电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 刚入了一把Gh60 ,自己想加方向键的,但是还有技术性问题我不是太懂
共6条 1/1 1 跳转至页
2015-12-27 13:47:39     打赏
这是图。
["ESC","!\n1","@\n2","#\n3","$\n4","%\n5","^\n6","&\n7","*\n8","(\n9",")\n0","_\n-","+\n=",{w:2},"Backspace"],
[{w:1.5},"Tab","Q","W","E","R","T","Y","U","I","O","P","{\n[","}\n]",{w:1.5},"|\n\\"],
[{w:1.75},"Caps Lock","A","S","D","F","G","H","J","K","L",":\n;","\"\n'",{w:2.25},"Enter"],
[{w:2.25},"Shift","Z","X","C","V","B","N","M","<\n,",">\n.","/\n\n\n\n\n\n\n\n?",{w:1.75},"↑",{a:0},"Shift\n\n\n\n."],
[{a:4,w:1.25},"Ctrl",{w:1.25},"Win",{w:1.25},"Alt",{a:7,w:6.25},"",{a:4,w:1.25},"Fn",{w:1.25},"←",{w:1.25},"↓",{w:1.25},"→"]
  这是什么代码。。。
然后问题来了。
下面的FN和灯怎么设置。
目前我的灯好像就一种模式,有FN+v 进行控制。。。
论坛大神请提醒我一下,我该接下来怎么做。
2015-12-27 13:49:51     打赏
0.0  昨晚弄到半夜,就搞懂了配列。。。
2015-12-27 15:20:25     打赏
从上边截图来看你选错版本了,咱们的要选REV A/B/C ,开关和灯效都是FN功能 你看下原版配列就懂了
http://www.keyboard-layout-editor.com/#/layouts/7d55431c8a8d9f9bf94b6f6af8ce7c12
2015-12-27 18:44:22     打赏
群文件里面有类60机械键盘修改配列的文档,你可以参考下
2015-12-27 21:44:53     打赏
我也想弄这种。。你的1.75shift键帽是怎么解决的?
2015-12-28 19:10:32     打赏
不难,可以看看别人修改固件的帖子
共6条 1/1 1 跳转至页
