LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE IEEE.std_logic_unsigned.ALL; USE IEEE.std_logic_arith.ALL; ENTITY BirdrectionalSignal2 IS PORT(CLK_200M : IN std_logic; rst,re,we : IN std_logic; data : INOUT std_logic_vector(7 DOWNTO 0)); END BirdrectionalSignal2; ARCHITECTURE behave OF BirdrectionalSignal2 IS type state_type IS(nop_state,read_state,write_state,high_z); SIGNAL data_in,data_out : std_logic_vector(7 DOWNTO 0); SIGNAL reg : std_logic_vector(7 DOWNTO 0); SIGNAL present_state,next_state : state_type :=high_z; BEGIN data_in<=data;--data_in accepts the data uncoditional state_transfer : PROCESS(re,we,rst) BEGIN CASE present_state IS WHEN nop_state=> reg<="00000000"; IF(re='1') THEN next_state<=read_state; ELSIF(we='1') THEN next_state<=write_state; ELSE next_state<=nop_state; END IF; WHEN read_state=> data<=data_out; IF(we='1' AND re='0') THEN next_state<=write_state; ELSIF(we='0' AND re='1') THEN next_state<=read_state; ELSIF(we='0' AND re='0') THEN next_state<=high_z; ELSE next_state<=nop_state; --data<="ZZZZZZZZ"; END IF; WHEN write_state=> reg<=data_in; IF(re='1' AND we='0') THEN next_state<=read_state; ELSIF(re='0' AND we='1') THEN next_state<=write_state; ELSIF(we='0' AND re='0') THEN next_state<=high_z; ElSE next_state<=nop_state; END IF; WHEN high_z=> data<="ZZZZZZZZ"; IF(re='1' AND we='0') THEN next_state<=read_state; ELSIF(re='0' AND we='1') THEN next_state<=write_state; ELSIF(we='0' AND re='0') THEN next_state<=high_z; ElSE next_state<=nop_state; END IF; END CASE; IF(rst='1') THEN next_state<=high_z; END IF; END PROCESS state_transfer; state_register : PROCESS(CLK_200M) BEGIN IF(CLK_200M'event AND CLK_200M='1') THEN present_state<=next_state; data_out<=reg; --reg<=data_in; END IF; END PROCESS state_register; END behave;
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
