430用模拟SPI写25q32,无输出求大神正解(带源程序) 就是输入都没问题,但是就是没得输出DO一直处于高阻状态。。。卡了几天了,,,求大神带我飞,,,,QAQ
/******SPI.C文件********/
#include "SPI_ml.h"
#define SDI_1 Pinout(1,0,1)
#define SDI_0 Pinout(1,0,0)
#define SCK_1 Pinout(1,2,1)
#define SCK_0 Pinout(1,2,0)
#define SPI_SS_1 Pinout(1,5,1)
#define SPI_SS_0 Pinout(1,5,0)
#define I0_SDO1 (P1IN&BIT1)//备用按钮
uchar atey[10];
void Pinout(unsigned char pinx,unsigned char pin,unsigned char out)
if(pinx==1)
switch(pin)
case 0:
if(out==1){ P1OUT |= BIT0;}
else{P1OUT &= ~BIT0;}break;
case 1:
if(out==1){ P1OUT |= BIT1;}
else{P1OUT &= ~BIT1;}break;
case 2:
if(out==1){ P1OUT |= BIT2;}
else{P1OUT &= ~BIT2;}break;
case 3:
if(out==1){ P1OUT |= BIT3;}
else{P1OUT &= ~BIT3;}break;
case 4:
if(out==1){ P1OUT |= BIT4;}
else{P1OUT &= ~BIT4;}break;
case 5:
if(out==1){ P1OUT |= BIT5;}
else{P1OUT &= ~BIT5;}break;
case 6:
if(out==1){ P1OUT |= BIT6;}
else{P1OUT &= ~BIT6;}break;
case 7:
if(out==1){ P1OUT |= BIT7;}
else{P1OUT &= ~BIT7;}
break;
else if(pinx==2)
switch(pin)
case 0:
if(out==1){ P2OUT |= BIT0;}
else{P2OUT &= ~BIT0;}break;
case 1:
if(out==1){ P2OUT |= BIT1;}
else{P2OUT &= ~BIT1;}break;
case 2:
if(out==1){ P2OUT |= BIT2;}
else{P2OUT &= ~BIT2;}break;
case 3:
if(out==1){ P2OUT |= BIT3;}
else{P2OUT &= ~BIT3;}break;
case 4:
if(out==1){ P2OUT |= BIT4;}
else{P2OUT &= ~BIT4;}break;
case 5:
if(out==1){ P2OUT |= BIT5;}
else{P2OUT &= ~BIT5;}break;
case 6:
if(out==1){ P2OUT |= BIT6;}
else{P2OUT &= ~BIT6;}
break;
case 7:
if(out==1){ P2OUT |= BIT7;}
else{P2OUT &= ~BIT7;}break;
void delay_spi(unsigned int x)//1us 11M
unsigned char i,c;
for(i=0;i<x;i++)
c++;
c++;
/*****等待写入结束******/
void waitwiriteEND(uint x)
uint i;
for(i=0;i<x;i++)
SCK_0;
delay_spi(5);
SCK_1;
delay_spi(5);
//初始化SPI
void int_SPI()
SCK_1; //置高时钟
SPI_SS_1;
/*********发送一个字节************/
void send_SPI(unsigned char data_send)
unsigned char i,s=0;
for(i=0;i<8;i++)
SCK_0;
s=(data_send&0x01);
if(s==1)
SDI_1;
else
SDI_0;
delay_spi(5);
SCK_1;
delay_spi(5);
data_send>>=1;
/*********读取一个字节************/
unsigned char read_SPI()
unsigned char i,data_read=0;
for(i=0;i<8;i++)
data_read<<=1;
SCK_0;
delay_spi(5);
SCK_1;
delay_spi(5);
data_read|=I0_SDO1;
return data_read;
/*********发送写入允许指令************/
void write_SR()
/*****发送第一个字节——指令1****/
SPI_SS_0;
//send_SPI(byte1);//写使能06 04
send_SPI(write_1);//写使能06 04
SPI_SS_1;
/*********读取寄存器************/
void read_SR()
uchar read_sr1;
//uchar read_sr2=0;
SPI_SS_0;
send_SPI(read_SR_1);//读状态寄存器1 05 35
//ead_sr1=read_SPI();
// SPI_SS=1;
// SPI_SS=0;
// send_SPI(read_SR_2);//读状态寄存器2 05 35
// read_sr2=read_SPI();
SPI_SS_1;
/*********写入多个字节***********/
void write_data_ye(uchar *p,u32 sendAddr,uchar tx)
uchar i;
write_SR();
SPI_SS_0;
send_SPI(PP);//页写数据
send_SPI((sendAddr&0xFF0000)>>16);//地址1高
send_SPI((sendAddr&0xFF00)>>8);//地址2
send_SPI(sendAddr&0xFF);//地址3低
for(i=0;i<tx;i++)
send_SPI(p[i]);
SPI_SS_1;
/*********读取多个字节***********/
void read_datac(u32 readAddr,uchar rx)
uchar i;
SPI_SS_0;
send_SPI(read_data);//读数据
send_SPI((readAddr & 0xFF0000) >> 16);//地址1高
send_SPI((readAddr & 0xFF00) >> 8);//地址2
send_SPI(readAddr & 0xFF);//地址3低
while(rx--)
atey[i]=read_SPI();
SPI_SS_1;//结束,关闭模块
/*********扇区擦除***********/
void Erase_datac(u32 readAddr)
/********允许写入命令*******/
write_SR();
SPI_SS_0;
send_SPI(SE);//读数据
waitwiriteEND(40);
SPI_SS_1;//结束,关闭模块
void SPI_FLASH_BulkErase(void)
write_SR();
SPI_SS_0;
send_SPI(SE);//读数据
SPI_SS_1;//结束,关闭模块
waitwiriteEND(50);
void ccc()
uint i;
SPI_SS_0;
send_SPI(0x9f);
waitwiriteEND(36);
for(i=0;i<5;i++)
// atey[i]=read_SPI();
SPI_SS_1;
SPI_SS_0;
send_SPI(0xAB);
for(i=5;i<10;i++)
//atey[i]=read_SPI();
waitwiriteEND(30);
SPI_SS_1;
/*******spi.h文件**********/
#ifndef __SPI_ml__
#define __SPI_ml__
#include "main.h"
/*********状态寄存器16位*************/
#define writeb 0x50 //设置写使能为挥发性
#define busy 0x01 //忙检测
#define WEL 0x02 //写使能 :低位
#define BP_0 0x04 //内存保护CMP=0 SEC=0 TB=0最高110
#define SRP_1 0x80 //写保护直到下次断电才可改变写:低位
#define SRP_3 0x01 //写控制要WP=1 可写:高位
#define SUS 0x80 //擦除状态位 为1执行擦除:高位
#define LB_0 0x00 //安全解锁 :高位
/************第一个字节为指令 集1**************/
#define write_1 0x06 //写使能
#define write_0 0x04 //写禁止
#define read_SR_1 0x05 //读状态寄存器1
#define read_SR_2 0x35 //读状态寄存器2
#define write_SR_01 0x01 //写入状态寄存器(3个字节)S7——S0 S15—S8
#define PP 0x02 //页编程 A23-A0 D7_D0(第5个字节)
#define QPP 0x32 //4页编程A23—A0
#define SE 0x20 //扇区擦除4kb
#define BE0 0x52 //块擦除32ke
#define BE1 0xd8 //块擦除64kb
#define CE 0xc7 //芯片擦除
#define EPR 0x75 //编程暂停擦除
#define PD 0xb9 //编程恢复
#define read_rese 0xff //连续读取模式
/************第一个字节为指令 集2**************/
#define read_data 0x03 //读数据 地址A23——A0 数据D7_D0(字节5)
#define fast_read 0x0b //快速读取
#define read_SR_12 0xeb //快速读取4 I / O EBH A23-A0,M7-M0( 4)(X,X,X,X,D7-D0,......)(5)(D7-D0,......)
//7.最低地址位必须为0(A0 = 0)8.最低4位地址位必须为0(A0,A1,A2,A3 = 0)
extern uchar atey[10];
void delay_spi(unsigned int x);//1us 11M
void int_SPI();
void send_SPI(unsigned char data_send);
unsigned char read_SPI();
void read_datac(u32 readAddr,uchar rx);//读取多个字节
void read_SR();
void write_SR();
void write_data_ye(uchar *p,u32 sendAddr,uchar tx);//写 页
void Erase_datac(u32 readAddr);//扇区擦除
void SPI_FLASH_BulkErase(void);//全部擦除
void Pinout(unsigned char pinx,unsigned char pin,unsigned char out);
void ccc();
#endif
#ifndef __CONFIG_H__
#define __CONFIG_H__
//#include "msp430x54x.h"
#include "msp430G2553.h"
#ifndef TRUE
#define TRUE 1
#endif
#ifndef FALSE
#define FALSE 0
#endif
//#define Debug //调试软件
#define uchar unsigned char //无符号8位整型变量
#define uint unsigned int //无符号32位整型变量
#define u32 unsigned long //无符号32位整型变量
typedef signed char int8; //有符号8位整型变量
typedef unsigned short uint16; //无符号16位整型变量
typedef signed short int16; //有符号16位整型变量
typedef signed int int32; //有符号32位整型变量
typedef float fp32; //单精度浮点数(32位长度)
typedef double fp64; //双精度浮点数
#endif
/*******主函数部分**********/
#include "main.h"
#include "SPI_ml.h"
#define SHP 0x001
#define I0_RB (P1IN&BIT7)//上
#define I0_RU (P1IN&BIT6)
#define FLASH_WriteAddress 0x00000
void Pinout(unsigned char pinx,unsigned char pin,unsigned char out);//管脚使能函数
void IO_INTI(); //IO口初始化
void BasicClock_Init(); //时钟源初始化
void IO_INTI()
//P1全输入
P1DIR = 0xfd;//1111 1101
//配置输入
P1REN |=BIT1;
P1OUT|=BIT1;
{ //设置时钟源
if(CALBC1_1MHZ == 0xFF || CALDCO_1MHZ == 0xFF)
{ while(1); }
/*********调整DC0频率************/
BCSCTL1 = CALBC1_1MHZ; //DCO ---1MHz
DCOCTL = CALDCO_1MHZ;
BCSCTL3 |= LFXT1S_0;
IFG1 &= ~OFIFG;
BCSCTL2 |= SELM_0 + DIVM_2+DIVA_1; //MCLK使用DC01MHZ,SMCLK采用125k时钟
void main()
WDTCTL=WDTPW+WDTHOLD;//关闭看门狗
BasicClock_Init(); //时钟初始化
// Capture_GPIO_Init(); //定时器初始化
IO_INTI(); //管脚初始化 BTS
int_SPI();
//Erase_datac(FLASH_WriteAddress);//擦除模块
// write_data_ye(b,FLASH_WriteAddress,10);//写页
//read_datac(FLASH_WriteAddress,10);//读取页
//ead_SR();
ccc();
while(1)
Pinout(1,0,1);
