电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 21号交作业
共8条 1/1 1 跳转至页
21号交作业
2015-11-15 22:26:37     打赏
2015-11-15 22:28:28     打赏
作业一:keil安装
猛戳这个程序:
然后出现这个玩意:
接下来的就不要理会那么多了,猛戳Next就对了,出现这个窗口:
剩下的就是等,等出现这玩意:
点击Finish,接下来就要用这个神器和谐Keil:
最后就Duang!!!能用到2020年了!
2015-11-15 22:31:34     打赏
作业二:流水灯
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
 GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void delay_us(u32 n)
 u8 j;
 while(n--)
 for(j=0;j<10;j++);
void delay_ms(u32 n)
 while(n--)
 delay_us(1000);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
 int i;
 unsigned int a[8]={GPIO_Pin_0,GPIO_Pin_1,GPIO_Pin_2,GPIO_Pin_3,GPIO_Pin_4,GPIO_Pin_5,GPIO_Pin_6,GPIO_Pin_7};
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3| GPIO_Pin_4| GPIO_Pin_5| GPIO_Pin_6| GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
while(1)
  for(i=0;i<=7;i++)
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
   delay_ms(50);
GPIO_ResetBits(GPIOC,a[i]);
delay_ms(50);
GPIO_SetBits(GPIOC,a[i]);
delay_ms(50);
2015-11-15 22:33:27     打赏
作业三:0~99按键计数
view plaincopy to clipboardprint?
  1. <strong>
  2. <pre name="code" class="c">#include "stm32f10x.h"
  3.
  4. GPIO_InitTypeDef GPIO_InitStructure; // 声明一个结构体
  5.
  6. void RCC_Configuration(void);
  7. void GPIO_INIT(void) ;
  8. void Function(void) ;
  9.
  10. int main(void)
  11. {
  12.     RCC_Configuration();
  13.     GPIO_INIT();
  14.     Function();
  15. }
  16.
  17. void RCC_Configuration(void)    //复位所有的RCC外围设备寄存器
  18. {
  19.         ErrorStatus HSEStartUpStatus;   //  设置错误标志量
  20.     RCC_DeInit();                       //*将外设寄存器RCC重设为初始值
  21.     RCC_HSEConfig(RCC_HSE_ON);//*打开外部高速时钟晶振HSE:
  22.   HSEStartUpStatus = RCC_WaitForHSEStartUp();  //*等待外部高速时钟晶振工作:
  23.   if(HSEStartUpStatus==SUCCESS)
  24.     {
  25.         RCC_HCLKConfig(RCC_SYSCLK_Div1);//*AHB使用系统时钟,负责外部存储器的时钟
  26.         RCC_PCLK1Config(RCC_HCLK_Div2);//*APB1 负责DA,USB,SPI,I2C,CAN,串口2345,普通TIM
  27.         RCC_PCLK2Config(RCC_HCLK_Div1);//*APB2负责AD,I/O,高级TIM,串口1
  28.         RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//*设置PLL输入时钟源72M
  29.         RCC_PLLCmd(ENABLE);//*打开PLL:
  30.         while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);//*等待PLL工作:
  31.         RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//*设置系统时钟
  32.         while(RCC_GetSYSCLKSource() != 0x08);//* 判断PLL是否是系统时钟:
  33.     }
  34.
  35.     GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//改变管脚的映射SWJ使能,禁用JTAG,选择用于事件输出的GPIO端口
  36.
  37.     /*蜂鸣器*/
  38.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //# 使能被重新映射到GPIOD时钟和使能复用时钟功能
  39.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;       //#管脚号  关闭蜂鸣器
  40.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //#输出速度
  41.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;      //#推挽输出
  42.   GPIO_Init(GPIOD, &GPIO_InitStructure);     //#初始化
  43.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  44. }
  45.
  46. void delay_us(u32 n)        //延时函数
  47. {
  48.     u8 j;
  49.     while(n--)
  50.             for(j=0;j<10;j++);
  51. }
  52. void  delay_ms(u32 n)       //延时函数
  53. {
  54.    while(n--)
  55.    delay_us(1000);
  56. }
  57.
  58. void GPIO_INIT(void)
  59. {
  60.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOB, ENABLE);
  61.
  62.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
  63.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;   //输出速度
  64.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  65.         GPIO_Init(GPIOC, &GPIO_InitStructure);  //初始化
  66.
  67.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_1|GPIO_Pin_15|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;//数码管
  68.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  69.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  70.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  71. }
  72.
  73.
  74. void Number(int a)  //数码管显示数字
  75. {
  76.     switch(a)
  77.             {
  78.         case 0 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
  79.         case 1 : GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);break;
  80.         case 2 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);break;
  81.         case 3 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);break;
  82.         case 4 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);break;
  83.         case 5 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);break;
  84.         case 6 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
  85.         case 7 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);break;
  86.         case 8 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
  87.         case 9 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break;
  88.             }
  89. }
  90.
  91.
  92. void Function(void)
  93. {
  94.         int i=0,j=0;          //i被按下的次数,n延时变量
  95.
  96.         GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
  97.         delay_ms(50); //关闭数码管
  98.
  99.         while(1)
  100.         {
  101.                 GPIO_SetBits(GPIOB,GPIO_Pin_1);         //打开个位数码管
  102.                 Number(i);                                //用switch函数显示00
  103.                 delay_ms(t);
  104.                 GPIO_ResetBits(GPIOB,GPIO_Pin_1);        //关闭个位
  105.                 GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
  106.
  107.                 GPIO_SetBits(GPIOB,GPIO_Pin_15);           //打开十位
  108.                 Number(j);
  109.                 delay_ms(t);
  110.                 GPIO_ResetBits(GPIOB,GPIO_Pin_15);      //关掉十位数码管
  111.                 GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
  112.
  113.                 if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))   //判断按键是s1否被按下
  114.                 {
  115.                     delay_ms(50);            //延时消抖
  116.                     if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))  //再次判断按键是s1否被按下
  117.                     {
  118.                         i++;                     //按键被按下,个位+1
  119.                         if(i==10)
  120.                         {
  121.                             j++;
  122.                             i=0;
  123.                         }
  124.                         if(j==10)
  125.                         {
  126.                              j=0;
  127.                                                  i=0;
  128.                         }
  129.                     }
  130.                 }
  131.
  132.
  133.
  134.
  135.
  136.
  137.
  138.
  139. </pre>
  140. <p>
  141.
  142. </p>
  143. </strong>
2015-11-15 22:35:31     打赏
作业四:单号uart控制LED流水灯转速
  1. <strong>#include "stm32f10x.h"
  2. #include    "stdio.h"
  3.
  4. GPIO_InitTypeDef GPIO_InitStructure;        // 声明结构体
  5. NVIC_InitTypeDef  NVIC_InitStructure;
  6. USART_InitTypeDef  USART_InitStructure;
  7. USART_ClockInitTypeDef  USART_ClockInitStructure;
  8.
  9. #define buff_size  16;
  10. char rx_buff[],rx_buff_count=0;
  11.
  12. void RCC_Configuration(void) ;
  13. void GPIO_INIT(void)  ;
  14. void USART_int(long BaudRate);
  15. void USART_SendStr(char *str);
  16. void  delay_ms(u32 n)  ;
  17. void delay_us(u32 n);
  18.
  19.
  20.
  21. /****主函数 ****/
  22. int main()
  23. {
  24.     RCC_Configuration();
  25.     GPIO_INIT();
  26.     USART_int(9600);
  27.     GPIO_ResetBits(GPIOC,0xffff);//led全亮,提示程序开始
  28.     delay_ms(200);
  29.     GPIO_SetBits(GPIOC,0xffff);//led全灭
  30.     USART_SendStr("USART Led Speed\r\n");//
  31.     USART_SendStr("\n>");//
  32.     while(1);
  33. }
  34.
  35.
  36. /****   配置RCC ****/
  37. void RCC_Configuration(void)
  38. {
  39.     ErrorStatus HSEStartUpStatus;   //  设置错误标志量
  40.     RCC_DeInit();                       //*将外设寄存器RCC重设为初始值
  41.     RCC_HSEConfig(RCC_HSE_ON);//*打开外部高速时钟晶振HSE:
  42.   HSEStartUpStatus = RCC_WaitForHSEStartUp();  //*等待外部高速时钟晶振工作:
  43.   if(HSEStartUpStatus==SUCCESS)
  44.     {
  45.         RCC_HCLKConfig(RCC_SYSCLK_Div1);//*AHB使用系统时钟,负责外部存储器的时钟
  46.         RCC_PCLK1Config(RCC_HCLK_Div2);//*APB1 负责DA,USB,SPI,I2C,CAN,串口2345,普通TIM
  47.         RCC_PCLK2Config(RCC_HCLK_Div1);//*APB2负责AD,I/O,高级TIM,串口1
  48.         RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//*设置PLL输入时钟源72M
  49.         RCC_PLLCmd(ENABLE);//*打开PLL:
  50.         while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);//*等待PLL工作:
  51.         RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//*设置系统时钟
  52.         while(RCC_GetSYSCLKSource() != 0x08);//* 判断PLL是否是系统时钟:
  53.     }
  54.      GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  55.
  56.     /*蜂鸣器*/
  57.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  58.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  59.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  60.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  61.     GPIO_Init(GPIOD, &GPIO_InitStructure);
  62.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  63. }
  64.
  65.
  66. /****延时 ****/
  67. void delay_us(u32 n)
  68. {
  69.     u8 j;
  70.     while(n--)
  71.     for(j=0;j<10;j++);
  72. }
  73.
  74. void  delay_ms(u32 n)
  75. {
  76.    while(n--)
  77.     delay_us(1000);
  78. }
  79.
  80.
  81. /**** 初始化GPIO ****/
  82. void GPIO_INIT(void)
  83. {
  84.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  85.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  86.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  87.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  88.     GPIO_Init(GPIOC, &GPIO_InitStructure);
  89. }
  90.
  91.
  92. /**** USART传输的波特率 ****/
  93. void USART_int(long BaudRate)
  94. {
  95.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA和 usart1
  96.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  97.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  98.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;          //复用推挽输出 PA9作为US1的TX端,打开复用,负责发送数据
  99.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  100.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;                          //RX位于PA10
  101.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;     //浮空输入,PA10作为US1的RX端,负责接收数据
  102.                                     //RX初始化PA10
  103.
  104.         USART_InitStructure.USART_BaudRate = BaudRate;//波特率
  105.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;//USART_WordLength 在一个帧中传输8位数据(字节)
  106.         USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位为一个字节
  107.         USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验
  108.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无流控制
  109.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式
  110.         USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//时钟低电平活动,开启发送接受数据功能(usart 使能)
  111.         USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;      //SCLK输出时钟低电平
  112.         USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//时钟第二个边沿开始数据捕获
  113.         USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据不从SCLK发出
  114.         USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
  115.         USART_Init(USART1, &USART_InitStructure);//初始化USART1
  116.         USART_Cmd(USART1, ENABLE);//USART1使能
  117.         USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能接收中断,在接受移位寄存器中有数据时产生
  118.         USART_Cmd(USART1, ENABLE);
  119.
  120.         //配置NVIC ,设置优先级分组,使用NVIC_Init对NVIC进行初始化
  121.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);//选择中断分组4(先占优先级四位,从优先级0)
  122.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择中断通道
  123.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//抢占优先级1-15
  124.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//响应优先级1-15
  125.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能中断
  126.         NVIC_Init(&NVIC_InitStructure); //初始化中断
  127.
  128. }
  129.
  130.
  131.
  132.
  133. /**** usart发送数据 ****/
  134. void USART_SendStr(char *str)   //USART发送数据
  135. {
  136.             while((*str)!='\0')
  137.         {
  138.                     USART_SendData(USART1,*str++);  //通过外设 USARTx 发送单个数据
  139.                     while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);  //检查指定的 USART 标志位设置与否
  140.         }
  141. }
  142.
  143.
  144. /**** 取字符串中的数字 ****/
  145. unsigned int translate(char* pstr)
  146. {
  147.       int s = 0;
  148.         while(*pstr != '\0')        //如果没扫到字符串的最后不停止
  149.         {
  150.                 if(*pstr >= '0' && *pstr <= '9')  //如果字符串中存在0-9的数字
  151.                 {
  152.                         s = s * 10 + *pstr - '0';
  153.                 }
  154.                 pstr++;
  155.         }
  156.     return s;
  157. }
  158.
  159. /****  点亮led****/
  160. void LED(char *S,char LEN)     //(字符串,字符串长度)
  161. {
  162.           int m,i;
  163.         int a[8]={GPIO_Pin_0,GPIO_Pin_1,GPIO_Pin_2,GPIO_Pin_3,GPIO_Pin_4,GPIO_Pin_5,GPIO_Pin_6,GPIO_Pin_7};
  164.             m=translate(S);
  165.
  166.             GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  167.             delay_ms(100);
  168.             for(i=0;i<8;i++)
  169.             {
  170.                 GPIO_ResetBits(GPIOC,a[i]);    // 点亮LED
  171.                 delay_ms(m);
  172.                 GPIO_SetBits(GPIOC,a[i]);     //熄灭LED
  173.                 delay_ms(m);
  174.             }
  175. }
  176.
  177.
  178. void input_ASK()
  179. {
  180.     char j;
  181.     LED(rx_buff,rx_buff_count);
  182.     rx_buff_count=0;
  183.     for (j=0;j<rx_buff_count;j++)
  184.     {
  185.             rx_buff[j]='\0';
  186.         }//判断读入信息是否结束,如果结束则准备下一次读入
  187.     USART_SendStr("\n>");
  188. }
  189.
  190.
  191.   /****接收中断****/
  192. void USART1_IRQHandler(void)
  193. {
  194.         while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)  { }   //判断接收中断是否打开
  195.     if(USART_ReceiveData(USART1)==0x0d)
  196.     {
  197.             input_ASK();
  198.         }
  199.     else
  200.     {
  201.             USART_SendData(USART1,USART_ReceiveData(USART1));  //将数据传回给电脑
  202.             rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
  203.       rx_buff_count++;
  204.     }
  205.
  206.         USART_ClearFlag(USART1, USART_FLAG_RXNE);  //清除中断接受完成标志位
  207.
  208. }  </strong>
2016-01-19 16:10:29     打赏
//作业五:
#include <stdio.h>
EXTI_InitTypeDef   EXTI_InitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
int count=0;
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void NVIC_Configuration(void)
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
/* Private functions ---------------------------------------------------------*/
int main(void)
  NVIC_Configuration();
  TIM_TimeBaseStructure.TIM_Period = 36000;
  TIM_TimeBaseStructure.TIM_Prescaler = 100;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
  TIM_Cmd(TIM2, ENABLE);
  while (1){
void TIM2_IRQHandler(void) //TIM3
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_Update );
    count++;
        if(count==1)
    GPIO_ResetBits(GPIOC,GPIO_Pin_0);
    if(count==2)
    GPIO_ResetBits(GPIOC,GPIO_Pin_1);
    if(count==3)
    GPIO_ResetBits(GPIOC,GPIO_Pin_2);
    if(count==4)
    GPIO_ResetBits(GPIOC,GPIO_Pin_3);
    if(count==5)
    GPIO_ResetBits(GPIOC,GPIO_Pin_4);
    if(count==6)
    GPIO_ResetBits(GPIOC,GPIO_Pin_5);
    if(count==7)
    GPIO_ResetBits(GPIOC,GPIO_Pin_6);
    if(count==8)
    GPIO_ResetBits(GPIOC,GPIO_Pin_7);
    if(count==9)
    count=0;
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
#ifdef __GNUC__
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  while (1)
#endif
2016-01-19 16:12:25     打赏
//定时器 5 通道 1 输入捕获配置
TIM_ICInitTypeDef TIM5_ICInitStructure;
void TIM5_Cap_Init(u16 arr,u16 psc)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE); //①使能 TIM5 时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //①使能 GPIOA 时钟
//初始化 GPIOA.0 ①
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //PA0 设置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PA0 输入
GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化 GPIOA.0
GPIO_ResetBits(GPIOA,GPIO_Pin_0);  //PA0 下拉
//②初始化 TIM5 参数
TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
TIM_TimeBaseStructure.TIM_Prescaler =psc; //预分频器
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; // TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM 向上计数模式
TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure); //初始化 TIMx
//③初始化 TIM5 输入捕获通道 1
TIM5_ICInitStructure.TIM_Channel = TIM_Channel_1; //选择输入端 IC1 映射到 TI1 上
TIM5_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;  //上升沿捕获
TIM5_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到 TI1 上
TIM5_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
TIM5_ICInitStructure.TIM_ICFilter = 0x00; //IC1F=0000 配置输入滤波器 不滤波
TIM_ICInit(TIM5, &TIM5_ICInitStructure); //初始化 TIM5 输入捕获通道 1
//⑤初始化 NVIC 中断优先级分组
NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn; //TIM3 中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //先占优先级 2 级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //从优先级 0 级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ 通道被使能
NVIC_Init(&NVIC_InitStructure); //初始化 NVIC
TIM_ITConfig( TIM5,TIM_IT_Update|TIM_IT_CC1,ENABLE);//④允许更新中断捕获中断
TIM_Cmd(TIM5,ENABLE ); //⑥使能定时器 5
u8 TIM5CH1_CAPTURE_STA=0;  //输入捕获状态
u16 TIM5CH1_CAPTURE_VAL; //输入捕获值
//⑤定时器 5 中断服务程序
void TIM5_IRQHandler(void)
if((TIM5CH1_CAPTURE_STA&0X80)==0)//还未成功捕获
if (TIM_GetITStatus(TIM5, TIM_IT_Update) != RESET)
if(TIM5CH1_CAPTURE_STA&0X40) //已经捕获到高电平了
if((TIM5CH1_CAPTURE_STA&0X3F)==0X3F)//高电平太长了
TIM5CH1_CAPTURE_STA|=0X80; //标记成功捕获了一次
TIM5CH1_CAPTURE_VAL=0XFFFF;
}else TIM5CH1_CAPTURE_STA++;
if (TIM_GetITStatus(TIM5, TIM_IT_CC1) != RESET) //捕获 1 发生捕获事件
if(TIM5CH1_CAPTURE_STA&0X40) //捕获到一个下降沿
TIM5CH1_CAPTURE_STA|=0X80;  //标记成功捕获到一次上升沿
TIM5CH1_CAPTURE_VAL=TIM_GetCapture1(TIM5);
TIM_OC1PolarityConfig(TIM5,TIM_ICPolarity_Rising); //设置为上升沿捕获
}else //还未开始,第一次捕获上升沿
TIM5CH1_CAPTURE_STA=0;  //清空
TIM5CH1_CAPTURE_VAL=0;
TIM_SetCounter(TIM5,0);
TIM5CH1_CAPTURE_STA|=0X40;  //标记捕获到了上升沿
TIM_OC1PolarityConfig(TIM5,TIM_ICPolarity_Falling); //设置为下降沿捕获
TIM_ClearITPendingBit(TIM5, TIM_IT_CC1|TIM_IT_Update); //清除中断标志位
//timer.h
extern u8 TIM5CH1_CAPTURE_STA;  //输入捕获状态
extern u16  TIM5CH1_CAPTURE_VAL; //输入捕获值
int main(void)
u32 temp=0;
delay_init();  //延时函数初始化
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置 NVIC 中断分组 2
uart_init(115200); //串口初始化波特率为 115200
LED_Init();  //LED 端口初始化
TIM3_PWM_Init(899,0); //不分频。PWM 频率=72000/(899+1)=80Khz
TIM5_Cap_Init(0XFFFF,72-1);  //以 1Mhz 的频率计数
while(1)
delay_ms(10);
TIM_SetCompare2(TIM3,TIM_GetCapture2(TIM3)+1);
if(TIM_GetCapture2(TIM3)==300)
TIM_SetCompare2(TIM3,0);
if(TIM5CH1_CAPTURE_STA&0X80)//成功捕获到了一次上升沿
temp=TIM5CH1_CAPTURE_STA&0X3F;
temp*=65536;//溢出时间总和
temp+=TIM5CH1_CAPTURE_VAL;//得到总的高电平时间
printf("HIGH:%d us\r\n",temp); //打印总的高点平时间
TIM5CH1_CAPTURE_STA=0; //开启下一次捕获
2016-01-19 16:13:13     打赏
  1. //ADC改变灯的颜色:
  2. #include "stm32f10x.h"
  3. #include "stm32_eval.h"
  4. #include <stdio.h>
  5. #define VREF 3.3
  6. GPIO_InitTypeDef   GPIO_InitStructure;
  7. USART_InitTypeDef USART_InitStructure;
  8. USART_ClockInitTypeDef USART_ClockInitStructure;
  9. int volt;
  10. unsigned int temp0,temp1,temp2;
  11. void RCC_Configuration(void)
  12. {/*
  13.   RCC_DeInit();
  14.
  15.   RCC_HSICmd(ENABLE);
  16.   while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  17.
  18.   RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  19.
  20.   RCC_HSEConfig(RCC_HSE_OFF);
  21.   RCC_LSEConfig(RCC_LSE_OFF);
  22.   RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  23.   RCC_PLLCmd(ENABLE);
  24.   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  25.   RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  26.   RCC_PCLK2Config(RCC_HCLK_Div1);
  27.   RCC_PCLK1Config(RCC_HCLK_Div2);
  28.   RCC_HCLKConfig(RCC_SYSCLK_Div1);
  29.   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  30.   while(RCC_GetSYSCLKSource() != 0x08);
  31. */
  32.     SystemInit();
  33.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  34.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  35. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  36.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  37.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  38.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  39.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  40.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  41.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  42.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  43.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  44.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  45.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  46.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  47.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  48.     GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  49.       RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  50. }
  51.
  52. void USART_int(long BaudRate)
  53. {
  54.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
  55.        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  56.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  57.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  58.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  59.     /* PA10 USART1_Rx  */
  60.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  61.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  62.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  63.   /* USARTx configured as follow:
  64.         - BaudRate = 115200 baud
  65.         - Word Length = 8 Bits
  66.         - One Stop Bit
  67.         - No parity
  68.         - Hardware flow control disabled (RTS and CTS signals)
  69.         - Receive and transmit enabled
  70.   */
  71.   USART_InitStructure.USART_BaudRate = BaudRate;
  72.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  73.   USART_InitStructure.USART_StopBits = USART_StopBits_1;
  74.   USART_InitStructure.USART_Parity = USART_Parity_No;
  75.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  76.     USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  77.     USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  78.     USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  79.     USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  80.     USART_ClockInit(USART1, &USART_ClockInitStructure);
  81.   USART_Init(USART1, &USART_InitStructure);
  82.   USART_Cmd(USART1, ENABLE);
  83.     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  84.  USART_Cmd(USART1, ENABLE);
  85. }
  86. void delay_us(u32 n)
  87. {
  88.     u8 j;
  89.     while(n--)
  90.     for(j=0;j<10;j++);
  91. }
  92. void  delay_ms(u32 n)
  93. {
  94.     while(n--)
  95.     delay_us(1000);
  96. }
  97. void PWM_Config()
  98. {
  99.     uint16_t PrescalerValue = 0;
  100.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  101.   TIM_OCInitTypeDef  TIM_OCInitStructure;
  102.     /* TIM2 clock enable */
  103.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  104.   /* GPIOA  enable */
  105.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  106.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//PWM&RGB- PA1 PA2 PA3
  107.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  108.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  109.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  110.         TIM_Cmd(TIM2, ENABLE);
  111.       /* Compute the prescaler value */
  112.   PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  113.   /* Time base configuration */
  114.   TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  115.   TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  116.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  117.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  118.   TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  119.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  120.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  121.   /* PWM1 Mode configuration: Channel2 ,PA1在通道2*/
  122.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  123.   TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  124.   TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  125.     /* PWM1 Mode configuration: Channel3 PA2在通道3*/
  126.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  127.   TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  128.   TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  129.     /* PWM1 Mode configuration: Channel4 PA3在通道4*/
  130.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  131.   TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  132.   TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  133.   TIM_ARRPreloadConfig(TIM2, ENABLE);
  134. }
  135. void ADC_CONFIG(){
  136.     ADC_InitTypeDef ADC_InitStructure;
  137.     #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  138.   /* ADCCLK = PCLK2/2 */
  139.   RCC_ADCCLKConfig(RCC_PCLK2_Div2);
  140. #else
  141.   /* ADCCLK = PCLK2/4 */
  142.   RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  143. #endif
  144. ADC_DeInit(ADC1);
  145.   /* Enable ADC1 and GPIOC clock */
  146.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
  147.     /* Configure PB0 (ADC Channel14) as analog input -------------------------*/
  148.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;//ADC所在端口PB0
  149.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模拟输入模式
  150.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  151.   /* ADC1 configuration ------------------------------------------------------*/
  152.   ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  153.   ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  154.   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  155.   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  156.   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//ADC数据右对齐
  157.   ADC_InitStructure.ADC_NbrOfChannel = 1;//ADC通道数为1
  158.   ADC_Init(ADC1, &ADC_InitStructure);//初始化ADC1
  159.   /* Enable ADC1 DMA */
  160.   ADC_DMACmd(ADC1, ENABLE);
  161.   /* Enable ADC1 */
  162.   ADC_Cmd(ADC1, ENABLE);
  163. }
  164.
  165. int Get_ADC(){
  166.      /* ADC1 regular channel configuration */
  167.   ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);//通道:8 ,采样时间
  168.     /* Enable ADC1 reset calibration register */
  169.   ADC_ResetCalibration(ADC1);//重置ADC1的校准寄存器
  170.   /* Check the end of ADC1 reset calibration register */
  171.   while(ADC_GetResetCalibrationStatus(ADC1));//确认重置完毕
  172.   /* Start ADC1 calibration */
  173.   ADC_StartCalibration(ADC1);
  174.   /* Check the end of ADC1 calibration */
  175.   while(ADC_GetCalibrationStatus(ADC1));
  176.   /* Start ADC1 Software Conversion */
  177.   ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  178.     return ADC_GetConversionValue(ADC1);
  179. }
  180. void PWM_TEST()
  181. {
  182.
  183.     unsigned int temp0=volt,temp1=0,temp2=volt;
  184.     printf("PWM-RGB TEST......\r\n");
  185.    for(;(temp0>0)||(temp1<volt);temp0--,temp1++)
  186.    {
  187.        TIM_SetCompare2(TIM2, temp0);//temp0:volt~0
  188.      TIM_SetCompare3(TIM2, temp1);//temp1:0~volt
  189.        delay_us(1000);
  190.    }
  191.      for(;(temp0<volt)||(temp2>0);temp0++,temp2--)
  192.      {
  193.        TIM_SetCompare2(TIM2, temp0);//temp0:0~volt
  194.        TIM_SetCompare4(TIM2, temp2);//temp2:volt~0
  195.        delay_us(1000);
  196.    }
  197.    for(;(temp1>0)||(temp2<volt);temp1--,temp2++)
  198.    {
  199.        TIM_SetCompare4(TIM2, temp2);//temp2:0~volt
  200.        TIM_SetCompare3(TIM2, temp1);//temp1:volt~0
  201.        delay_us(1000);
  202.    }
  203. }
  204. int main(void)
  205. {
  206.   float Volt=0.00;
  207.     int ADValue = 0;
  208.   RCC_Configuration();
  209.   USART_int(115200);
  210.     ADC_CONFIG();
  211.     Get_ADC();
  212.     PWM_Config();
  213.     delay_ms(1000);
  214.     printf(" config done...\r\n");
  215.     while(1)
  216.     {
  217.         ADValue = Get_ADC();
  218.         Volt = VREF*ADValue/4095;
  219.         volt=Volt*1000;
  220.         printf("===============================\r\n");
  221.         printf("The ADC value is:%d\r\n",ADValue);
  222.         printf("The Volt is:%f V\r\n",Volt);
  223.         printf("The volt is:%d \r\n",volt);
  224.         PWM_TEST();
  225.         delay_ms(500);
  226.     }
  227. }
  228.
  229. #ifdef  USE_FULL_ASSERT
  230.
  231. void assert_failed(uint8_t* file, uint32_t line)
  232. {
  233.   while (1)
  234.   {
  235.   }
  236. }
  237.
  238. #endif
  239.
  240. #ifdef __GNUC__
  241.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  242. #else
  243.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  244. #endif /* __GNUC__ */
  245.
  246. PUTCHAR_PROTOTYPE
  247. {
  248.
  249.   USART_SendData(EVAL_COM1, (uint8_t) ch);
  250.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  251.   {}
  252.
  253.   return ch;
  254. }
  255.
  256. #ifdef  USE_FULL_ASSERT
  257.
  258. void assert_failed(uint8_t* file, uint32_t line)
  259. {
  260.   while (1)
  261.   {
  262.   }
  263. }
  264. #endif
共8条 1/1 1 跳转至页
