FEATURES
High-Definition Multimedia Interface (HDMI®) 1.4a features
supported
All mandatory and additional 3D video formats supported
Extended colorimetry, including sYCC601, Adobe® RGB,
Adobe YCC601, xvYCC extended gamut color
CEC 1.4-compatible
HDMI 3 GHz receiver
297 MHz maximum TMDS clock frequency
Supports 4k × 2k resolution
Xpressview fast switching of HDMI ports
Up to 48-bit Deep Color with 36-/30-/24-bit support
High-bandwidth Digital Content Protection (HDCP) 1.4
support with internal HDCP keys
HDCP repeater support: up to 127 KSVs supported
Integrated CEC controller
Programmable HDMI equalizer
5 V detect and Hot Plug assert for each HDMI port
Audio support
Audio support including high bit rate (HBR) and
Direct Stream Digital (DSD)
S/PDIF (IEC 60958-compatible) digital audio support
Supports up to four I
2
S outputs
Advanced audio mute feature
Dedicated, flexible audio output port
Super Audio CD® (SACD) with DSD output interface
HBR audio
Dolby® TrueHD
DTS-HD Master Audio™
General
Interrupt controller with 2 interrupt outputs
Standard identification (STDI) circuit
Highly flexible, 48-bit pixel output interface
36-bit output for resolutions up to 1080p Deep Color
2 × 24-bit pass-through outputs for HDMI formats
greater than 2.25 GHz
Internal EDID RAM
Any-to-any, 3 × 3 color space conversion (CSC) matrix
128-lead TQFP_EP,14 mm × 14 mm package
APPLICATIONS
Projectors
Video conferencing
HDTV
AVR, HTiB
Soundbar
Video switch
