大家好
我的功放进程贴开始了,我会记录我的每一步动向,谢谢大家的分享。
开始我的程序设计,一点一滴记录,欢迎大家指正。
/************* 功能说明 **************
本文件为STC15xxx系列的端口初始化程序,用户几乎可以不修改这个程序.
#include "GPIO.h"
// 函数: u8 GPIO_Inilize(u8 GPIO, GPIO_InitTypeDef *GPIOx)
// 描述: 初始化IO口.
// 参数: GPIOx: 结构参数,请参考timer.h里的定义.
// 返回: 成功返回0, 空操作返回1,错误返回2.
// 版本: V1.0, 2012-10-22
if(GPIO > GPIO_P5) return 1; //空操作
if(GPIOx->Mode > GPIO_OUT_PP) return 2; //错误
if(GPIO == GPIO_P0)
if(GPIOx->Mode == GPIO_PullUp) P0M1 &= ~GPIOx->Pin, P0M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P0M1 |= GPIOx->Pin, P0M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P0M1 |= GPIOx->Pin, P0M0 |= GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P0M1 &= ~GPIOx->Pin, P0M0 |= GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P1)
if(GPIOx->Mode == GPIO_PullUp) P1M1 &= ~GPIOx->Pin, P1M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P1M1 |= GPIOx->Pin, P1M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P1M1 |= GPIOx->Pin, P1M0 |= GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P1M1 &= ~GPIOx->Pin, P1M0 |= GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P2)
if(GPIOx->Mode == GPIO_PullUp) P2M1 &= ~GPIOx->Pin, P2M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P2M1 |= GPIOx->Pin, P2M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P2M1 |= GPIOx->Pin, P2M0 |= GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P2M1 &= ~GPIOx->Pin, P2M0 |= GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P3)
if(GPIOx->Mode == GPIO_PullUp) P3M1 &= ~GPIOx->Pin, P3M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P3M1 |= GPIOx->Pin, P3M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P3M1 |= GPIOx->Pin, P3M0 |= GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P3M1 &= ~GPIOx->Pin, P3M0 |= GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P4)
if(GPIOx->Mode == GPIO_PullUp) P4M1 &= ~GPIOx->Pin, P4M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P4M1 |= GPIOx->Pin, P4M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P4M1 |= GPIOx->Pin, P4M0 |= GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P4M1 &= ~GPIOx->Pin, P4M0 |= GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P5)
if(GPIOx->Mode == GPIO_PullUp) P5M1 &= ~GPIOx->Pin, P5M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P5M1 |= GPIOx->Pin, P5M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P5M1 |= GPIOx->Pin, P5M0 |= GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P5M1 &= ~GPIOx->Pin, P5M0 |= GPIOx->Pin; //推挽输出
return 0; //成功
时钟控制
本文件为STC15xxx系列的定时器初始化和中断程序,用户可以在这个文件中修改自己需要的中断程序.
#include "timer.h"
/********************* Timer0中断函数************************/
//void timer0_int (void) interrupt TIMER0_VECTOR
/********************* Timer1中断函数************************/
void timer1_int (void) interrupt TIMER1_VECTOR
/********************* Timer2中断函数************************/
void timer2_int (void) interrupt TIMER2_VECTOR
P10 = ~P10;
// 函数: u8 Timer_Inilize(u8 TIM, TIM_InitTypeDef *TIMx)
// 描述: 定时器初始化程序.
// 参数: TIMx: 结构参数,请参考timer.h里的定义.
if(TIM > Timer2) return 1; //空操作
if(TIM == Timer0)
TR0 = 0; //停止计数
if(TIMx->TIM_Interrupt == ENABLE) ET0 = 1; //允许中断
else ET0 = 0; //禁止中断
if(TIMx->TIM_Polity == PolityHigh) PT0 = 1; //高优先级中断
else PT0 = 0; //低优先级中断
if(TIMx->TIM_Mode > TIM_16BitAutoReloadNoMask) return 2; //错误
TMOD = (TMOD & ~0x03) | TIMx->TIM_Mode; //工作模式,0: 16位自动重装, 1: 16位定时/计数, 2: 8位自动重装, 3: 16位自动重装, 不可屏蔽中断
if(TIMx->TIM_ClkSource == TIM_CLOCK_12T) AUXR &= ~0x80; //12T
if(TIMx->TIM_ClkSource == TIM_CLOCK_1T) AUXR |= 0x80; //1T
if(TIMx->TIM_ClkSource == TIM_CLOCK_Ext) TMOD |= 0x04; //对外计数或分频
else TMOD &= ~0x04; //定时
if(TIMx->TIM_ClkOut == ENABLE) INT_CLKO |= 0x01; //输出时钟
else INT_CLKO &= ~0x01; //不输出时钟
TH0 = (u8)(TIMx->TIM_Value >> 8);
TL0 = (u8)TIMx->TIM_Value;
if(TIMx->TIM_Run == ENABLE) TR0 = 1; //开始运行
return 0; //成功
if(TIM == Timer1)
TR1 = 0; //停止计数
if(TIMx->TIM_Interrupt == ENABLE) ET1 = 1; //允许中断
else ET1 = 0; //禁止中断
if(TIMx->TIM_Polity == PolityHigh) PT1 = 1; //高优先级中断
else PT1 = 0; //低优先级中断
if(TIMx->TIM_Mode >= TIM_16BitAutoReloadNoMask) return 2; //错误
TMOD = (TMOD & ~0x30) | TIMx->TIM_Mode; //工作模式,0: 16位自动重装, 1: 16位定时/计数, 2: 8位自动重装
if(TIMx->TIM_ClkSource == TIM_CLOCK_12T) AUXR &= ~0x40; //12T
if(TIMx->TIM_ClkSource == TIM_CLOCK_1T) AUXR |= 0x40; //1T
if(TIMx->TIM_ClkSource == TIM_CLOCK_Ext) TMOD |= 0x40; //对外计数或分频
else TMOD &= ~0x40; //定时
if(TIMx->TIM_ClkOut == ENABLE) INT_CLKO |= 0x02; //输出时钟
else INT_CLKO &= ~0x02; //不输出时钟
TH1 = (u8)(TIMx->TIM_Value >> 8);
TL1 = (u8)TIMx->TIM_Value;
if(TIMx->TIM_Run == ENABLE) TR1 = 1; //开始运行
return 0; //成功
if(TIM == Timer2) //Timer2,固定为16位自动重装, 中断无优先级
AUXR &= ~(1<<4); //停止计数
if(TIMx->TIM_Interrupt == ENABLE) IE2 |= (1<<2); //允许中断
else IE2 &= ~(1<<2); //禁止中断
if(TIMx->TIM_ClkSource > TIM_CLOCK_Ext) return 2;
if(TIMx->TIM_ClkSource == TIM_CLOCK_12T) AUXR &= ~(1<<2); //12T
if(TIMx->TIM_ClkSource == TIM_CLOCK_1T) AUXR |= (1<<2); //1T
if(TIMx->TIM_ClkSource == TIM_CLOCK_Ext) AUXR |= (1<<3); //对外计数或分频
else AUXR &= ~(1<<3); //定时
if(TIMx->TIM_ClkOut == ENABLE) INT_CLKO |= 0x04; //输出时钟
else INT_CLKO &= ~0x04; //不输出时钟
TH2 = (u8)(TIMx->TIM_Value >> 8);
TL2 = (u8)TIMx->TIM_Value;
if(TIMx->TIM_Run == ENABLE) AUXR |= (1<<4); //开始运行
return 0; //成功
return 2; //错误
| 有奖活动 | |
| 这个春节你犒赏自己什么了?分享你的故事,有奖征集 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| Gravity:中英文语音合成模块V2.0及其串口控制被打赏¥24元 | |
| 全彩色度变化图的绘制被打赏¥27元 | |
| 【FreeRtos】FreeRtos任务栈的生长方向管理方式被打赏¥20元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】LVGL添加输入设备:EC11旋转编码器被打赏¥39元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】RA8D1部署FreeRTOS+LVGL被打赏¥33元 | |
| 空气质量检测器设计与实现被打赏¥24元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】LWIP进行UDP、TCP、HTTP、MQTT功能联合测试被打赏¥41元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】RA8D1部署FreeRTOS+LWIP被打赏¥36元 | |
| RTOS怎么选?让我来给你答案!被打赏¥15元 | |
| 【S32K3XX】Flash驱动使用被打赏¥26元 | |
