STM32 CBT6 的芯片用SWD模式下载要怎么下载,四根线,JLink 的 1 7 9 20 脚 分别接到板上 VCC DIO(PA13) CLK(PA14) GND (对应的)。 配置keil 总是出现问题,(nO SW-DP found)
然后用JLingk 下载时,Connect 成功,Erase chip 失败, 提示
Erasing chip ...
- Erasing 256 sectors, 1 range, 0x8000000 - 0x807FFFF
- ERROR: RAM check failed @ address 0x2000003C.
- ERROR: Write: 0x3F3E3D3C 43424140
- ERROR: Read: 0x00000055 000000AA
- ERROR: (60 bytes of RAM have been checked successfully)
- ERROR: Failed to erase chip
求解
