新手学习F2812DSP 要用XINTF让DSP和FPGA之间通信,接收来自FPGA的四个数据。 我是给这四路数据在DSP XINTF的zone0里面分了地址,通过XINT2下降沿来触发中断从而将来自FPGA的数据读进DSP XINTF的zone0的对应地址。不知道为什么就是检测不到读写时能信号的跳变,也没法正常读数。以下是我的程序以及配置,求大神指导! //地址分配头文件“EXFPGA.h” #define ADC0 0x002000 #define ADC1 0x002100 #define ADC2 0x002200 #define ADC3 0x002300 unsigned int ADC0_Data; unsigned int ADC1_Data; unsigned int ADC2_Data; unsigned int ADC3_Data; nt *ptrADC0; int *ptrADC1; int *ptrADC2; int *ptrADC3; //XINTF的初始化配置文件“Xintf.c” void InitXintf(void) { XintfRegs.XINTCNF2.bit.XTIMCLK = 0; XintfRegs.XINTCNF2.bit.WRBUFF = 0; XintfRegs.XINTCNF2.bit.CLKOFF = 0; XintfRegs.XINTCNF2.bit.CLKMODE = 0; XintfRegs.XTIMING0.bit.XWRLEAD = 3; XintfRegs.XTIMING0.bit.XWRACTIVE = 7; XintfRegs.XTIMING0.bit.XWRTRAIL = 3; XintfRegs.XTIMING0.bit.XRDLEAD = 3; XintfRegs.XTIMING0.bit.XRDACTIVE = 7; XintfRegs.XTIMING0.bit.XRDTRAIL = 3; XintfRegs.XTIMING0.bit.X2TIMING = 0; XintfRegs.XTIMING0.bit.USEREADY = 0; XintfRegs.XTIMING0.bit.READYMODE = 0; XintfRegs.XTIMING0.bit.XSIZE = 3; } //主程序“read_FPGA_ADC.c” #include "DSP281x_Device.h" #include "DSP281x_System.h" #include "EXFPGA_2812.h" unsigned int read_ADC_data(void); interrupt void XINT_A(void); void main(void) { InitSysCtrl(); DINT; InitPieCtrl(); IER = 0x0000; IFR = 0x0000; InitPieVectTable(); InitGpio(); InitXintf(); InitXIntrupt(); EALLOW; PieVectTable.XINT2 = &XINT_A; EDIS; IER |= M_INT1; PieCtrlRegs.PIEIER1.bit.INTx5=1; EINT; ERTM; while(1) } unsigned int read_ADC_data(void) { ADC0_Data=*ptrADC0; ADC1_Data=*ptrADC1; ADC2_Data=*ptrADC2; ADC3_Data=*ptrADC3; } interrupt void XINT_A(void) { PieCtrlRegs.PIEACK.all=0xFFFF; PieCtrlRegs.PIEIFR1.bit.INTx5=0; read_ADC_data(); if((ADC0_Data==0xFF00)&(ADC1_Data==0x00FF)&(ADC2_Data==0xAAAA)&(ADC3_Data==0x5555))//检测读到的数据是否与FPGA发送的约定的数据相同 { GpioDataRegs.GPGTOGGLE.bit.GPIOG4=1;//若数据正确让该引脚翻转 } else GpioDataRegs.GPGTOGGLE.bit.GPIOG4=0; } |
F2812 用XINTF让DSP和FPGA通信 求助!!!
关键词: FPGA
