdat_end = 11'd626,
vline_end = 11'd627;
always @(posedge clock)
begin
vga_clk = ~vga_clk;
end
VGA驱动部分
//行扫描
always@ (posedge vga_clk)
begin
if(hcount_ov)
hcount <= 11'd0;
else
hcount <= hcount + 1'd1;
end
assign hcount_ov = (hcount == hpixel_end);
//场扫描
always@(posedge vga_clk)
begin
if(hcount_ov)
begin
if(vcount_ov)
vcount <= 11'd0;
else
vcount <= vcount + 1'd1;
end
end
assign vcount_ov = (vcount == vline_end);
//数据,信号同步传输
assign dat_act = ((hcount >= hdat_begin)&&(vcount <hdat_end))
&&((vcount >= vdat_begin) && (vcount < vdat_end));
assign hsync = (hcount > hsync_end);
assign vsync = (vcount > vsync_end);
assign disp_RGB = (dat_act) ? data:3'h00;
always @(posedge vga_clk)
begin
case(switch[1:0])
2'd0: data <= h_dat; //横彩条
2'd1: data <= v_dat; //选择竖彩条
2'd2: data <= (v_dat ^ h_dat); //异或产生棋盘格
2'd3: data <= (v_dat ~^ h_dat); //同或产生棋盘格
endcase
end
always @(posedge vga_clk)//产生竖彩条
begin
if(hcount <315)
v_dat <= 3'h7; //白
else if(hcount < 415)
v_dat <= 3'h6; //黄
else if(hcount < 515)
v_dat <= 3'h5; //青
else if(hcount < 615)
v_dat <= 3'h4; //绿
else if(hcount < 715)
v_dat <= 3'h3; //紫
else if(hcount < 815)
v_dat <= 3'h2;//红
else if(hcount < 915)
v_dat <= 3'h1; //蓝
else
v_dat <= 3'h0; //黑
end
always@(posedge vga_clk)//产生横彩条
begin
if(vcount <101)
h_dat <= 3'h7; //白
else if(vcount < 176)
h_dat <= 3'h6; //黄
else if(vcount < 251)
h_dat <= 3'h5; //青
else if(vcount < 326)
h_dat <= 3'h4; //绿
else if(vcount < 401)
h_dat <= 3'h3; //紫
else if(vcount < 476)
h_dat <= 3'h2; //红
else if(vcount < 551)
h_dat <= 3'h1; //蓝
else
h_dat <= 3'h0; //黑
end
endmodule
共8条
