共1条
第四次作业
只看楼主 1楼
3-3: 解:1、用IF_THEN语句实现4选1多路选择器 LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY mux41 IS PORT (a,b,c,d; IN STD_LOGIC; s0: IN STD_LOGIC; s1: IN STD_LOGIC; y: OUT STD_LOGIC); END ENTITY mux41; ARCHITECTURE if_mux41 OF mux41 IS SIGNAL s0s1 :STD_LOGIC_VECTOR(1 DOWNT O 0):——定义标准逻辑位矢量数据 BEGIN s0s1<=s1&s0; ——s1相并s0,即s1与s0并置操作 PROCESS(s0s1,a,b,c,d) BEGIN IF s0s1="00" THEN y <= a; ELSIF s0s1="01" THEN y <= b; ELSIF s0s1="10" THEN y <= c; THEN y <= d; END IF; END PROCESS; END ARCHITECTURE if_mux41; 2、用CASE语句实现4选1多路选择器 LIBR ARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY mux41 IS PORT (a,b,c,d;IN STD_LOGIC; s0: IN STD_LOGIC; s1: IN STD_LOGIC; y: OUT STD_LOGIC); END ENTITY mux41; ARCHITECTURE case_mux41 OF mux41 IS SIGNAL s0s1:STD_LOGIC_VECTOR(1 DOWNTO 0);——定义标准逻辑位矢量数据 BEGIN s0s1<=s1&s0; ——s1相并s0,即s1与s0并置操作 PROCESS(s0s1,a,b,c,d) BEGIN CASE s0s1 IS ——类似于真值表的CASE语句 WHEN "00" => y <= a; WHEN "01" => y <= b; WHEN "10" => y <= c; WHEN "11" => y< = d; WHEN OTHERS =>NULL; END CASE; END PROCESS; END ARCHITECTURE case_mux41; 3、用WHEN_ELSE语句实现4选1多路选择器 LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY mux 41 IS PORT (a,b,c,d:IN STD_LOGIC; S0: IN STD_LOGIC; S1: IN STD_LOGIC; y: OUT STD_LOGIC); END ENTITY mux 41; ARCHITECTURE case_mux41 OF mux41 IS SIGNAL.s0s1 :STD_LOGIC_VECTOR(1 DOWNTO 0); BEGIN s0s1<=s1&s0; PROCESS(s0s1,a,b,c,d) BEGIN CASE s0s1 IS WHEN "00" WHEN "01" WHEN "10" WHEN "11" WHEN OTHERS END CASE; END PROCESS; END ARCHITECTURE case_mux41; 3-4 (1) LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY f_suber IS PORT(x,y,sub_in: IN STD_LOGIC; sub_out,diff_out: OUT STD_LOGIC); END ENTITY f_suber; ARCHITECTURE fs1 OF f_suber IS COMPONENT h_suber PORT(x,y: IN STD_LOGIC; diff,s_out:OUT STD_LOGIC); END COMPONENT; SIGNAL a,b,c:STD_LOGIC; BEGIN u1: h_suber PORT MAP(x=>xin,y=>yin, diff=>a, s_out=>b); u2: h_suber PORT MAP(x=>a, y=>sub_in,diff=>diff_out,s_out=>c); sub_out <=c OR b; END ARCHITECTURE fs1; (2)图在附件里 程序 LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY suber_8 IS PORT (x0,x1,x2,x3,x4,x5,x6,x7: IN STD_LOGIC; y0,y1,y2,y3,y4,y5,y6,y7,sin: IN STD_LOGIC; diff0,diff1,diff2,diff3: OUT STD _LOGIC; diff4,diff5,fiff6,diff7,sout: OUT STD_LOGIC ); END ENTITY suber_8; ARCHITECTURE s8 OF suber_8 IS COMPONENT f_suber PORT(xin,yin,sub_in: IN STD_LOGIC; sub_out,diff_out: OUT STD_LOGIC); END COMPONENT; SIGNAL a0,a1,a2,a3,a4,a5,a6: STD_LOGIC; BEGIN u0: f_suber PORT MAP(xin=>x0,yin=>y0,diff_out=>diff0,sub_in=>sin,sub_out=>a0); u1: f_suber PORT MAP(xin=>x1,yin=>y1,diff_out=>diff1,sub_in=>a0,sub_out=>a1); u2: f_suber PORT MAP(xin=>x2,yin=>y2,diff_out=>diff2,sub_in=>a1,sub_out=>a2); u3: f_suber PORT MAP(xin=>x3,yin=>y3,diff_out=>diff3,sub_in=>a2,sub_out=>a3); u4: f_suber PORT MAP(xin=>x4,yin=>y4,diff_out=>diff4,sub_in=>a3,sub_out=>a4); u5: f_suber PORT MAP(xin=>x5,yin=>y5,diff_out=>diff5,sub_in=>a4,sub_out=>a5); u6: f_suber PORT MAP(xin=>x6,yin=>y6,diff_out=>diff6,sub_in=>a5,sub_out=>a6); u7: f_suber PORT MAP(xin=>x7,yin=>y7,diff_out=>diff7,sub_in=>a6,sub_out=>sout); END ARCHITECTURE s8;
作业附件
共1条
| OrangePiZero2W系统被打赏¥33元 | |
