电子产品世界 » 论坛首页 » 企业专区 » GD32 » [GD32130C-START]GD32F130C8真的可以兼容ST的吗?(七)
[GD32130C-START]GD32F130C8真的可以兼容ST的吗?(七)TIM3定时器PWM实验
2015-04-01 21:37:06     打赏
定时器是我们在嵌入式单片机里应用最广泛的外设。使用定时器的水平高低也决定着整个项目实施的水平高低。本次版主给大家带了使用TIM3定时器产生PWM示例。例程主要使用TIM3来产生40K频率的方波,占空比通过按键可调,按键按下时,占空比增加。
实例还是比较简单的,版主就不再多多叙述,大家直接看源代码吧!
源代码:
  * @brief  tim3 pwm 40KHz
  * @param
  * @retval
  * @date   2015-03-31
  * @note
void TIM3PWM(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  /* GPIOA Configuration: TIM3 CH4 (PB1) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_1);
  /* Enable the TIM3 gloabal Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  TIM_TimeBaseStructure.TIM_Prescaler = 0;  /*!< 分频为48MHz */
  TIM_TimeBaseStructure.TIM_Period = 1199;  /*!< 40KHz频率 */
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = gCCR4_Val;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OC4Init(TIM3, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Disable);
  TIM_Cmd(TIM3, ENABLE);
  * @brief  key check
  * @param
  * @retval
  * @date   2015-03-28
  * @note
void KeyCheck(void)
  bool KeyStatus;
  KeyStatus = KeyScan(0);
  switch(gKeyStatus)
    case 0:  /*!< 空闲状态 */
      if(KeyStatus == true)
        gKeyStatus = 1;
      else
        gKeyStatus = 0;
        LedOff(0);
        gSendCmdStatus = 0;
      break;
    case 1:  /*!< 消抖状态 */
        gKeyCnt = 5;
        gKeyStatus = 2;
      else
        gKeyCnt = 0;
        gKeyStatus = 0;
      break;
    case 2:  /*!< 按下状态 */
        if(gKeyCnt == 0)
          //按键按下执行内容
          LedOn(0);
          gSendCmdStatus |= 0x0F;
        else
          gKeyStatus = 2;
      else
        gKeyCnt = 0;
        gKeyStatus = 0;
      break;
    case 3:  /*!< 确认按下 */
      LedOn(0);
      break;
    default: gKeyStatus = 0;
  * @brief  uart_int
  * @param
  * @retval
  * @date   2015-03-29
  * @note   发送使用DMA方式,接收使用中断
void UartConfig(uint32_t band)
  USART_InitTypeDef USART_InitStructure;
  DMA_InitTypeDef  DMA_InitStructure;
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  RCC_APB2PeriphClockCmd (RCC_APB2Periph_USART1, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  /* Connect pin to Periph */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_1);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_1);
  /* Configure pins as AF pushpull */
  GPIO_InitStructure.GPIO_Pin     = GPIO_Pin_9 | GPIO_Pin_10;
  GPIO_InitStructure.GPIO_PuPd    = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  USART_InitStructure.USART_BaudRate = band;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(USART1, &USART_InitStructure);
  /* NVIC configuration */
  /* Enable the USARTx Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_DeInit(DMA1_Channel2);
  DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_TDR_ADDRESS;
  DMA_InitStructure.DMA_BufferSize = (uint16_t)256;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)(&gSendBuf[0]);
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_Init(DMA1_Channel2, &DMA_InitStructure);
  USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
  USART_Cmd(USART1, ENABLE);
void main(void)
  uint16_t i;
  int8_t Str[] = "hello EEPW\r\n";
  gKeyStatus = 0;
  bspInit();
  gCntLed[0] = 500;
  gCntLed[1] = 500;
  TxIndex = 0;
  gSendCnt = 12;
  gRcvBuf[0] = 100;
  gCCR4_Val = 99;
  for(i = 0; i < gSendCnt; i++)
    gSendBuf[i] = Str[i];
  UartConfig(115200);
  if (SysTick_Config(48000)) //参数为系统时钟的向上溢出值,此配置为48000,即1ms中断一次
    /* Capture error */
    while (1);
  TIM3PWM();
  while(1)
    if(gCntLed[1] == 0)
      LedToggle(1);
      gCntLed[1] = gRcvBuf[0] * 4;
    KeyCheck();
    if(gSendCmdStatus > 0)
      if(gSendCmdStatus < 0x10)
        gCCR4_Val = gCCR4_Val + 100;
        if(gCCR4_Val > 1000)
          gCCR4_Val = 0;
        TIM_SetCompare4(TIM3, gCCR4_Val);
        DMA_Cmd(DMA1_Channel2, DISABLE);
        DMA_SetCurrDataCounter(DMA1_Channel2, gSendCnt);
        DMA_Cmd(DMA1_Channel2, ENABLE);
        gSendCmdStatus |= 0xF0;
  * @brief  SysTick_Handler的中断入口函数
  * @param
  * @retval
  * @date   2014-11-23
  * @note
void SysTick_Handler(void)
  if(gCntLed[0] > 0)
    gCntLed[0]--;
  else
    gCntLed[0] = 0;
  if(gCntLed[1] > 0)
    gCntLed[1]--;
  else
    gCntLed[1] = 0;
  if(gKeyCnt > 0)
    gKeyCnt--;
  else
    gKeyCnt = 0;
  * @brief  USART1_Handler的中断入口函数
  * @param
  * @retval
  * @date   2015-03-29
  * @note
void USART1_IRQHandler(void)
  if (USART_GetITStatus(USART1, USART_IT_RXNE) == SET)
    gRcvBuf[0] = USART_ReceiveData(USART1);
工程文件:
exp08_TIM3PWM.zip
关键词: GD32130C-START     兆易     GD32F13
2015-04-02 09:41:14     打赏
还是有些说明的好
