电子产品世界 » 论坛首页 » 企业专区 » GD32 » GD32107C-EVAL配置108M时钟
共5条 1/1 1 跳转至页
2015-03-18 23:23:23     打赏
GD32主频108M,而STM32推荐工作频率为72M。所以使用STM32估计固件库开发得加入108M时钟的配置。采用如下步骤来完成,如果哪里有错误还请网友及时指出
1、添加几项宏定义:(system_stm32f10x.h)
//加入108MHz
#if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
/* #define SYSCLK_FREQ_HSE    HSE_VALUE */
 #define SYSCLK_FREQ_24MHz  24000000
#else
/* #define SYSCLK_FREQ_24MHz  24000000 */
/* #define SYSCLK_FREQ_36MHz  36000000 */
/* #define SYSCLK_FREQ_48MHz  48000000 */
/* #define SYSCLK_FREQ_56MHz  56000000 */
/* #define SYSCLK_FREQ_72MHz  72000000 */
#define  SYSCLK_FREQ_108MHz  108000000
#endif
#ifdef SYSCLK_FREQ_HSE
  uint32_t SystemCoreClock         = SYSCLK_FREQ_HSE;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_24MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_36MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_36MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_48MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_56MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_56MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_72MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_72MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_108MHz
	uint32_t SystemCoreClock         = SYSCLK_FREQ_108MHz;
#else /*!< HSI Selected as System Clock source */
  uint32_t SystemCoreClock         = HSI_VALUE;        /*!< System Clock Frequency (Core Clock) */
#endif
  static void SetSysClockToHSE(void);
  static void SetSysClockTo24(void);
  static void SetSysClockTo36(void);
  static void SetSysClockTo48(void);
  static void SetSysClockTo56(void);
  static void SetSysClockTo72(void);
	static void SetSysClockTo108(void);
#endif
2、完成void SetSysClockTo108(void)函数,以SetSysClockTo72为参照,在其基础上修改。因为GD32中倍频系数由5个位组成。所以先在stm32f10x.h里添加几项东西:
/*!< PLLMUL configuration *///11 1100
#define  RCC_CFGR_PLLMULL                    ((uint32_t)0x003C0000)        /*!< PLLMUL[3:0] bits (PLL multiplication factor) */
#define  RCC_CFGR_PLLMULL_0                  ((uint32_t)0x00040000)        /*!< Bit 0 */
#define  RCC_CFGR_PLLMULL_1                  ((uint32_t)0x00080000)        /*!< Bit 1 */
#define  RCC_CFGR_PLLMULL_2                  ((uint32_t)0x00100000)        /*!< Bit 2 */
#define  RCC_CFGR_PLLMULL_3                  ((uint32_t)0x00200000)        /*!< Bit 3 */
#define  RCC_CFGR_PLLMULL_4                  ((uint32_t)0x08000000)        /*!< Bit 4 GD32*/
是采用 8M / 2 * 27 = 108MHz 所以添加一个x27的宏
 #define  RCC_CFGR_PLLMULL4                  ((uint32_t)0x00080000)        /*!< PLL input clock * 4 */
 #define  RCC_CFGR_PLLMULL5                  ((uint32_t)0x000C0000)        /*!< PLL input clock * 5 */
 #define  RCC_CFGR_PLLMULL6                  ((uint32_t)0x00100000)        /*!< PLL input clock * 6 */
 #define  RCC_CFGR_PLLMULL7                  ((uint32_t)0x00140000)        /*!< PLL input clock * 7 */
 #define  RCC_CFGR_PLLMULL8                  ((uint32_t)0x00180000)        /*!< PLL input clock * 8 */
 #define  RCC_CFGR_PLLMULL9                  ((uint32_t)0x001C0000)        /*!< PLL input clock * 9 */
 #define  RCC_CFGR_PLLMULL6_5                ((uint32_t)0x00340000)        /*!< PLL input clock * 6.5 */
 #define  RCC_CFGR_PLLMULL27                 ((uint32_t)(RCC_CFGR_PLLMULL_4 | RCC_CFGR_PLLMULL_3 | RCC_CFGR_PLLMULL_1))
函数如下:
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /* Flash 2 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
#ifdef STM32F10X_CL
    /* Configure PLLs ------------------------------------------------------*/
    /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
    RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
                              RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
    RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
                             RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
    /* Enable PLL2 */
    RCC->CR |= RCC_CR_PLL2ON;
    /* Wait till PLL2 is ready */
    while((RCC->CR & RCC_CR_PLL2RDY) == 0)
    /* PLL configuration: PLLCLK = PREDIV1 / 2 * 27 = 108 MHz */
    RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL | RCC_CFGR_PLLMULL_4);
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLSRC_PREDIV1 |
                            RCC_CFGR_PLLMULL27);
#else
#endif /* STM32F10X_CL */
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
#endif
关键词: 配置     时钟     GD32107C-EVAL
2015-03-18 23:36:44     打赏
WOW,108M,刷VGA去
2015-03-18 23:43:11     打赏
真棒啊!
这样就可以配置108MHz了
可是,楼主有时间一定要想一想如何通过函数来完成,而不是通过这个初始化文件。因为,我们在低功耗的时候,有时是采用降频来处理的
2015-03-28 08:01:18     打赏
超频最高多少?
2015-03-28 23:03:59     打赏
108M稳定工作的话能多干好多事情呢。。。
比如刷VGA之类
共5条 1/1 1 跳转至页
