电子产品世界 » 论坛首页 » DIY与开源设计 » 开源硬件 » banana pi BPI-M2 四核开源单板计算机
共3条 1/1 1 跳转至页
2014-12-05 14:38:08     打赏
Banana PI M2 is the open source hardware platform,Banana PI M2 is an quad core version of Banana Pi ,Banana PI M2 is the quad core more better than the Banana Pi M1,it support WIFI onboard.
Banana Pi M2 series run Android,Debian linux,Ubuntu linux, Raspberry Pi imange and others imange.
Elastos coordinate multi CUP to from the family cloud entirnment which based on the “software/hardware service”
Banana PI hardware: 1Ghz ARM7 quad-core processor, 1GB DDR3 SDRAM,
Banana PI with Gigabit ethernet port, It can run with Android 4.4 smoothly. The size of Banana PI M2 same as banana pi M1, it can easily run with the game it support 1080P high definition video output, the GPIO compatible with Raspberry Pi B+ and can run the ROM Image
Note: Banana Pi M2 not support sata port, so you need use USB for hardisk
关键词: banana     BPI-M2     四核     开源
2014-12-21 22:26:20     打赏
好厉害的样子,支持,期待快快发售。。。。。。
2015-02-02 15:16:21     打赏
春节后会上市。谢谢支持。
共3条 1/1 1 跳转至页
