电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » SCI查询方式
SCI查询方式
2014-12-08 19:40:12     打赏
                 281x-SCI和PC间的通讯
// $          Date:   30/11/2009        整理:  eyes417      $
//   FILE :  281x-SCI_PC.c
//  TITLE:  281x-SCI和PC间的通讯  ---  查询方式,使用FIFO   #此前在首页部分显示#
//               PC发送至串口,DSP再回送至PC                                //
//                        ASSUMPTIONS:
//   As supplied, this project is configured for "boot to H0" operation.
//   Other then boot mode pin configuration, no other hardware configuration is required.
# include "DSP281x_Device.h"    // DSP281x Headerfile Include File
# include "DSP281x_Examples.h"   // DSP281x Examples Include File
 void scia_echoback_init(void);
 void scia_fifo_init(void);
 void scia_xmit(int a);                    //串口发送--数据
 void scia_msg(char *msg);                 //串口发送--字符串
 Uint16 LoopCount;
 void main(void)
    Uint16 ReceivedChar;
    char *msg;
// Step 1. Initialize System Control:
    InitSysCtrl();
// Step 2. Initalize GPIO:
 // InitGpio();  //配置IO口功能为SCIA和SCIB模式
    EALLOW;
    GpioMuxRegs.GPFMUX.bit.SCITXDA_GPIOF4 = 1;
    GpioMuxRegs.GPFMUX.bit.SCIRXDA_GPIOF5 = 1;
    GpioMuxRegs.GPGMUX.bit.SCITXDB_GPIOG4 = 1;
    GpioMuxRegs.GPGMUX.bit.SCIRXDB_GPIOG5 = 1;
    EDIS;
// Step 3. Clear all interrupts and initialize PIE vector table:
    DINT;                   // Disable CPU interrupts
    InitPieCtrl();         //初始化PIE控制寄存器
    IER = 0x0000;
    IFR = 0x0000;
    InitPieVectTable();    //初始化PIE中断向量表
// Step 4. Initialize all the Device Peripherals:
   // InitPeripherals();    //初始化所有外设
// Step 5. User specific code:
    scia_fifo_init();
    scia_echoback_init();
//从PC上的串口调试助手输入要发送的数据至DSP
    msg = "\r\nYou will enter a character, and the DSP will echo it back! \n\0";
    scia_msg(msg);
    for(;;)
       msg = "\r\nEnter a character: \0";
       scia_msg(msg);
       // 查询方式--接收--使用FIFO
       while(SciaRegs.SCIFFRX.bit.RXFIFST!=1) { }      // wait for XRDY =1 for empty state
                                                       //XRDY =1 (空状态)等待数据发送
       // 接收数据
       ReceivedChar = SciaRegs.SCIRXBUF.all;
       // Echo character back
       msg = "  You sent: \0";
       scia_msg(msg);
       scia_xmit(ReceivedChar);     //串口发送函数
       LoopCount++;
     }  //end for
}  //end main
//SCI-A初始化
void scia_echoback_init()
//通信控制寄存器,1个停止位,无奇偶校验,自测试禁止,空闲线模式,字符长度8位
  SciaRegs.SCICCR.all =0x0007;
//禁止接收错误中断,禁止休眠,使能发送,接收
 SciaRegs.SCICTL1.all =0x0003;
 SciaRegs.SCICTL2.all =0x0003;
 SciaRegs.SCICTL2.bit.TXINTENA =1;   //使能TXRDY中断
 SciaRegs.SCICTL2.bit.RXBKINTENA =1; //接收缓冲器中断使能
//波特率设置 SCI-Band=LSPCLK/((BRR+1)*8)---9600K
 SciaRegs.SCIHBAUD = 0x0001;
 SciaRegs.SCILBAUD = 0x00E7;
 SciaRegs.SCICTL1.all =0x0023;  // SCI初始化完成退出复位重启状态
//串口发送--变量
    while (SciaRegs.SCIFFTX.bit.TXFFST != 0) {}
    SciaRegs.SCITXBUF=a;
//串口发送--字符或字符串
 void scia_msg(char * msg)
    int16 i;
    i = 0;
    while(msg != '\0')
        scia_xmit(msg);
        i++;
// 初始化 SCI--FIFO
 void scia_fifo_init()
    SciaRegs.SCIFFTX.all=0xE040;  //允许接收,使能FIFO,清除TXFIFINT
    SciaRegs.SCIFFRX.all=0x204f;  //使能FIFO接收,清除RXFFINT,16级FIFO
    SciaRegs.SCIFFCT.all=0x0000;  //禁止波特率校验
// No more.
