GD32130GStart开发板初探
只看楼主 1楼
板子主片型号:GD32F130G8
片上资源:
内核
ARM 32-bit Cortex-M3 (48 MHz max)
存储器
- 64 K Flash
- 8 K 硬件奇偶校验的SRAM
- CRC calculation unit
- Calendar RTC with alarm and periodic wakeup from Stop/Standby
- Low power Sleep, Stop, and Standby modes
- VBAT supply for RTC and backup registers
- 7-channel DMA controller
- 18 capacitive sensing channels
- 1 * 12-bit ADC (10-channel)
- 2 * I2C interfaces
- 2 * USARTs supporting master synchronous SPI and modem control
- 2 * SPIs with 4 to 16 programmable bit frame
- Two watchdog timers (independent, window)
- SysTick timer: 24-bit downcounter
- 23 fast I/Os
- 96-bit unique ID
- Serial wire debug (SWD)
一个USER Key,一个Reset Key,一个USER LED。
