自己加楼.
没空,没办法,数字键盘只好先做一层了.
画了个草图
修改配列地址:
http://www.keyboard-layout-editor.com/#/
在线生成EEP文件的地址:
http://www.keyboard.fans/tkg/#
先打开一个104的标准键盘
把功能区和F区删去.数字区先不删,做参考,按草图修改配列.可以先把要修改的键帽改一下色,好区分.
复制代码:
["~\n`","!\n1","@\n2","#\n3","$\n4","%\n5","^\n6","&\n7","*\n8",{c:"#8f877f"},"Num Lock",{c:"#8d887a"},"7\nHome","4\n←","1\nEnd",{w:2},"0\nIns"],
[{c:"#cccccc",w:1.5},"Tab","Q","W","E","R","T","Y","U","I",{c:"#8d887a"},"/","8\n↑","5","2\n↓",{a:7,w:1.5},""],
[{c:"#cccccc",a:4,w:1.75},"Caps Lock","A","S","D","F","G","H","J",{c:"#8d887a"},"*","9\nPgUp","6\n→","3\nPgDn",{w:2.25},".\nDel"],
[{c:"#cccccc",w:2.25},"Shift","Z","X","C","V","B","N",{c:"#82807a"},"-","+",{c:"#8d887a",a:7},"",{a:4},"Ent",{a:7,w:2.75},""],
[{c:"#cccccc",a:4,w:1.25},"Ctrl",{w:1.25},"Win",{w:1.25},"Alt",{a:7,w:6.25},"",{c:"#8d887a",a:4,w:1.25},"Fn",{w:1.25},"Ctrl",{w:1.25},"Alt",{w:1.25},"Backspace"]
拷入
http://www.keyboard.fans/tkg/#中
生成EEP文件,刷入32U4测试,结果如下:
成了!
拷贝没有图,做了个文档,大伙可以下来参考.
配列文件:
| 为遥控小车巧添功能被打赏¥26元 | |
