电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 2.28】作业更新
共8条 1/1 1 跳转至
2.28】作业更新
2016-01-16 22:09:58     打赏
2016-01-16 22:39:59     打赏
1.运行安装程序
2.选择 i agree
3.s选择路径安装
4.安装完成后开始破解
5.用这个神器破解,一个序列号不行就多刷几个
破解完就可以正常使用了
2016-01-16 22:42:42     打赏
作业2:流水灯
代码:#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
2016-01-16 22:43:39     打赏
作业3:0~99按键计数
代码:GPIO_InitTypeDef GPIO_InitStructure; // 声明一个结构体
void RCC_Configuration(void);
void GPIO_INIT(void) ;
void Function(void) ;
int main(void)
    RCC_Configuration();
    GPIO_INIT();
    Function();
void RCC_Configuration(void)    //复位所有的RCC外围设备寄存器
    ErrorStatus HSEStartUpStatus;   //  设置错误标志量
  RCC_DeInit();                 //复位RCC模块的寄存器,复位成缺省值
 RCC_HSEConfig(RCC_HSE_ON);      //开启HSE时钟
  HSEStartUpStatus = RCC_WaitForHSEStartUp();  //获取HSE启动状态:
  if(HSEStartUpStatus==SUCCESS) //如果HSE启动成功
        FLASH_PrefetchBufferCmd(ENABLE);          //开启FLASH的预取功能
        FLASH_SetLatency(FLASH_Latency_2);      //FLASH延迟2个周期
        RCC_HCLKConfig(RCC_SYSCLK_Div1); //配置HCLK,PCLK2,PCLK1,PLL
        RCC_PLLCmd(ENABLE); //启动PLL
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);
        {}   //等待PLL启动完成
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//配置系统时钟
        while(RCC_GetSYSCLKSource() != 0x08); //检查是否将HSE 9倍频后作为系统时钟
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//改变管脚的映射SWJ使能选择用于事件输出的GPIO端口
    /*蜂鸣器*/
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //使能所有要用APB2的外设时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;       //选中2引脚
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        // 引脚频率50M
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     //引脚设置推拉输出
  GPIO_Init(GPIOD, &GPIO_InitStructure);    //初始化GPIOD
void delay_us(u32 n)        //延时函数
    u8 j;
    while(n--)
            for(j=0;j<10;j++);
void  delay_ms(u32 n)       //延时函数
   while(n--)
   delay_us(1000);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOB, ENABLE);   //使能所有要用APB2的外设时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;  //选中8,9,10,11引脚
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //引脚设置推拉输出
        GPIO_Init(GPIOC, &GPIO_InitStructure);  //初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_1|GPIO_Pin_15|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;//数码管
        GPIO_Init(GPIOB, &GPIO_InitStructure);    //初始化
void Number(int a)  //数码管显示数字
    switch(a)
        case 0 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 1 : GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);break;
        case 2 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);break;
        case 3 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);break;
        case 4 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);break;
        case 5 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);break;
        case 6 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 7 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);break;
        case 8 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 9 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break;
void Function(void)
        int i=0,j=0;          //i被按下的次数,n延时变量
        GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
        delay_ms(50); //关闭数码管
        while(1)
                GPIO_SetBits(GPIOB,GPIO_Pin_1);         //打开个位数码管
                Number(i);                                //用switch函数显示00
                delay_ms(50);
                GPIO_ResetBits(GPIOB,GPIO_Pin_1);        //关闭个位
                GPIO_SetBits(GPIOB,GPIO_Pin_15);           //打开十位
                Number(j);
                delay_ms(50);
                GPIO_ResetBits(GPIOB,GPIO_Pin_15);      //关掉十位数码管
                if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))   //判断按键是s1否被按下
                    delay_ms(50);            //延时消抖
                    if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))  //再次判断按键是s1否被按下
                        i++;                     //按键被按下,个位+1
                        if(i==10)
                            j++;
                            i=0;
                        if(j==10)
                             j=0;
                                                 i=0;
2016-01-16 22:44:48     打赏
作业4:uart控制LED流水灯转速
#include "stdbool.h"
int main(void)
    GPIO_INIT();
    Function();
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
void GPIO_INIT()
   //GPIO数码管初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8
|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  //按键初始化
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
  void Function(void)
        while(1)
                delay_ms(50);
                Number(j);
                delay_ms(50);
                        i++;                     //按键被按下,个位+1
                        if(i==10)
                            j++;
                            i=0;
                        if(j==10)
                             j=0;
                                                 i=0;
  * @brief  Main program.
  * @param  None
  * @retval None
2016-01-16 22:45:40     打赏
作业5:定时器控制LED灯
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include <stdio.h>
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
EXTI_InitTypeDef   EXTI_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
/* Private function prototypes -----------------------------------------------*/
void EXTIkeyS3_Config(void);
void EXTIkeyS4_Config(void);
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Configure four bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  /* Enable the USART1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
/* Private functions ---------------------------------------------------------*/
  * @param  None
  * @retval None
int main(void)
{RCC_Configuration();
  /* Configure PA.00 in interrupt mode */
  EXTIkeyS3_Config();
  /* Configure PB.09 or PG.08 in interrupt mode */
  EXTIkeyS4_Config();
USART_int(115200);
printf("Config done,waiting for interrupt......\r\n");
  while (1)
  * @brief  Configure PA.00 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOA clock */
  /* Configure PA.00 pin as input floating */
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  /* Connect EXTI0 Line to PA.00 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource10);
  /* Configure EXTI0 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line10;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI0 Interrupt to the lowest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  * @brief  Configure PB.09 or PG.08 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOB clock */
  /* Configure PB.09 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  /* Connect EXTI9 Line to PB.09 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource11);
  /* Configure EXTI9 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line11;
  /* Enable and set EXTI9_5 Interrupt to the lowest priority */
/*            STM32F10x Peripherals Interrupt Handlers                        */
  * @brief  This function handles External lines 9 to 5 interrupt request.
  * @param  None
  * @retval None
void EXTI15_10_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line10) != RESET)
    /* Toggle LED2 */
     GPIO_SetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
printf("S4 interrupt ......\r\n");
    /* Clear the  EXTI line 9 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line10);
if(EXTI_GetITStatus(EXTI_Line11) != RESET)
    /* Toggle LED1 */
     GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
printf("S3 interrupt ......\r\n");
    /* Clear the  EXTI line 0 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line11);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2016-01-20 13:33:14     打赏
//定时器 5 通道 1 输入捕获配置
TIM_ICInitTypeDef TIM5_ICInitStructure;
void TIM5_Cap_Init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE); //①使能 TIM5 时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //①使能 GPIOA 时钟
//初始化 GPIOA.0 ①
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //PA0 设置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PA0 输入
GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化 GPIOA.0
GPIO_ResetBits(GPIOA,GPIO_Pin_0);  //PA0 下拉
//②初始化 TIM5 参数
TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
TIM_TimeBaseStructure.TIM_Prescaler =psc; //预分频器
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; // TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM 向上计数模式
TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure); //初始化 TIMx
//③初始化 TIM5 输入捕获通道 1
TIM5_ICInitStructure.TIM_Channel = TIM_Channel_1; //选择输入端 IC1 映射到 TI1 上
TIM5_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;  //上升沿捕获
TIM5_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到 TI1 上
TIM5_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
TIM5_ICInitStructure.TIM_ICFilter = 0x00; //IC1F=0000 配置输入滤波器 不滤波
TIM_ICInit(TIM5, &TIM5_ICInitStructure); //初始化 TIM5 输入捕获通道 1
//⑤初始化 NVIC 中断优先级分组
NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn; //TIM3 中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //先占优先级 2 级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //从优先级 0 级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ 通道被使能
NVIC_Init(&NVIC_InitStructure); //初始化 NVIC
TIM_ITConfig( TIM5,TIM_IT_Update|TIM_IT_CC1,ENABLE);//④允许更新中断捕获中断
TIM_Cmd(TIM5,ENABLE ); //⑥使能定时器 5
u8 TIM5CH1_CAPTURE_STA=0;  //输入捕获状态
u16 TIM5CH1_CAPTURE_VAL; //输入捕获值
//⑤定时器 5 中断服务程序
void TIM5_IRQHandler(void)
if((TIM5CH1_CAPTURE_STA&0X80)==0)//还未成功捕获
if (TIM_GetITStatus(TIM5, TIM_IT_Update) != RESET)
if(TIM5CH1_CAPTURE_STA&0X40) //已经捕获到高电平了
if((TIM5CH1_CAPTURE_STA&0X3F)==0X3F)//高电平太长了
TIM5CH1_CAPTURE_STA|=0X80; //标记成功捕获了一次
TIM5CH1_CAPTURE_VAL=0XFFFF;
}else TIM5CH1_CAPTURE_STA++;
if (TIM_GetITStatus(TIM5, TIM_IT_CC1) != RESET) //捕获 1 发生捕获事件
if(TIM5CH1_CAPTURE_STA&0X40) //捕获到一个下降沿
TIM5CH1_CAPTURE_STA|=0X80;  //标记成功捕获到一次上升沿
TIM5CH1_CAPTURE_VAL=TIM_GetCapture1(TIM5);
TIM_OC1PolarityConfig(TIM5,TIM_ICPolarity_Rising); //设置为上升沿捕获
}else //还未开始,第一次捕获上升沿
TIM5CH1_CAPTURE_STA=0;  //清空
TIM5CH1_CAPTURE_VAL=0;
TIM_SetCounter(TIM5,0);
TIM5CH1_CAPTURE_STA|=0X40;  //标记捕获到了上升沿
TIM_OC1PolarityConfig(TIM5,TIM_ICPolarity_Falling); //设置为下降沿捕获
TIM_ClearITPendingBit(TIM5, TIM_IT_CC1|TIM_IT_Update); //清除中断标志位
//timer.h
extern u8 TIM5CH1_CAPTURE_STA;  //输入捕获状态
extern u16  TIM5CH1_CAPTURE_VAL; //输入捕获值
int main(void)
u32 temp=0;
delay_init();  //延时函数初始化
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置 NVIC 中断分组 2
uart_init(115200); //串口初始化波特率为 115200
LED_Init();  //LED 端口初始化
TIM3_PWM_Init(899,0); //不分频。PWM 频率=72000/(899+1)=80Khz
TIM5_Cap_Init(0XFFFF,72-1);  //以 1Mhz 的频率计数
while(1)
delay_ms(10);
TIM_SetCompare2(TIM3,TIM_GetCapture2(TIM3)+1);
if(TIM_GetCapture2(TIM3)==300)
TIM_SetCompare2(TIM3,0);
if(TIM5CH1_CAPTURE_STA&0X80)//成功捕获到了一次上升沿
temp=TIM5CH1_CAPTURE_STA&0X3F;
temp*=65536;//溢出时间总和
temp+=TIM5CH1_CAPTURE_VAL;//得到总的高电平时间
printf("HIGH:%d us\r\n",temp); //打印总的高点平时间
TIM5CH1_CAPTURE_STA=0; //开启下一次捕获
2016-02-27 18:47:20     打赏
7.期末项目
#include "stdio.h"
int fputc(int ch,FILE *f);
/********************RCC配置*********************/
RCC_DeInit();
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);
RCC_PLLCmd(ENABLE);
/**蜂鸣器*/
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
/*****************************GPIO初始********************************/
void GPIO_Inits(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
/*GPIOA--RGB初始化*/
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3)
/**************************DS18B20**********************/
uint8_t DS18B20_Init(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
Set_B20();
DS18B20_Rst();
return DS18B20_Presence ();
static void DS18B20_Mode_IPU(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
static void DS18B20_Mode_Out_PP(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
static void DS18B20_Rst(void)
DS18B20_Mode_Out_PP();
Reset_B20() ;
delay_us(700);
Set_B20()   ;
delay_us(15);
static uint8_t DS18B20_Presence(void)
uint8_t pulse_time = 0;
DS18B20_Mode_IPU();
while( Read_B20() && pulse_time<100 )
pulse_time++;
delay_us(1);
if( pulse_time >=100 )
return 1;
else
pulse_time = 0;
while( !Read_B20() && pulse_time<240 )
pulse_time++;
delay_us(1);
if( pulse_time >=240 )
return 1;
else
return 0;
static uint8_t DS18B20_ReadBit(void)
uint8_t dat;
Reset_B20();
delay_us(10);
DS18B20_Mode_IPU();
//Delay_us(2);
if( Read_B20() == SET )
dat = 1;
else
dat = 0;
delay_us(45);
return dat;
static uint8_t DS18B20_ReadByte(void)
uint8_t i, j, dat = 0;
for(i=0; i<8; i++)
j = DS18B20_ReadBit();
dat = (dat) | (j<
return dat;
static void DS18B20_WriteByte(uint8_t dat)
uint8_t i, testb;
for( i=0; i<8; i++ )
testb = dat&0x01;
dat = dat>>1;
if (testb)
Reset_B20();
delay_us(8);
Set_B20();
delay_us(58);
else
Reset_B20();
/* 60us < Tx 0 < 120us */
delay_us(70);
Set_B20();
delay_us(2);
static void DS18B20_SkipRom ( void )
DS18B20_Rst();
DS18B20_Presence();
DS18B20_WriteByte(0XCC);
static void DS18B20_MatchRom ( void )
DS18B20_Rst();
DS18B20_Presence();
DS18B20_WriteByte(0X55);
float DS18B20_GetTemp_SkipRom ( void )
uint8_t tpmsb, tplsb;
short s_tem;
float f_tem;
DS18B20_SkipRom ();
DS18B20_WriteByte(0X44);
DS18B20_SkipRom ();
DS18B20_WriteByte(0XBE);
tplsb = DS18B20_ReadByte();
tpmsb = DS18B20_ReadByte();
s_tem = tpmsb<<8;
s_tem = s_tem | tplsb;
if( s_tem < 0 )
f_tem = (~s_tem+1) * 0.0625;
else
f_tem = s_tem * 0.0625;
return f_tem;
void DS18B20_ReadId ( uint8_t * ds18b20_id )
uint8_t uc;
DS18B20_WriteByte(0x33);
for ( uc = 0; uc < 8; uc ++ )
ds18b20_id [ uc ] = DS18B20_ReadByte();
float DS18B20_GetTemp_MatchRom ( uint8_t * ds18b20_id )
uint8_t tpmsb, tplsb, i;
short s_tem;
float f_tem;
DS18B20_MatchRom ();
for(i=0;i<8;i++)
DS18B20_WriteByte ( ds18b20_id [ i ] );
for(i=0;i<8;i++)
s_tem = tpmsb<<8;
if( s_tem < 0 )
else
return f_tem;
int main()
uint8_t uc, ucDs18b20Id [ 8 ];
GPIO_Inits();
USART_int(9600);
while( DS18B20_Init() )
printf("\r\n no ds18b20 exit \r\n");
printf("\r\n Yes ds18b20 \r\n");
DS18B20_ReadId ( ucDs18b20Id  );
printf("\r\nDS18B20的序列号是: 0x");
printf ( "%.2x", ucDs18b20Id [ uc ] );
for(;;)
static unsigned int i=0;
float a,b;
if(i==10)
printf ( "\r\n第10秒:温度: %.1f\r\n", DS18B20_GetTemp_MatchRom ( ucDs18b20Id ) );
a=DS18B20_GetTemp_MatchRom ( ucDs18b20Id );
delay_ms(1000);
i++;
else{}
if(i<10)
printf ( "\r\n温度: %.1f\r\n", DS18B20_GetTemp_MatchRom ( ucDs18b20Id ) );
delay_ms(1000);
i++;
if(i>10)
printf ( "\r\n10秒后:温度: %.1f\r\n", DS18B20_GetTemp_MatchRom ( ucDs18b20Id ) );
b=DS18B20_GetTemp_MatchRom ( ucDs18b20Id );
delay_ms(1000);
i++;
if((b-a)>0.9)
{GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
else{}
if((b-a)<0.9)
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
else{}
else{}
USART_SendData(USART1, (uint8_t) ch);
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
return ch;
共8条 1/1 1 跳转至
