电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » 第七次作业
第七次作业
2014-12-16 15:01:36     打赏
5-1 同步复位 异步复位。同步复位是指与时钟同步,当复位信号有效之后,出现时钟有效边沿时才对电路模块进行复位操作;而异步复位与时钟信号无关,只要复位信号有效,无论这时时钟信号是什么样,都对电路模块进行复位操作。
5-7
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity counter is
port(
allow,reset,clk :in bit;
o:out integer range 0 to 10;
c:out bit);
end counter;
architecture behaver of counter is
begin
 p1: process (clk,reset,allow)
 variable ot:integer range 0 to 10:=0;
 variable t:bit ;
 begin
if(reset='1')then o<=0;
 elsif (allow='1') then
  if(clk'event and clk='1')then
  ot:=ot+1;t:='0';
  if(ot>9) then ot:=0;t:='1';
  end if;
  end if;
  o<=ot;
  c<=t;
end if;
end process p1;
end architecture behaver;
5-8
library IEEE;use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity cnt_16 is
    port (
        clk: in STD_LOGIC;
        k: in STD_LOGIC;
        clr: in STD_LOGIC;
        q: out STD_LOGIC_VECTOR (15 downto 0)
end cnt_16;
architecture cnt_16_arch of cnt_16 is
signal qq:std_logic_vector(15 downto 0);
begin
process(clk,clr,k)
begin
 if clr='1' then
  qq<="0000000000000000";
 elsif clk'event and clk='1' then
  if k='1' then
     qq<=qq+'1';
  else
     qq<=qq-'1';
   end if;
 end if;
end process;
process(qq)
begin
 q<=qq;
end process;
end cnt_16_arch;
