共7条
stm32l053按键控制灯亮灭
然后再插入如下函数,下到板子上就ok。还挺灵敏的,
void delay()
{uint32_t i=0xffff;
while(i--);
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* Configure the system clock */
SystemClock_Config();
/* Initialize all configured peripherals */
MX_GPIO_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_13)==0)
delay();
HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);
while(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_13)==0);
/* USER CODE END 3 */
共7条
