高级点的来了,Key作为外部中断,用中断方式检测Key是否按下。
首先配置下NVIC和EXTI,然后当检测到中断时点亮LED。
int main(void)
NVIC_InitPara NVIC_InitStructure;
EXTI_InitPara EXTI_InitStructure;
/* Enable the GPIO_LED Clock */
RCC_AHBPeriphClock_Enable( RCC_AHBPERIPH_GPIOA , ENABLE );
//配置GPIO
GPIO_InitPara GPIO_InitStructure;
/* Configure the GPIO_LED pin */
GPIO_InitStructure.GPIO_Pin = GPIO_PIN_1;
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OTYPE_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PUPD_NOPULL;
GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
GPIO_Init( GPIOA , &GPIO_InitStructure );
GPIO_InitStructure.GPIO_Pin = GPIO_PIN_0;
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_IN;
//配置NVIC
//使能NVIC时钟
NVIC_PRIGroup_Enable( NVIC_PRIGROUP_1 );
NVIC_InitStructure.NVIC_IRQ = EXTI0_1_IRQn ;
NVIC_InitStructure.NVIC_IRQEnable = ENABLE;
NVIC_InitStructure.NVIC_IRQPreemptPriority = 0;
NVIC_InitStructure.NVIC_IRQSubPriority = 0;
NVIC_Init(&NVIC_InitStructure);
//配置外部中断
//使能EXTI时钟
RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_CFG, ENABLE);
//将EXTI0连接到PA0(Key引脚)
SYSCFG_EXTILine_Config(EXTI_SOURCE_GPIOA,EXTI_SOURCE_PIN0);
EXTI_InitStructure.EXTI_LINE = EXTI_LINE0;
EXTI_InitStructure.EXTI_LINEEnable =ENABLE;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_Init(&EXTI_InitStructure);
while(1);
中断配置完毕。添加中断响应函数,使得当外部中断进来时候就点亮LED灯。
void EXTI0_1_IRQHandler(void)
if(EXTI_GetINTBitState(EXTI_LINE0) != RESET)
EXTI_ClearINTBitState(EXTI_LINE0);
GPIO_SetBits(GPIOA,GPIO_PIN_1);
这样,我们又点了一次灯。
下一个实验是看门狗。MCU复位后配置看门狗,延时一段时间之后让LED点亮。 如果不喂狗,当看门狗时间到达之后会复位MCU。于是我们就会看到LED在以一定的频率闪烁。
