板子拿到很久了,可是一直没有时间发帖。。。
之前也是尝试过点灯,可是一直行不通,最后查找硬件和软件问题。
问题分析后,是IO设置的问题,应该设置成推挽输出。(由于之前一直没时间,所以直到今天才重启拿起来试试)
外部STLink的MCO是有输出的,但是我这里是用的HSI。
在主函数while循环中添加断点,单步调试就可以控制LED等的亮灭。
下面贴出代码。
main.c
#include "stm32l0xx.h"
#include "sys.h"
#include "led.h"
int main(void)
SystemCoreClockConfigure();
SystemCoreClockUpdate();
led_init();
while(1)
GPIOA->BSRR = 1 << 5; GPIOA->BRR = 1 << 5; } }
led.c
#include "led.h"
int
led_init(void)
//PA5
RCC->IOPENR |= 0x0001;
GPIOA->MODER &= ~(0x3 << 10); GPIOA->MODER |= 0x1 << 10; GPIOA->OTYPER &= ~(0x1 << 5); GPIOA->OSPEEDR |= 0x3 << 10; GPIOA->PUPDR &= ~(0x3 << 10); return 0; }
sys.c
#include "sys.h"
* SystemCoreClockConfigure: configure SystemCoreClock using HSI
void
SystemCoreClockConfigure(void)
RCC->CR |= ((uint32_t)RCC_CR_HSION); // Enable HSI
while ((RCC->CR & RCC_CR_HSIRDY) == 0); // Wait for HSI Ready
RCC->CFGR = RCC_CFGR_SW_HSI; // HSI is system clock
while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_HSI); // Wait for HSI used as system clock
// PLL configuration: PLLCLK = (HSI * 4)/2 = 32 MHz
RCC->CFGR &= ~(RCC_CFGR_PLLSRC |
RCC_CFGR_PLLMUL |
RCC_CFGR_PLLDIV );
RCC->CFGR |= (RCC_CFGR_PLLSRC_HSI |
RCC_CFGR_PLLMUL4 |
RCC_CFGR_PLLDIV2 );
FLASH->ACR |= FLASH_ACR_PRFTEN; // Enable Prefetch Buffer
FLASH->ACR |= FLASH_ACR_LATENCY; // Flash 1 wait state
RCC->APB1ENR |= RCC_APB1ENR_PWREN; // Enable the PWR APB1 Clock
PWR->CR = PWR_CR_VOS_0; // Select the Voltage Range 1 (1.8V)
while((PWR->CSR & PWR_CSR_VOSF) != 0); // Wait for Voltage Regulator Ready
RCC->CFGR |= RCC_CFGR_HPRE_DIV1; // HCLK = SYSCLK
RCC->CFGR |= RCC_CFGR_PPRE1_DIV1; // PCLK1 = HCLK
RCC->CFGR |= RCC_CFGR_PPRE2_DIV1; // PCLK2 = HCLK
RCC->CR &= ~RCC_CR_PLLON; // Disable PLL
RCC->CR |= RCC_CR_PLLON; // Enable PLL
while((RCC->CR & RCC_CR_PLLRDY) == 0) __NOP(); // Wait till PLL is ready
RCC->CFGR &= ~RCC_CFGR_SW; // Select PLL as system clock source
RCC->CFGR |= RCC_CFGR_SW_PLL;
while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_PLL); // Wait till PLL is system clock src
MDK寄存器版模板见如下附件
