5-1 同步复位 异步复位。同步复位是指与时钟同步,当复位信号有效之后,出现时钟有效边沿时才对电路模块进行复位操作;而异步复位与时钟信号无关,只要复位信号有效,无论这时时钟信号是什么样,都对电路模块进行复位操作。
5-7
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity counter is port( allow,reset,clk :in bit; o:out integer range 0 to 10; c:out bit); end counter; architecture behaver of counter is begin p1: process (clk,reset,allow) variable ot:integer range 0 to 10:=0; variable t:bit ; begin if(reset='1')then o<=0; elsif (allow='1') then if(clk'event and clk='1')then ot:=ot+1;t:='0'; if(ot>9) then ot:=0;t:='1'; end if; end if; o<=ot; c<=t; end if; end process p1; end architecture behaver;
5-8
library IEEE;use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity cnt_16 is
port (
clk: in STD_LOGIC;
k: in STD_LOGIC;
clr: in STD_LOGIC;
q: out STD_LOGIC_VECTOR (15 downto 0)
end cnt_16;
architecture cnt_16_arch of cnt_16 is
signal qq:std_logic_vector(15 downto 0);
begin
process(clk,clr,k)
begin
if clr='1' then
qq<="0000000000000000";
elsif clk'event and clk='1' then
if k='1' then
qq<=qq+'1';
else
qq<=qq-'1';
end if;
end if;
end process;
process(qq)
begin
q<=qq;
end process;
end cnt_16_arch;
