电子产品世界 » 论坛首页 » 活动中心 » 合作大赛 » arduino物联网程序
arduino物联网程序
2015-06-11 11:06:53     打赏
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <math.h>
byte buff[2];
// for yeelink api
#define APIKEY         "20314f31cb6934a5187f43b676be2886" // 此处替换为你自己的API KEY
#define DEVICEID       19119 // 此处替换为你的设备编号
#define SENSORID1       33314 // 此处替换为你的传感器编号
// assign a MAC address for the ethernet controller.
byte mac[] = { 0x00, 0x1D, 0x72, 0x82, 0x35, 0x9D};
// initialize the library instance:
EthernetClient client ;
char server[] = "api.yeelink.net";   // name address for yeelink API
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 3*1000; // delay between 2 datapoints, 30s
String returnValue = "";
boolean ResponseBegin = false;
void setup() {
   pinMode(5, OUTPUT);
   Wire.begin();
   // start serial port:
  Serial.begin(57600);
   // start the Ethernet connection with DHCP:
   if (Ethernet.begin(mac) == 0) {
     Serial.println("Failed to configure  Ethernet using DHCP");
     for(;;)
   else {
     Serial.println("Ethernet configuration OK");
void loop() {
   // if there's incoming data from the net connection.
   // send it out the serial port.  This is for debugging
   // purposes only:
   if (client.available()) {
     char c = client.read();
    // Serial.print(c);
       if (c == '{')
         ResponseBegin = true;
       else if (c == '}')
       if (ResponseBegin)
         returnValue += c;
   if (returnValue.length() !=0 && (ResponseBegin == false))
     Serial.println(returnValue);
     if (returnValue.charAt(returnValue.length() - 1) == '1') {
       Serial.println("turn on the LED");
       digitalWrite(5, HIGH);
       else if(returnValue.charAt(returnValue.length() - 1) == '0') {
       Serial.println("turn off the LED");
       digitalWrite(5, LOW);
      returnValue = "";
   // if there's no net connection, but there was one last time
   // through the loop, then stop the client:
   if (!client.connected() && lastConnected) {
    Serial.println();
     Serial.println("disconnecting.");     client.stop();
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    // read sensor data, replace with your code
    //int sensorReading = readLightSensor();
    Serial.print("yeelink:");
    //get data from server
    getData();    }
  // store the state of the connection for next time through
   // the loop:
  lastConnected = client.connected();
// this method makes a HTTP connection to the server and get data back
void getData(void) {
   // if there's a successful connection:
   if (client.connect(server, 80)) {
     Serial.println("connecting...");
     // send the HTTP GET request:
     client.print("GET /v1.0/device/");
     client.print(DEVICEID);
     client.print("/sensor/");
     client.print(SENSORID1);
     client.print("/datapoints");
     client.println(" HTTP/1.1");
     client.println("Host: api.yeelink.net");
     client.print("Accept: *");
     client.print("/");
     client.println("*");
     client.print("U-ApiKey: ");
     client.println(APIKEY);
     client.println("Content-Length: 0");
     client.println("Connection: close");
     client.println();
     Serial.println("print get done.");
   else {
     // if you couldn't make a connection:
     Serial.println("connection failed");
    Serial.println();
     client.stop();
    // note the time that the connection was made or attempted:
   lastConnectionTime = millis();
